16-VXLAN命令参考
01-VXLAN命令
本章节下载 01-VXLAN命令  (383.39 KB)
01-VXLAN命令
1 VXLAN
1.1 VXLAN基础配置命令
1.1.1 ac statistics enable (VLAN view)
1.1.2 arp suppression enable
1.1.3 description
1.1.4 display arp suppression vsi
1.1.5 display igmp host group
1.1.6 display ipv6 nd suppression vsi
1.1.7 display l2vpn mac-address
1.1.8 display l2vpn service-instance
1.1.9 display l2vpn vsi
1.1.10 display vxlan tunnel
1.1.11 encapsulation
1.1.12 flooding disable
1.1.13 group
1.1.14 igmp host enable
1.1.15 ipv6 nd suppression enable
1.1.16 l2vpn enable
1.1.17 l2vpn mac-address software-learning enable
1.1.18 mac-address static vsi
1.1.19 mac-based ac
1.1.20 reserved vxlan
1.1.21 reset arp suppression vsi
1.1.22 reset ipv6 nd suppression vsi
1.1.23 reset l2vpn mac-address
1.1.24 reset l2vpn statistics ac
1.1.25 reset l2vpn statistics vsi
1.1.26 rewrite inbound tag
1.1.27 rewrite outbound tag
1.1.28 selective-flooding mac-address
1.1.29 service-instance
1.1.30 shutdown
1.1.31 statistics enable (Ethernet service instance view)
1.1.32 statistics enable (VSI view)
1.1.33 tunnel
1.1.34 tunnel bfd enable
1.1.35 tunnel global source-address
1.1.36 vsi
1.1.37 vxlan
1.1.38 vxlan invalid-vlan-tag discard
1.1.39 vxlan local-mac report
1.1.40 vxlan tunnel mac-learning disable
1.1.41 vxlan udp-port
1.1.42 vxlan vlan-based
1.1.43 vxlan vni
1.1.44 xconnect vsi
1.2 VXLAN IP网关配置命令
1.2.1 arp distributed-gateway dynamic-entry synchronize
1.2.2 arp send-rate
1.2.3 default
1.2.4 description
1.2.5 display interface vsi-interface
1.2.6 distributed-gateway local
1.2.7 gateway subnet
1.2.8 gateway vsi-interface
1.2.9 interface vsi-interface
1.2.10 ipv6 nd distributed-gateway dynamic-entry synchronize
1.2.11 mac-address
1.2.12 mtu
1.2.13 shutdown
1.2.14 vtep group member local
1.2.15 vtep group member remote
1.2.16 vxlan tunnel arp-learning disable
1.2.17 vxlan tunnel nd-learning disable
1.3 OVSDB-VTEP配置命令
1.3.1 ovsdb server bootstrap ca-certificate
1.3.2 ovsdb server enable
1.3.3 ovsdb server pki domain
1.3.4 ovsdb server pssl
1.3.5 ovsdb server ptcp
1.3.6 ovsdb server ssl
1.3.7 ovsdb server tcp
1.3.8 vtep access port
1.3.9 vtep enable
1 VXLAN
1.1  VXLAN基础配置命令
ac statistics enable命令用来开启VLAN下对应AC的统计功能。
undo ac statistics enable命令用来关闭VLAN下对应AC的统计功能。
VLAN下对应AC的统计功能处于关闭状态。
VLAN视图
采用VLAN与VXLAN关联方式时,开启VLAN下对应AC的统计功能后,可以对该VLAN下自动生成的AC进行报文统计。
开启本功能前,必须先执行vxlan vlan-based命令开启VLAN关联VXLAN功能。
# 配置VLAN 10关联VXLAN 100,并开启VLAN 10下对应AC的统计功能。
[Sysname] vxlan vlan-based
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
[Sysname-vlan10] ac statistics enable
·              display l2vpn service-instance
·              reset l2vpn statistics ac
·              vxlan vlan-based
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
ARP泛洪抑制功能处于关闭状态。
VSI视图
为了避免广播发送的ARP请求报文过多占用核心网络带宽,VTEP从本地站点、VXLAN隧道接收到ARP请求和ARP应答报文后,根据该报文在本地建立ARP泛洪抑制表项。后续当VTEP收到本站点内虚拟机请求其它虚拟机MAC地址的ARP请求时,优先根据ARP泛洪抑制表项进行代答。如果没有对应的表项,则将ARP请求泛洪到核心网。ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
# 在VSI vsi1下开启ARP泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
·              display arp suppression vsi
·              reset arp suppression vsi
1.1.3  description
description命令用来配置VSI的描述信息。
undo description命令用来恢复缺省情况。
未配置VSI的描述信息。
VSI视图
text:VSI的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn1的VSI的描述信息为“vsi for vpn1”。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
·              display l2vpn vsi
display arp suppression vsi命令用来显示VSI的ARP泛洪抑制表项信息。
(独立运行模式)
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
slot slot-number:显示指定单板的ARP泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的ARP泛洪抑制表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的ARP泛洪抑制表项。(IRF模式)
count:显示ARP泛洪抑制表项的个数。
# 显示VSI的ARP泛洪抑制表项信息。
<Sysname> display arp suppression vsi
IP address      MAC address    VSI name                        Link ID    Aging
1.1.1.2         000f-e201-0101 vsi1                            0x70000    14
1.1.1.3         000f-e201-0202 vsi1                            0x80000    18
1.1.1.4         000f-e201-0203 vsi2                            0x90000    10
# 显示VSI的ARP泛洪抑制表项个数。
<Sysname> display arp suppression vsi count
Total entries: 3
表1-1 display arp suppression vsi命令显示信息描述表
IP address
ARP泛洪抑制表项的IP地址
MAC address
ARP泛洪抑制表项的MAC地址
VSI name
VSI名称
Link ID
ARP泛洪抑制表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging
ARP泛洪抑制表项的老化时间,单位为分钟
Total entries
ARP泛洪抑制表项的数目
·              arp suppression enable
display igmp host group命令用来显示IGMP执行主机行为的所有组播组信息。
display igmp host group [ group-address | interface interface-type interface-number ] [ verbose ]
group-address:显示指定组播组的信息,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,则显示所有组播组的信息。
interface interface-type interface-number:显示指定接口上的信息。如果未指定本参数,则显示所有接口上的信息。
verbose:显示详细信息。如果未指定本参数,则显示简要信息。
采用组播路由方式泛洪流量时,VXLAN组播报文源IP地址所在的接口需要作为IGMP主机加入VXLAN所在的组播组。通过本命令可以查看接口是否加入组播组,及该组播组的信息。
# 显示IGMP执行主机行为的所有组播组的简要信息。
<Sysname> display igmp host group
IGMP host groups in total: 2
 Vlan-interface10(1.1.1.20):
   Group address      Member state      Expires
   225.1.1.1          Idle              Off
   225.1.1.2          Idle              Off
# 显示IGMP执行主机行为的所有组播组的详细信息。
<Sysname> display igmp host group verbose
   Group: 225.1.1.1
     Group mode: Exclude
     Member state: Idle
     Expires: Off
     Source list (sources in total: 0):
   Group: 225.1.1.2
     Group mode: Exclude
     Member state: Idle
     Expires: Off
表1-2 display igmp host group命令显示信息描述表
IGMP执行主机行为的组播组总数
IGMP执行主机行为的接口的名称和IP地址
当前接口下IGMP执行主机行为的组播组数目
Group address/Group
组播组地址
Member state
组播组成员的状态,取值包括:
·          Delay:表示加入了组播组,并对该组启动了延迟发送报告报文的定时器
·          Idle:表示加入了组播组,但对该组尚未启动延迟发送报告报文的定时器
延迟发送报告报文定时器的值不可配置
Expires
组播组延迟发送报告报文的剩余时间,Off表示该定时器关闭
Group mode
对组播源的过滤模式,取值包括:
·          Include:表示INCLUDE模式
·          Exclude:表示EXCLUDE模式
Source list
IGMP执行主机行为的组播组所包含的组播源列表
sources in total
组播源的总数
对本命令的显示信息更加详细的介绍,请参见“IP组播配置指导”中的“IGMP”。
·              igmp host enable
display ipv6 nd suppression vsi命令用来显示VSI的ND泛洪抑制表项信息。
(独立运行模式)
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
display ipv6 nd suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ND泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ND泛洪抑制表项。
slot slot-number:显示指定单板的ND泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的ND泛洪抑制表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ND泛洪抑制表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的ND泛洪抑制表项。(IRF模式)
count:显示ND泛洪抑制表项的个数。
# 显示VSI的ND泛洪抑制表项信息。
<Sysname> display ipv6 nd suppression vsi
IPv6 address    MAC address      VSI name         Link ID      Aging (min)
1000::2         000f-e201-0101   vsi1             0x70000      5
1000::3         000f-e201-0202   vsi1             0x80000      5
1000::4         000f-e201-0203   vsi2             0x90000      5
# 显示VSI的ND泛洪抑制表项个数。
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
表1-3 display ipv6 nd suppression vsi命令显示信息描述表
IPv6 address
ND泛洪抑制表项的IPv6地址
MAC address
ND泛洪抑制表项的MAC地址
VSI name
VSI名称
Link ID
ND泛洪抑制表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging (min)
ND泛洪抑制表项的老化时间,单位为分钟
Total entries
ND泛洪抑制表项的数目
·              ipv6 nd suppression enable
·              reset ipv6 nd suppression vsi
display l2vpn mac-address命令用来显示VSI的MAC地址表信息。
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址表信息。
dynamic:显示通过源MAC地址动态学习的MAC地址表项。如果不指定本参数,则显示通过源MAC地址动态学习的本地和远端MAC地址表项、通过BGP EVPN协议学习的远端MAC地址表项、静态配置的本地和远端MAC地址表项、通过OpenFlow下发的远端MAC地址表项和通过OVSDB生成的远端MAC地址表项。
count:显示MAC地址表项的数目。
verbose:显示MAC地址表项的详细信息。
执行本命令时,如果没有指定countverbose参数,则显示MAC地址表项的简要信息。
# 显示所有VSI的MAC地址表简要信息。
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 3 mac address(es) found  ---
# 显示所有VSI的MAC地址表项总数。
<Sysname> display l2vpn mac-address count
表1-4 display l2vpn mac-address命令显示信息描述表
MAC Address
MAC地址
MAC地址的状态,取值包括:
·          Dynamic:表示通过源MAC地址动态学习的本地或远端MAC地址表项
·          Static:表示静态配置的本地或远端MAC地址表项
·          EVPN:表示通过BGP EVPN协议学习的远端MAC地址表项
·          OpenFlow:表示通过OpenFlow下发的远端MAC地址表项
·          OVSDB:表示通过OVSDB生成的远端MAC地址表项
VSI Name
VSI名称
Link ID/Name
对于本端MAC地址,为MAC地址对应以太网服务实例所在接口的名称
对于远端MAC地址,为MAC地址对应的隧道接口名称
Aging
MAC地址表项是否老化,取值包括Aging和NotAging
XX mac address(es) found
VSI的MAC地址表项的总数
# 显示所有VSI的MAC地址表详细信息。
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name    : vpn1
VXLAN ID    : 123
Interface   : XGE1/0/1
Link ID     : 1
State       : Dynamic
Aging       : Aging
表1-5 display l2vpn mac-address verbose命令显示信息描述表
MAC Address
MAC地址
VSI Name
MAC地址所属的VSI名称
VXLAN ID
VXLAN编号
对于本端MAC地址,为以太网服务实例所在接口的名称
Link ID
AC或VXLAN隧道在VSI内的链路标识符
MAC地址的状态,取值包括:
Aging
·              reset l2vpn mac-address
display l2vpn service-instance命令用来显示以太网服务实例的信息。
interface interface-type interface-number:显示指定二层以太网接口或二层聚合接口上的以太网服务实例信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有二层以太网接口和二层聚合接口上的以太网服务实例信息。
service-instance instance-id:显示指定以太网服务实例的信息。instance-id为以太网服务实例的ID,取值范围为1~4096。如果指定了interface interface-type interface-number参数,未指定本参数,则显示指定二层以太网接口或二层聚合接口上所有以太网服务实例的信息。
# 显示所有以太网服务实例的简要信息。
<Sysname> display l2vpn service-instance
Total number of service-instances: 4, 4 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                SrvID Owner                           LinkID State Type
XGE1/0/1                 3     vsi12                           1      Up    VSI
XGE1/0/1                 4     vsi13                           1      Up    VSI
表1-6 display l2vpn service-instance命令显示信息描述表
以太网服务实例的总数,及处于up和down状态的以太网服务实例数目
Total number of ACs
AC的总数,及处于up和down状态的AC数目
二层以太网接口或二层聚合接口名称
SrvID
以太网服务实例的ID
Owner
VSI名称,如果以太网服务实例上尚未关联VSI,则该字段显示为空
LinkID
以太网服务实例在VSI内的链路标识符
以太网服务实例的状态,取值包括Up和Down
以太网服务实例所属的L2VPN类型,取值包括VSI和VPWS
# 显示二层以太网接口Ten-GigabitEthernet1/0/1上所有以太网服务实例的详细信息。
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 1/0/1 verbose
Interface: XGE1/0/1
  Service Instance: 1
    Type          : Manual
    Encapsulation : s-vid 16
    Bandwidth     : Unlimited
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
表1-7 display l2vpn service-instance verbose命令显示信息描述表
二层以太网接口或二层聚合接口
Service Instance
以太网服务实例ID
以太网服务实例的类型和报文匹配方式,取值包括:
·          Dynamic (MAC-based):动态创建,采用MAC地址匹配方式
·          Dynamic (VLAN-based):动态创建,采用VLAN匹配方式
·          Manual:手工创建,采用VLAN匹配方式
Encapsulation
以太网服务实例的报文匹配规则,如果未配置报文匹配规则,则不显示本字段
Bandwidth
以太网服务实例对应AC上流量的最大带宽,单位为kbps
取值为“Unlimited”时,表示不限制AC上的流量
VSI Name
与以太网服务实例关联的VSI的名称
Link ID
以太网服务实例在VSI内的链路标识符
Statistics
是否使能以太网服务实例的统计功能,取值包括:
·          Enabled:使能了以太网服务实例的统计功能
·          Disabled:禁止以太网服务实例的统计功能
Input Statistics
入方向的以太网服务实例报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)
Output Statistics
出方向的以太网服务实例报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)
·              service-instance
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示所有VSI的简要信息。
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
表1-8 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·          Up:up状态
·          Down:down状态
·          Admin down:通过shutdown命令手工关闭VSI
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Input statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
    MTunnel0             0x6002710  Up     Auto      Disabled
  ACs:
    AC                               Link ID    State    Type
    XGE1/0/1 srv1000                 0          Up       Manual
表1-9 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括:
·          Up:up状态
·          Down:down状态
·          Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
VSI内流量的最大带宽值,单位为kbps
取值为Unlimited时,表示不限制VSI内的流量
Broadcast Restrain
VSI的广播抑制带宽值,单位为kbps
取值为Unlimited时,表示不抑制VSI内的广播流量
Multicast Restrain
VSI的组播抑制带宽值,单位为kbps
取值为Unlimited时,表示不抑制VSI内的组播流量
VSI的未知单播抑制带宽值,单位为kbps
取值为Unlimited时,表示不抑制VSI内的未知单播流量
MAC Learning
是否使能了MAC地址学习功能
MAC Table Limit
VSI内MAC地址表项的最大数目
Drop Unknown
当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
Flooding
是否使能VSI的泛洪功能,取值包括:
·          Enabled:表示使能了VSI的泛洪功能
·          Disabled:表示禁止VSI的泛洪功能
Statistics
是否使能VSI的统计功能,取值包括:
·          Enabled:使能了VSI的统计功能
·          Disabled:禁止VSI的统计功能
Input statistics
入方向的VSI报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)。设备不支持统计错误报文数(Errors)和丢弃的报文数(Discards)
Output statistics
出方向的VSI报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)、错误报文数(Errors)和丢弃的报文数(Discards)。设备不支持统计错误报文数(Errors)和丢弃的报文数(Discards)
Gateway Interface
VSI网关虚接口编号
VXLAN ID
VXLAN编号
Tunnels
与VXLAN关联的隧道信息
Tunnel Name
隧道名称
Link ID
隧道在VSI内的链路标识符
隧道状态,取值包括:
·          Up:Tunnel接口状态Up,隧道可正常转发数据
·          Defect:Tunnel接口状态Up,但是隧道的BFD检测功能检测到隧道故障,请检查VXLAN隧道配置及链路
·          Down:Tunnel接口状态Down,隧道停止数据转发
VXLAN和VXLAN隧道的关联方式,取值包括:
·          Auto:表示自动关联
¡  EVPN自动将VXLAN和VXLAN隧道关联
¡  在组播路由方式下,自动创建用于转发泛洪流量的组播VXLAN隧道(MTunnel),并将其与VXLAN关联
·          Manual:表示手动关联VXLAN和VXLAN隧道
Flood proxy
隧道是否开启了泛洪代理功能,设备暂不支持该功能
ACs
VSI的AC列表
AC
接入电路
Link ID
AC在VSI内的链路标识符
AC的状态,取值包括Up和Down
display vxlan tunnel命令用来显示与VXLAN关联的VXLAN隧道的信息。
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id:显示与指定VXLAN关联的隧道的信息。vxlan-id为VXLAN的编号,取值范围为0~16777215。不指定此参数,则显示所有与VXLAN关联的隧道的信息。
# 显示所有与VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
# 显示与编号为10的VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel vxlan-id 10
表1-10 display vxlan tunnel命令显示信息描述表
已创建的VXLAN的总数
VXLAN ID
VXLAN ID
VSI name
VXLAN所属的VSI名称
Total tunnels
与VXLAN关联的隧道的总数,包括处于Up和Down状态的隧道总数
Tunnel name
隧道名称
Link ID
隧道在VXLAN内的链路标识符
隧道的状态,取值包括:
·          Blocked:该隧道为备用隧道,不进行数据转发,Tunnel接口状态Up‌
·          Auto:表示自动关联
Flood proxy
·              tunnel
·              vxlan
encapsulation命令用来配置以太网服务实例的报文匹配规则。
undo encapsulation命令用来恢复缺省情况。
encapsulation s-vid { vlan-id | vlan-id-list } [ only-tagged ]
encapsulation s-vid { vlan-id | vlan-id-list } c-vid { vlan-id-list | all }
encapsulation c-vid { vlan-id | vlan-id-list }
encapsulation { default | tagged | untagged }
undo encapsulation
未配置报文匹配规则。
以太网服务实例视图
s-vid:匹配外层VLAN标签(Service VLAN ID)为指定值的报文。
c-vid:匹配内层VLAN标签(Customer VLAN ID)为指定值的报文。
vlan-id:VLAN的编号,取值范围为1~4094。
vlan-id-list:VLAN列表,表示一个或多个VLAN的编号。表示方式为vlan-id-list = { vlan-id [ to vlan-id ] }&<1-8>。其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-8>表示前面的参数最多可以输入8次。
only-tagged:表示只匹配携带VLAN标签的报文。当匹配的VLAN为缺省VLAN时,如果未指定本关键字,则会同时匹配所携带VLAN标签为缺省VLAN的报文和未携带VLAN标签的报文;如果指定了本参数,则只匹配所携带VLAN标签为缺省VLAN的报文。
all:所有VLAN。
default:表示缺省的报文匹配规则。同一个以太网接口下最多只能有一个服务实例采用缺省的报文匹配规则。如果接口下同时存在一个采用缺省报文匹配规则的服务实例和多个采用其他报文匹配规则的服务实例,则未与任何其他报文匹配规则匹配的报文将匹配缺省报文匹配规则;如果接口下只存在一个采用缺省报文匹配规则的服务实例,则该接口上的所有报文都匹配缺省报文匹配规则。
untagged:表示匹配未携带VLAN标签的报文。
不能为同一个接口下不同以太网服务实例配置相同的报文匹配规则。
同一个接口下为不同以太网服务实例配置不同的报文匹配规则时,有如下限制:
·              不同以太网服务实例下匹配的外层VLAN ID范围(s-vid vlan-id-list)或内层VLAN ID范围(c-vid vlan-id-list)均不能有交叉。
·              encapsulation tagged命令和带有s-vidc-vid参数的encapsulation命令互斥,不能同时配置。
·              如果同时配置了以下三种命令,则配置了encapsulation c-vid命令的以太网服务实例不能正常工作。
¡  encapsulation s-vid vlan-id-list [ only-tagged ]
¡  encapsulation s-vid vlan-id-list c-vid { vlan-id-list | all }
¡  encapsulation c-vid vlan-id-list
不能通过重复执行本命令修改报文匹配规则。如需修改报文匹配规则,请先通过undo encapsulation命令删除报文匹配规则,再执行encapsulation命令。
删除以太网服务实例下的报文匹配规则后,会自动取消以太网服务实例与VSI的关联。
# 在二层以太网接口Ten-GigabitEthernet1/0/1的以太网服务实例1上配置如下报文匹配规则:匹配外层VLAN标签为111的报文。
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
flooding disable命令用来关闭VSI的泛洪功能。
undo flooding disable命令用来开启VSI的泛洪功能。
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction | dci ]
VSI的泛洪功能处于开启状态。
VSI视图
all:禁止泛洪广播、未知单播和未知组播数据帧。
broadcast:禁止泛洪广播数据帧。
unknown-multicast:禁止泛洪未知组播数据帧。
unknown-unicast:禁止泛洪未知单播数据帧。
all-direction:禁止将AC和VXLAN隧道上接收到的泛洪流量转发给相同VSI内的其他AC和VXLAN隧道。如果不指定本参数,则表示仅禁止将AC上接收到的泛洪流量转发给相同VSI内的VXLAN隧道。
dci:只禁止向数据中心间的VXLAN-DCI隧道泛洪。如果不指定本参数,则表示禁止向VXLAN隧道和VXLAN-DCI隧道泛洪。
缺省情况下,VTEP从本地站点内接收到目的MAC地址为广播、未知单播和未知组播的数据帧后,会在该VXLAN内除接收接口外的所有本地接口和VXLAN隧道上泛洪该数据帧,将该数据帧发送给VXLAN内的所有站点;VTEP从VXLAN隧道接收到目的MAC地址为广播、未知单播和未知组播的数据帧后,会在该VXLAN内的所有本地接口上泛洪该数据帧。通过本命令可以手工禁止某类数据帧在VXLAN内泛洪,以减少网络中的泛洪流量。
数据中心互联场景中,如果只想禁止向数据中心间的VXLAN-DCI隧道泛洪,而数据中心内部的VXLAN隧道可以泛洪,请指定dci参数。
# 在VSI实例vsi1内禁止将本地站点内接收到的广播数据帧泛洪到远端站点。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
1.1.13  group
group命令用来配置VXLAN泛洪的组播地址和组播报文的源IP地址。
undo group命令用来恢复缺省情况。
group group-address source source-address
undo group group-address source source-address
未指定VXLAN泛洪的组播地址和组播报文的源IP地址,VXLAN采用单播路由方式泛洪。
VXLAN视图
group-address:VXLAN泛洪的组播地址,取值范围为224.0.1.0~239.255.255.255。
source source-address:指定VXLAN组播报文的源IP地址。
数据中心网络中需要通过IP核心网络进行二层互联的站点较多时,采用组播路由方式可以节省泛洪流量对核心网络带宽资源的占用。
组播路由泛洪方式支持如下两种实现模式:
·              PIM模式:在VTEP和核心设备上运行PIM协议,以建立组播转发表项。采用该模式时,可以使用Loopback接口地址作为组播报文的源IP地址。当VTEP存在多个网络侧接口时,PIM协议可以动态选择报文的出接口。
·              IGMP主机模式:在VTEP上使能IGMP协议的主机功能、在连接VTEP的核心设备上配置IGMP、在所有核心设备上运行PIM协议,以建立组播转发表项。采用该模式时,必须使用VTEP上网络侧接口的IP地址作为组播报文的源IP地址,并在该接口上使能IGMP协议的主机功能。当VTEP存在多个网络侧接口时,IGMP主机模式只能采用组播报文的源IP地址所在的接口作为报文的出接口。
同一VXLAN网络中的不同VTEP可以采用不同的实现模式。
为确保组播报文转发正常,VXLAN组播报文的源IP地址(source-address)需要指定为一个已创建且处于up状态的VXLAN隧道的源端地址。
可以为不同的VXLAN指定相同的组播地址。例如,多个VXLAN共用相同的VTEP设备时,为这些VXLAN指定相同的组播地址,通过VXLAN ID来区分报文所属的VXLAN,可以减少IP核心网络中建立的组播转发表项数目。为不同VXLAN指定相同的组播地址时,要求为其指定的源IP地址也必须相同。
在同一个VXLAN视图下多次执行本命令,最后一次执行的命令生效。
# 为VXLAN 100配置VXLAN泛洪的组播地址为233.1.1.1、VXLAN组播报文的源IP地址为2.1.1.1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] group 233.1.1.1 source 2.1.1.1
·              igmp host enable
·              pim dm(IP组播命令参考/PIM)
·              pim sm(IP组播命令参考/PIM)
igmp host enable命令用来在接口上开启IGMP协议的主机功能。
undo igmp host enable命令用来在接口上关闭IGMP协议的主机功能。
igmp host enable
接口上IGMP协议的主机功能处于关闭状态。
采用组播路由方式的IGMP主机模式泛洪流量时,必须在VXLAN组播报文源IP地址所在的接口上执行本命令,使得当前接口作为IGMP主机,即从该接口收到IGMP查询报文后,通过该接口发送组播组的报告报文,以便接收该组播组的报文。
只有通过multicast routing命令使能IP组播路由后,本命令才会生效。
# 使能公网实例中的IP组播路由,并在接口Vlan-interface10上开启IGMP协议的主机功能。
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Vlan-interface10] igmp host enable
·              display igmp host group
·              group
·              multicast routing(IP组播命令参考/组播路由与转发)
ipv6 nd suppression enable命令用来开启ND泛洪抑制功能。
undo ipv6 nd suppression enable命令用来关闭ND泛洪抑制功能。
ND泛洪抑制功能处于关闭状态。
VSI视图
为了避免组播发送的ND请求报文占用核心网络带宽,VTEP从本地站点或VXLAN隧道接收到ND请求和ND应答报文后,根据该报文在本地建立ND泛洪抑制表项。后续当VTEP收到本站点内用户终端请求其它用户终端MAC地址的ND请求时,优先根据ND泛洪抑制表项进行代答。如果没有对应的表项,则将ND请求泛洪到核心网。ND泛洪抑制功能可以大大减少ND泛洪的次数。
# 在VSI vsi1下开启ND泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
·              display ipv6 nd suppression vsi
1.1.16  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn mac-address software-learning enable命令用来开启接口的MAC地址软件学习功能。
undo l2vpn mac-address software-learning enable命令用来关闭接口的MAC地址软件学习功能。
接口的MAC地址软件学习功能处于关闭状态,设备采用硬件方式学习MAC地址。
二层以太网接口视图
二层聚合接口视图
本命令适用于SDN(Software Defined Network,软件定义网络)组网。
在SDN组网中,设备将接口学习到的MAC地址上传给控制器,控制器把收到的MAC地址下发给其它远端设备,以减少不必要的广播流量。
接口的MAC地址学习方式包括:
·              硬件学习:接口通过硬件学习MAC地址。软件周期性地检查硬件是否学习到新的MAC地址,把学到的地址上传控制器处理。硬件学习方式下需等待软件检查周期的到来,控制器获取MAC地址的速度较慢。
·              软件学习:接口通过软件学习MAC地址。软件把学到的MAC地址下发给硬件,同时上传控制器处理。软件学习方式下不需等待软件检查周期的到来,控制器获取MAC地址的速度较快。
需要注意的是,开启接口的MAC地址软件学习功能后,大量的MAC地址学习可能对系统造成冲击,不建议用户在大量MAC地址频繁变化的情况下开启本功能。
# 开启二层以太网接口的MAC地址软件学习功能。
[Sysname-Ten-GigabitEthernet1/0/1] l2vpn mac-address software-learning enable
mac-address static vsi命令用来添加静态MAC地址表项。
undo mac-address static vsi命令用来删除指定的静态MAC地址表项。
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] [ interface tunnel tunnel-number ] vsi vsi-name
不存在静态MAC地址表项。
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
interface tunnel tunnel-number:指定远端MAC地址对应的VXLAN隧道接口或VXLAN-DCI隧道接口。tunnel-number为VXLAN隧道接口或VXLAN-DCI隧道接口的编号,取值范围为已创建的隧道接口的编号。
vsi vsi-name:指定MAC地址所属的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址、BGP EVPN协议等学习。
对于远端MAC地址表项,interface tunnel interface-number参数指定的隧道接口必须与vsi vsi-name参数指定的VSI对应的VXLAN关联,否则配置将失败。
执行undo mac-address static vsi命令时如果没有指定任何参数,则删除该VSI下的所有静态MAC地址表项。
# 添加一条静态远端MAC地址表项:MAC地址为000f-e201-0101,VXLAN隧道接口为Tunnel1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
·              vxlan tunnel mac-learning disable
1.1.19  mac-based ac
mac-based ac命令用来开启动态创建的以太网服务实例匹配MAC地址功能。
undo mac-based ac命令用来关闭动态创建的以太网服务实例匹配MAC地址功能。
mac-based ac
undo mac-based ac
动态创建的以太网服务实例匹配MAC地址功能处于关闭状态,即动态创建的以太网服务实例只匹配VLAN。
二层以太网接口视图
二层聚合接口视图
802.1X或MAC地址认证为用户下发授权VSI、Guest VSI、Auth-Fail VSI或Critical VSI后,将用户信息(接入端口、所属VLAN、MAC地址等)及VSI信息通知给VXLAN,VXLAN根据用户信息动态创建以太网服务实例,并将其与VSI关联。
动态创建的以太网服务实例可以通过以下匹配方式判断接口接收到的报文是否属于该AC:
·              VLAN方式:检查报文携带的VLAN ID是否与以太网服务实例匹配的VLAN ID相同。只有二者相同,报文才属于该AC。
·              MAC地址方式:检查报文携带的源MAC地址是否与以太网服务实例匹配的MAC地址相同。只有二者相同,报文才属于该AC。
缺省情况下,动态创建的以太网服务实例采用VLAN匹配方式。如需要采用MAC地址方式,那么必须采用MAC地址认证或基于MAC接入控制的802.1X认证,并开启动态创建的以太网服务实例匹配MAC地址功能。
本命令仅对动态创建的以太网服务实例生效。通过service-instance命令创建的静态以太网服务实例只能通过encapsulation命令配置匹配的VLAN ID,不能匹配MAC地址。
若接口下已存在动态创建的以太网服务实例,则不能通过本命令修改动态创建以太网服务实例匹配MAC地址功能的开启、关闭状态。
# 开启动态创建的以太网服务实例匹配MAC地址功能。
[Sysname-Ten-GigabitEthernet1/0/1] mac-based ac
reserved vxlan命令用来配置保留VXLAN。
undo reserved vxlan命令用来恢复缺省情况。
reserved vxlan vxlan-id
undo reserved vxlan
未指定保留VXLAN。
vxlan-id:保留VXLAN的ID,取值范围为0~16777215。
只能在系统视图下配置一个全局保留VXLAN,该VXLAN不能与VSI下创建的VXLAN相同。
配置的保留VXLAN不能与mapping vni命令配置的映射远端VXLAN相同。
# 配置保留VXLAN为VXLAN 10000。
[Sysname] reserved vxlan 10000
·              mapping vni(EVPN命令参考/EVPN)
reset arp suppression vsi命令用来清除VSI的ARP泛洪抑制表项。
reset arp suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ARP泛洪抑制表项。
# 清除所有VSI的ARP泛洪抑制表项。
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
reset ipv6 nd suppression vsi命令用来清除VSI的ND泛洪抑制表项。
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ND泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ND泛洪抑制表项。
# 清除所有VSI的ND泛洪抑制表项。
<Sysname> reset ipv6 nd suppression vsi
reset l2vpn mac-address命令用来清除通过源MAC地址动态学习的MAC地址表项。
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name:清除指定VSI动态学习的MAC地址表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI动态学习的MAC地址表项。
VSI通过源MAC地址学习到错误的MAC地址表项,或学习的MAC地址表项数目达到最大值时,可以执行本命令,以便重新学习MAC地址表项。
# 清除名为vpn1的VSI通过源MAC地址动态学习的MAC地址表项。
<Sysname> reset l2vpn mac-address vsi vpn1
·              display l2vpn mac-address vsi
reset l2vpn statistics ac命令用来清除AC的报文统计信息。
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id ]
interface interface-type interface-number:清除指定接口的报文统计信息。interface-type interface-number表示接口类型和接口编号。
service-instance instance-id:清除指定以太网服务实例的报文统计信息。instance-id表示以太网服务实例的ID,取值范围为1~4096。
执行本命令时,如果未指定任何参数,则清除所有AC的报文统计信息。
# 清除接口Ten-GigabitEthernet1/0/1上以太网服务实例1的报文统计信息。
<Sysname> reset l2vpn statistics ac interface ten-gigabitethernet 1/0/1 service-instance 1
·              display l2vpn service-instance verbose
·              statistics enable (Ethernet service instance view)
reset l2vpn statistics vsi命令用来清除VSI的报文统计信息。
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name:清除指定VSI的报文统计信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的信息。
# 清除本设备上所有VSI报文统计信息。
<Sysname> reset l2vpn statistics vsi
·              statistics enable (VSI view)
rewrite inbound tag命令用来配置入方向报文的处理规则。
undo rewrite inbound tag命令用来恢复缺省情况。
rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } } [ symmetric ]
不对入方向报文进行处理。
以太网服务实例视图
nest:表示添加标签。
c-vid:表示内层标签。
s-vid:表示外层标签。
vlan-id:表示VLAN的编号,取值范围为1~4094。
remark:表示映射标签。
1-to-1:表示1:1标签映射,即将原有报文中的指定标签映射为指定的值。
2-to-1:表示2:1标签映射,即将原有报文中的两层标签映射为一层标签。
1-to-2:表示1:2标签映射,即将原有报文中的一层标签映射为两层标签。
2-to-2:表示2:2标签映射,即将原有报文中的最外两层标签映射为指定的两层标签。
strip:表示剥离标签。
symmetric:表示对出方向报文进行相反的标签操作。
要使本命令生效,需要满足如下条件:
·              请勿在VXLAN IP网关上使用本命令。本命令与VXLAN IP网关配置互斥。
·              使用encapsulation命令配置以太网服务实例报文匹配规则。
·              xconnect vsi命令配置接入模式为Ethernet。
本命令对其他命令的影响如下:
·              如果本命令和QoS策略同时配置,则本命令的优先级高于QoS策略,QoS策略只对本命令处理后的报文生效。
·              如果配置本命令时指定了symmetric参数,则不能再配置rewrite outbound tag命令;反之,如果已配置了出方向报文的处理规则,则在配置入方向报文的处理规则时不能指定symmetric参数。
·              指定了symmetric参数时,对带有VLAN标签的报文,如果配置strip参数、remark 1-to-1 c-vid vlan-id参数或nest c-vid vlan-id参数,则不支持对出方向报文进行相反的标签操作(添加标签、1:1内层标签映射或剥离内层VLAN标签)。
配置Nest规则时,请注意如下限制:
·              为不带VLAN标签的报文添加一层标签时,该标签视为外层标签,请指定nest s-vid参数。
·              VXLAN网络不支持处理带两层以上VLAN标签的报文。
¡  对带有两层VLAN标签的报文,不支持添加标签(指定nest s-vid vlan-id参数)。
¡  对带有VLAN标签的报文,不支持添加两层标签(指定nest s-vid vlan-id c-vid vlan-id参数)。
·              指定了symmetric参数时,以太网服务实例所在端口需要加入本命令指定的外层VLAN。
·              当以太网服务实例的报文匹配规则为encapsulation { default | tagged }时,使用rewrite inbound tag nest c-vid vlan-id 添加的内层VLAN Tag的802.1p优先级为0,无法从原始VLAN中拷贝。
配置Remark或Strip规则时,请注意如下限制:
·              对带有一层标签的报文进行1:1标签映射或剥离标签时,该层标签视为外层标签(s-vid),请指定remark 1-to-1 s-vid vlan-idstrip s-vid 参数,而不要使用remark 1-to-1 c-vid vlan-idstrip c-vid 参数。
·              指定了strip参数时,如果以太网服务实例的报文匹配规则为encapsulation { default | tagged },则本命令不支持剥离报文最外层的VLAN 标签(指定strip s-vid参数)。
·              指定了symmetric参数时:
¡  如果本命令配置了s-vid参数,则encapsulation命令也要配置s-vid参数;
¡  如果本命令配置了s-vidc-vid参数,则encapsulation命令也要配置s-vidc-vid参数。
·              当以太网服务实例的报文匹配规则为encapsulation { default | tagged }时,使用rewrite inbound tag remark 2-to-1 c-vid vlan-id映射的VLAN Tag 802.1p优先级拷贝自原始的外层VLAN。
·              当以太网服务实例的报文匹配规则为encapsulation { default | tagged }时,使用rewrite inbound tag remark 1-to-2 s-vid vlan-id c-vid vlan-id映射的内层VLAN Tag的802.1p优先级为0,无法从原始VLAN中拷贝。
不能通过重复执行本命令修改入方向报文的处理规则。如需修改入方向报文的处理规则,请先通过undo rewrite inbound tag命令删除入方向报文的处理规则,再执行rewrite inbound tag命令。
# 在二层以太网接口Ten-GigabitEthernet1/0/1的服务实例1上配置报文匹配规则和处理规则如下:对外层VLAN标签为10的入方向报文,将外层标签映射为VLAN标签100。
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 10
[Sysname-Ten-GigabitEthernet1/0/1-srv1] rewrite inbound tag remark 1-to-1 s-vid 100
rewrite outbound tag命令用来配置出方向报文的处理规则。
undo rewrite outbound tag命令用来恢复缺省情况。
rewrite outbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } }
不对出方向报文进行处理。
以太网服务实例视图
nest:表示添加标签。
c-vid:表示内层标签。
s-vid:表示外层标签。
remark:表示映射标签。
strip:表示剥离标签。
要使本命令生效,需要满足如下条件:
本命令对其他命令的影响如下:
·              配置本命令后,在配置rewrite inbound tag命令时不能指定symmetric参数。
对带有VLAN标签的报文,本命令不支持添加标签(指定nest参数)、1:1内层标签映射(指定remark 1-to-1 c-vid vlan-id参数)或剥离内层VLAN标签(指定strip c-vid 参数)。
配置Nest规则时,请注意如下限制:
·              以太网服务实例所在端口需要加入本命令指定的外层VLAN。
不能通过重复执行本命令修改出方向报文的处理规则。如需修改,请先通过undo rewrite outbound tag命令删除出方向报文的处理规则,再执行rewrite outbound tag命令。
# 在二层以太网接口Ten-GigabitEthernet1/0/1的服务实例1上配置报文匹配规则和处理规则如下:对外层VLAN标签为10的入方向报文,将外层标签映射为VLAN标签100,并对该服务实例上的出方向报文剥离其外层标签。
[Sysname-Ten-GigabitEthernet1/0/1-srv1] rewrite outbound tag strip s-vid
selective-flooding mac-addres命令用来配置VSI选择性泛洪的MAC地址。
undo selective-flooding mac-addres命令用来删除VSI的选择性泛洪MAC地址。
selective-flooding mac-addres mac-addres
undo selective-flooding mac-addres mac-addres
不存在VSI选择性泛洪MAC地址。
VSI视图
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
通过flooding disable命令禁止通过VXLAN隧道向远端站点泛洪后,为了将某些单播或组播MAC地址的数据帧泛洪到远端站点以保证某些业务的流量在站点间互通,可以配置选择性泛洪的MAC地址。当数据帧的目的MAC地址匹配选择性泛洪的MAC地址时,该数据帧可以泛洪到远端站点。
# 在VSI vsi1下配置选择性泛洪的MAC地址为000f-e201-0101。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
·              flooding disable
service-instance命令用来创建以太网服务实例,并进入以太网服务实例视图。如果指定的以太网服务实例已经存在,则直接进入以太网服务实例视图。
undo service-instance命令用来删除指定的以太网服务实例。
undo service-instance instance-id
不存在以太网服务实例。
二层以太网接口视图
二层聚合接口视图
instance-id:以太网服务实例的编号,取值范围为1~4096。
# 在二层以太网接口Ten-GigabitEthernet1/0/1上创建以太网服务实例1,并进入以太网服务实例1的视图。
1.1.30  shutdown
shutdown命令用来关闭VSI。
undo shutdown命令用来开启VSI。
shutdown
VSI处于开启状态。
VSI视图
关闭VSI后,该VSI将不能提供二层交换服务。
关闭VSI功能通常用于暂时禁用二层交换服务,但还需要再次启用该服务的场景。关闭VSI后,该VSI所有已存在的配置保持不变。在关闭状态下还可以对VSI进行配置。VSI再次被开启后,基于最新的配置提供二层交换服务。
# 关闭名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
·              display l2vpn vsi
statistics enable命令用来开启以太网服务实例的报文统计功能。
undo statistics enable命令用来关闭以太网服务实例的报文统计功能。
statistics enable
以太网服务实例的报文统计功能处于关闭状态。
以太网服务实例视图
只有为以太网服务实例配置了报文匹配方式并绑定了VSI实例,报文统计功能才会生效。如果在报文统计过程中修改报文匹配方式或绑定的VSI实例,则报文统计重新开始。
# 开启接口Ten-GigabitEthernet1/0/1上以太网服务实例200的报文统计功能。
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] statistics enable
statistics enable命令用来开启VSI的报文统计功能。
undo statistics enable命令用来关闭VSI的报文统计功能。
statistics enable
VSI的报文统计功能处于关闭状态。
VSI视图
# 开启名为vsi1的VSI的报文统计功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
·              display l2vpn vsi verbose
·              reset l2vpn statistics vsi
1.1.33  tunnel
tunnel命令用来配置VXLAN与VXLAN隧道关联。
undo tunnel命令用来取消VXLAN与指定隧道的关联。
tunnel { tunnel-number [ backup-tunnel tunnel-number | relay-agent ipoe ] | all }
undo tunnel { tunnel-number | all }
VXLAN未关联VXLAN隧道。
VXLAN视图
tunnel-number:关联指定的VXLAN隧道。tunnel-number为隧道接口的编号,取值范围为1~4096。指定的隧道必须是VXLAN模式的隧道。
backup-tunnel tunnel-number:指定备用隧道。tunnel-number为隧道接口的编号,取值范围为1~4095。指定的隧道必须是VXLAN模式的隧道。
relay-agent:开启隧道的代理透传功能,即该隧道用来透传IPoE报文。如果未指定本参数,则表示关闭隧道的代理透传功能。
ipoe:开启IPoE报文的代理透传功能。
all:关联所有VXLAN隧道。
在VXLAN组网中,用户可以手工将VXLAN与VXLAN隧道关联。采用单播路由泛洪方式时,如果VTEP接收到某个VXLAN的泛洪流量,则将在与该VXLAN关联的所有VXLAN隧道上发送该流量,以便将流量转发给所有的远端VTEP。
一个VXLAN可以关联多条VXLAN隧道;一条VXLAN隧道可以关联多个VXLAN。
执行本命令时,可以同时指定与VXLAN关联的主用VXLAN隧道和备用VXLAN隧道。备用VXLAN隧道为主用VXLAN隧道提供保护。当主用VXLAN隧道down时,VXLAN将启用备用VXLAN隧道。
如果关联VXLAN与VXLAN隧道时,在该隧道上开启了IPoE报文的代理透传功能,则从VXLAN内接收到的IPoE报文均通过该隧道转发给远端VTEP。隧道的代理透传功能通常应用在转发控制分离组网中:在DP上为DP与CP之间的VXLAN隧道开启代理透传功能,以便将控制流量(IPoE报文)发送给CP。
通过tunnel tunnel-number命令关联的VXLAN隧道,不能通过undo tunnel all命令取消该关联;反之,通过tunnel all命令关联所有VXLAN隧道后,不能通过undo tunnel tunnel-number命令取消关联其中的一条VXLAN隧道,只能执行undo tunnel all命令同时取消关联所有的VXLAN隧道。
通常情况下,不建议使用tunnel all命令。
# 配置VXLAN隧道Tunnel1和Tunnel2与VXLAN 10000关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
·              display vxlan tunnel
tunnel bfd enable命令用来开启隧道的BFD检测功能。
undo tunnel bfd enable命令用来关闭隧道的BFD检测功能。
tunnel bfd enable destination-mac mac-address
隧道的BFD检测功能处于关闭状态。
VXLAN模式Tunnel接口视图
destination-mac mac-address:指定BFD报文的目的MAC地址为VXLAN隧道对端VTEP的桥MAC地址。mac-address为BFD报文的目的MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
隧道的BFD检测功能用来避免VTEP设备无法感知或无法及时感知隧道的故障,导致报文转发失败。隧道两端的VTEP设备上均需要开启该功能。VTEP设备周期性地通过VXLAN隧道向配置的目的MAC地址发送单跳BFD控制报文。如果在5秒内未接收到对端发送的BFD控制报文,则将隧道状态置为Defect,隧道接口状态仍为Up。VXLAN隧道故障排除后隧道状态将自动恢复为Up。
执行本命令的同时,还需要在系统视图下执行reserved vxlan命令配置保留VXLAN。否则,BFD会话无法up。
# 开启VXLAN隧道Tunnel9的BFD检测功能,并指定BFD报文的目的MAC地址为1-1-1。
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address命令用来配置VXLAN隧道的全局源地址。
undo tunnel global source-address命令用来恢复缺省情况。
tunnel global source-address ip-address
未配置VXLAN隧道的全局源地址。
ip-address:隧道的全局源IP地址。
目前仅VXLAN隧道支持全局源地址,其它类型的隧道(包括VXLAN-DCI隧道)不支持全局源地址。
如果隧道下未配置源地址或源接口,则隧道会使用全局源地址作为隧道的源地址。
采用OVSDB对VTEP设备进行部署和控制时,用户不能在VXLAN隧道的Tunnel接口下手工指定源地址,只能通过本命令指定全局源地址,否则会影响控制器对VTEP设备的管理。
# 配置VXLAN隧道的全局源地址为1.1.1.1。
[Sysname] tunnel global source-address 1.1.1.1
1.1.36  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
不存在VSI。
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
VSI是VTEP上为一个VXLAN提供二层交换服务的虚拟交换实例。VSI可以看做是VTEP上的一台基于VXLAN进行二层转发的虚拟交换机,它具有传统以太网交换机的所有功能,包括源MAC地址学习、MAC地址老化、泛洪等。VSI与VXLAN一一对应。
# 创建名为vxlan10的VSI,并进入VSI视图。
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
·              display l2vpn vsi
1.1.37  vxlan
vxlan命令用来创建VXLAN,并进入VXLAN视图。如果指定的VXLAN已经存在,则直接进入VXLAN视图。
undo vxlan命令用来恢复缺省情况。
vxlan vxlan-id
undo vxlan
不存在VXLAN。
VSI视图
vxlan-id:VXLAN ID,取值范围为0~16777215。
在一个VSI下只能创建一个VXLAN。不同VSI下创建的VXLAN,其VXLAN ID不能相同。
# 在名称为vpna的VSI下创建编号为10000的VXLAN,并进入VXLAN视图。
[Sysname] vsi vpna
·              vsi
vxlan invalid-vlan-tag discard命令用来配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
undo vxlan invalid-vlan-tag discard命令用来恢复缺省情况。
不会检查VXLAN报文内层封装的以太网数据帧是否携带VLAN tag。
远端VTEP上通过xconnect vsi命令的access-mode参数配置接入模式为ethernet时,VXLAN报文可能携带VLAN tag。这种情况下建议不要在本端VTEP上执行vxlan invalid-vlan-tag discard命令,以免错误地丢弃报文。
# 配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
[Sysname] vxlan invalid-vlan-tag discard
·              xconnect vsi
vxlan local-mac report命令用来开启本地MAC地址的日志记录功能。
undo vxlan local-mac report命令用来关闭本地MAC地址的日志记录功能。
本地MAC地址的日志记录功能处于关闭状态。
开启本地MAC地址的日志记录功能后,VXLAN会立即根据已经学习到的本地MAC地址表项生成日志信息,之后在增加或删除本地MAC地址时也将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 开启本地MAC地址的日志记录功能。
[Sysname] vxlan local-mac report
vxlan tunnel mac-learning disable命令用来关闭远端MAC地址自动学习功能。
undo vxlan tunnel mac-learning disable命令用来开启远端MAC地址自动学习功能。
远端MAC地址自动学习功能处于开启状态。
如果网络中存在攻击,为了避免学习到错误的远端MAC地址,可以通过本命令手工关闭远端MAC地址自动学习功能。
# 关闭远端MAC地址自动学习功能。
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port命令用来配置VXLAN报文的目的UDP端口号。
undo vxlan udp-port命令用来恢复缺省情况。
vxlan udp-port port-number
undo vxlan udp-port
VXLAN报文的目的UDP端口号为4789。
port-number:VXLAN报文的目的UDP端口号,取值范围为1~65535。建议不要将VXLAN报文的目的UDP端口号配置为知名端口,即1~1023之间的端口。
属于同一个VXLAN的VTEP设备上需要配置相同的UDP端口号。
# 配置VXLAN报文的目的UDP端口号为6666。
[Sysname] vxlan udp-port 6666
vxlan vlan-based命令用来开启VLAN关联VXLAN功能。
undo vxlan vlan-based命令用来关闭VLAN关联VXLAN功能。
vxlan vlan-based
VLAN关联VXLAN功能处于关闭状态。
可以通过如下两种方式将指定VLAN的数据帧映射到特定VXLAN:
·              配置以太网服务实例关联VSI:在以太网服务实例下配置报文匹配规则匹配指定VLAN的数据帧后,将该以太网服务实例与VSI关联,可以实现将接口上收到的指定VLAN的数据帧映射到VSI对应的VXLAN。
·              配置VLAN关联VXLAN:执行本命令开启VLAN关联VXLAN功能,并在VLAN视图下执行vxlan vni命令配置与该VLAN关联的VXLAN后,如果存在属于该VLAN的接口,则自动在该接口上创建编号为当前VLAN ID、匹配外层VLAN tag为当前VLAN ID的以太网服务实例,并将该以太网服务实例与指定VXLAN对应的VSI关联。
上述两种方式不能同时配置。
# 开启VLAN关联VXLAN功能。
1.1.43  vxlan vni
vxlan vni命令用来配置VLAN与指定的VXLAN关联。
undo vxlan vni命令用来取消VLAN与VXLAN关联。
vxlan vni vxlan-id
undo vxlan vni
未指定与VLAN关联的VXLAN。
VLAN视图
vxlan-id:与VLAN关联的VXLAN ID,取值范围为0~16777215。
配置本命令前,需要先执行vxlan vlan-based命令开启VLAN关联VXLAN功能。
不能通过本命令配置VLAN 1与VXLAN关联。
本命令中指定的VXLAN ID不能为EVPN组网中的L3VNI。
本命令中指定的VXLAN ID可以不存在。在用户创建该VXLAN时,会自动创建AC,并将AC与VXLAN关联。
# 配置VLAN 10关联VXLAN 100。
[Sysname] vlan 10
·              vxlan vlan-based
1.1.44  xconnect vsi
xconnect vsi命令用来将AC与VSI关联。
undo xconnect vsi命令用来恢复缺省情况。
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
AC未关联VSI。
以太网服务实例视图
access-mode:指定接入模式。以太网服务实例的接入模式缺省为VLAN。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
track track-entry-number&<1-3>:配置AC与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
某个接口的以太网服务实例视图下执行本命令后,从该接口接收到的、符合以太网服务实例报文匹配规则的报文,将通过查找关联VSI的MAC地址表进行转发。
在以太网服务实例下配置该命令前,必须先配置encapsulation命令。
接入模式分为以下两种:
·              VLAN接入模式
¡  如果以太网服务实例上的匹配规则为encapsulation untagged,则该模式下,VTEP从本地站点接收到不携带VLAN tag的数据帧后,转发该数据帧;VTEP发送以太网帧到本地站点时,不会为其添加VLAN Tag。
¡  如果以太网服务实例上配置了其他匹配规则,则在该模式下,从本地站点接收到的和发送给本地站点的以太网帧必须带有VLAN Tag。
-      VTEP从本地站点接收到以太网帧后,删除该帧的所有VLAN Tag,再转发该数据帧;
-      VTEP发送以太网帧到本地站点时,为其添加本地站点的VLAN Tag。
¡  采用VLAN接入模式时,以太网服务实例上的匹配规则不能为encapsulation default
¡  采用该模式时,VTEP不会传递VLAN Tag信息,不同站点可以独立地规划自己的VLAN,不同站点的不同VLAN之间可以互通。
·              Ethernet接入模式
¡  在该模式下,从本地站点接收到的和发送给本地站点的以太网帧可以携带VLAN Tag,也可以不携带VLAN Tag。
-      VTEP从本地站点接收到以太网帧后,保持该帧的VLAN Tag信息不变,转发该数据帧;
-      VTEP发送以太网帧到本地站点时,不会为其添加VLAN Tag。
¡  采用该模式时,VTEP会在不同站点间传递VLAN Tag信息,不同站点的VLAN需要统一规划,否则无法互通。
# 接口Ten-GigabitEthernet1/0/1下采用以太网服务实例200来匹配外层VLAN为200的报文,将该以太网服务实例与名为vpn1的VSI关联。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] xconnect vsi vpn1
·              encapsulation
·              vsi
1.2  VXLAN IP网关配置命令
arp distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态ARP表项同步功能。
undo arp distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态ARP表项同步功能。
分布式网关的动态ARP表项同步功能处于关闭状态。
分布式VXLAN IP网关上开启本地代理ARP功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的ARP报文转发给其他网关,只有本地网关能够学习到ARP报文发送者的ARP表项。如果希望所有网关都能学习到该ARP表项,需要开启分布式网关的动态ARP表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器或EVPN等在彼此之间同步ARP表项,此时无需开启本功能。
# 开启分布式网关的动态ARP表项同步功能。
[Sysname] arp distributed-gateway dynamic-entry synchronize
·              distributed-gateway local
·              local-proxy-arp enable(三层技术-IP业务命令参考/代理ARP)
1.2.2  arp send-rate
arp send-rate命令用来开启VSI虚接口的ARP报文发送限速功能。
undo arp send-rate命令用来关闭VSI虚接口的ARP报文发送限速功能。
arp send-rate pps
undo arp send-rate
VSI虚接口的ARP报文发送限速功能处于关闭状态。
VSI虚接口视图
pps:ARP报文发送限速速率,取值范围为1~500,单位为包每秒(pps)。
开启VSI虚接口的ARP报文发送限速功能后,如果VSI虚接口的ARP报文发送速率超过限制的值,则后续待发送的ARP报文将被丢弃,直到接口的ARP发送速率低于限速速率。
虚拟机的报文处理能力较弱,通过本配置可以控制VTEP发往虚拟机的ARP报文速率,以免影响虚拟机工作。
# 配置VSI虚接口1的ARP报文发送限速为50pps。
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
1.2.3  default
default命令用来恢复接口的缺省配置。
default
VSI虚接口视图
# 将接口VSI-interface100恢复为缺省配置。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
1.2.4  description
description命令用来配置接口的描述信息。
接口的描述信息为“接口名 Interface”,例如:Vsi-interface100 Interface。
VSI虚接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置接口VSI-interface100的描述信息为“gateway for VXLAN 10”。
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface命令用来显示VSI虚接口的相关信息。
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。如果不指定vsi-interface,则显示设备支持的所有接口的相关信息;如果指定vsi-interface,不指定vsi-interface-id,则显示所有VSI虚接口的信息。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则不会根据接口物理状态来过滤显示信息。
# 显示接口VSI-interface100的相关信息。
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
表1-11 display interface vsi-interface命令显示信息描述表
Vsi-interface100
Current state
接口的物理状态和管理状态,取值包括:
·          Administratively DOWN:表示该接口已经通过shutdown命令被关闭,即管理状态为关闭
·          DOWN:该接口的管理状态为开启,但物理状态为关闭
·          UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·          UP:表示该接口的链路层协议状态为开启
·          UP(spoofing):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
·          DOWN:表示该接口的链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
Internet address
接口的主IP地址
IP报文发送帧格式
hardware address
硬件地址
IPv6报文发送帧格式
Physical
接口的物理类型,取值为Unknown
baudrate
接口的波特率,单位为kbps
最近一次清除接口下的统计信息的时间。目前设备不支持清除接口下的统计信息
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数,总计输出的字节,总计丢弃的输出报文数
# 显示所有VSI虚接口的概要信息。
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# 显示接口VSI-interface100的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface vsi-interface 100 brief description
Brief information on interfaces in route mode:Brief information of interface(s) under route mode:
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# 显示当前状态为down的接口的信息以及DOWN的原因。
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
表1-12 display interface vsi-interface brief命令显示信息描述表
·          如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·          如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值包括:
·          UP:表示本链路物理上是连通的
·          DOWN:表示本链路物理上是不通的
·          ADM:表示本链路被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·          Stby:表示该接口是一个处于Standby状态的备份接口
Protocol
接口的链路层协议状态,取值包括:
·          UP (s):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·          Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·          Not connected:表示没有VSI关联该接口,或者关联该接口的VSI内没有AC或VXLAN隧道
distributed-gateway local命令用来配置VSI虚接口为分布式网关接口。
undo distributed-gateway local命令用来恢复缺省情况。
VSI虚接口不是分布式网关接口。
VSI虚接口视图
在分布式VXLAN IP网关组网中,多个网关上同一VXLAN的VSI虚接口需要配置相同的IP地址。为了避免IP地址冲突,需要在VSI虚接口上执行本命令,以防止VSI虚接口上报地址冲突,导致VSI虚接口不可用。
# 配置接口Vsi-interface100为分布式网关接口。
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet命令用来配置VSI所属的子网网段。
undo gateway subnet命令用来删除VSI所属的子网网段。
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
未指定VSI所属的子网网段。
VSI视图
ipv4-address:IPv4子网网段地址,为点分十进制格式。
wildcard-mask:IPv4地址掩码的反码,即将IPv4地址的掩码取反(0变1,1变0)。例如:子网掩码255.0.0.0的反码为0.255.255.255。其中,反码中的“1”表示忽略IPv4地址中对应的位,“0”表示必须保留此位。
ipv6-address prefix-length:IPv6地址及前缀长度。prefix-length为IPv6前缀长度,取值范围为1~128。
多个VXLAN共用一个VSI虚接口时,可以在VSI视图下通过本命令指定VSI所属的子网网段,通过子网网段判断报文所属的VSI,并在该VSI内转发报文。
在VSI视图下配置子网网段前,必须先为该VSI指定网关接口。取消为VSI指定网关接口时,会自动删除为该VSI指定的子网网段。
一个VSI视图下最多可以配置8个子网网段,包括IPv4子网和IPv6子网。
不能为指定了相同网关接口的不同VSI配置相同的子网网段。
# 配置名称为vxlan的VSI所属的子网网段为100.0.10.0/24。
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface命令用来为VSI指定网关接口。
undo gateway vsi-interface命令用来恢复缺省情况。
gateway vsi-interface vsi-interface-id
未指定VSI的网关接口。
VSI视图
vsi-interface-id:VSI网关虚接口的编号,取值范围为0~4094。
本命令中指定的VSI网关虚接口必须已经通过interface vsi-interface命令创建。如果将VSI虚接口指定为网关接口后,执行undo interface vsi-interface命令删除该VSI虚接口,则指定网关接口的配置也将删除。
一个VSI只能指定一个网关接口。
不同的VSI可以指定相同的网关接口。
# 为VSI指定网关接口为Vsi-interface100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
·              interface vsi-interface
interface vsi-interface命令用来创建VSI虚接口,并进入VSI虚接口视图。如果指定的VSI虚接口已经存在,则直接进入VSI虚接口视图。
undo interface vsi-interface命令用来删除指定的VSI虚接口。
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
不存在VSI虚接口。
vsi-interface-id:VSI虚接口的编号,取值范围为0~4094。
如果通过gateway vsi-interface命令将VSI虚接口指定为网关接口后,执行undo interface vsi-interface命令删除该VSI虚接口,则指定网关接口的配置也将删除。
# 创建VSI虚接口100,并进入VSI虚接口视图。
·              gateway vsi-interface
ipv6 nd distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态IPv6 ND表项同步功能。
undo ipv6 nd distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态IPv6 ND表项同步功能。
分布式网关的动态IPv6 ND表项同步功能处于关闭状态。
分布式VXLAN IP网关上开启本地ND代理功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的IPv6 ND报文转发给其他网关,只有本地网关能够学习到IPv6 ND报文发送者的ND表项。如果希望所有网关都能学习到该ND表项,需要开启分布式网关的动态IPv6 ND表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器或EVPN等在彼此之间同步IPv6 ND表项,此时无需开启本功能。
# 开启分布式网关的动态IPv6 ND表项同步功能。
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
·              local-proxy-nd enable(三层技术-IP业务命令参考/IPv6基础)
1.2.11  mac-address
mac-address命令用来配置VSI虚接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
VSI虚接口的MAC地址为桥MAC地址+1。
VSI虚接口视图
mac-address:MAC地址,形式为H-H-H。
# 配置VSI虚接口100的MAC地址为0001-0001-0001。
[Sysname-Vsi-interface100] mac-address 1-1-1
1.2.12  mtu
mtu命令用来配置接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
VSI虚接口的MTU值为1444字节。
VSI虚接口视图
# 配置接口VSI-interface100的MTU值为1430字节。
[Sysname-Vsi-interface100] mtu 1430
1.2.13  shutdown
shutdown命令用来关闭VSI虚接口。
undo shutdown命令用来开启VSI虚接口。
shutdown
VSI虚接口均处于开启状态。
VSI虚接口视图
# 关闭接口VSI-interface100。
[Sysname-Vsi-interface100] shutdown
vtep group member local命令用来将本设备加入VXLAN IP网关保护组,并配置本设备的成员地址。
undo vtep group member local命令用来取消本设备加入指定的VXLAN IP网关保护组。
vtep group group-ip member local member-ip
undo vtep group group-ip member local
设备未加入VXLAN IP网关保护组。
group-ip:VXLAN IP网关保护组的VTEP IP地址,该地址必须是本设备上已经存在的地址。
member-ip:本设备在VXLAN IP网关保护组内的成员地址,该地址必须是设备上已经配置的地址。
成员地址不能和保护组的VTEP IP相同;同一个保护组中不同成员的成员地址也不能相同。
# 配置本设备加入VXLAN IP保护组,保护组的VTEP IP地址是1.1.1.1,本设备的成员地址为2.2.2.2。
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
·              vtep group member remote
vtep group member remote命令用来配置VXLAN IP网关保护组的成员地址列表。
undo vtep group member remote命令用来删除指定VXLAN IP网关保护组的成员地址列表。
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
未配置VXLAN IP网关保护组的成员地址列表。
group-ip:VXLAN IP网关保护组的VTEP IP地址。
member-ip&<1-8>:VXLAN IP网关保护组成员IP地址列表。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
# 配置VXLAN IP网关保护组1.1.1.1包含的成员设备为2.2.2.2、3.3.3.3和4.4.4.4。
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
·              vtep group member local
vxlan tunnel arp-learning disable命令用来关闭远端ARP自动学习功能。
undo vxlan tunnel arp-learning disable命令用来开启远端ARP自动学习功能。
远端ARP自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ARP信息,即远端ARP信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel arp-learning disable命令暂时关闭远端ARP自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel arp-learning disable命令开启远端ARP自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel arp-learning disable命令。
# 关闭远端ARP自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable命令用来关闭远端ND自动学习功能。
undo vxlan tunnel nd-learning disable命令用来开启远端ND自动学习功能。
远端ND自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ND信息,即远端ND信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel nd-learning disable命令暂时关闭远端ND自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel nd-learning disable命令开启远端ND自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel nd-learning disable命令。
# 关闭远端ND自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
1.3  OVSDB-VTEP配置命令
ovsdb server bootstrap ca-certificate命令用来指定与控制器进行SSL通信时使用的CA证书文件。
undo ovsdb server bootstrap ca-certificate命令用来恢复缺省情况。
ovsdb server bootstrap ca-certificate ca-filename
与控制器进行SSL通信时使用PKI域中的CA证书文件。
ca-filename:表示与控制器进行SSL通信时使用的CA证书文件名称,不区分大小写,文件名称中不允许出现slot字样。只允许使用主用主控板的CA证书文件。
通过本命令指定与控制器进行SSL通信使用的CA证书文件时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
本命令指定的只能是主用主控板中的CA证书文件。如果指定的文件存在,直接使用。否则,使用开启OVSDB服务器时通过SSL连接获取的自签名证书,并通过本命令指定证书文件名。
执行本命令后,优先使用本命令指定的CA证书文件,不使用PKI域中的CA证书。
# 指定与控制器进行SSL通信时使用的CA证书文件为ca-new。
[Sysname] ovsdb server bootstrap ca-certificate ca-new
·              ovsdb server enable
·              ovsdb server pki domain
·              ovsdb server pssl
·              ovsdb server ssl
ovsdb server enable命令用来开启OVSDB服务器。
undo ovsdb server enable命令用来关闭OVSDB服务器。
ovsdb server enable
OVSDB服务器处于关闭状态。
开启OVSDB服务器后,OVSDB服务器可以与控制器建立连接,接收控制器通过OVSDB控制协议发送的数据,并保存到本地OVSDB数据库中,从而实现控制器对VTEP设备进行VXLAN相关配置。
为了保证OVSDB服务器能够与控制器建立连接,在开启OVSDB服务器前,必须先配置至少一条与控制器的连接。
# 开启OVSDB服务器。
[Sysname] ovsdb server enable
ovsdb server pki domain命令用来指定与控制器进行SSL通信时使用的PKI域。
undo ovsdb bootstrap server pki domain命令用来恢复缺省情况。
ovsdb server pki domain domain-name
undo ovsdb server pki domain
未指定与控制器进行SSL通信时使用的PKI域。
domain-name:表示与控制器进行SSL通信时使用的PKI域名称,为1~31个字符的字符串,区分大小写。指定的PKI域必须存在,并且PKI域中包含完整的证书和密钥。PKI域的详细介绍,请参见“安全配置指导”中的“PKI”。
与控制器进行SSL通信时需通过本命令指定PKI域。
通过本命令指定与控制器进行SSL通信时使用的PKI域时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
# 指定与控制器进行SSL通信时使用的PKI域为ovsdb_test。
[Sysname] ovsdb server pki domain ovsdb_test
·              ovsdb server bootstrap ca-certificate
·              ovsdb server pssl
·              ovsdb server ssl
ovsdb server pssl命令用来配置与控制器建立被动SSL连接。
undo ovsdb server pssl命令用来恢复缺省情况。
ovsdb server pssl [ port port-number ]
不会与控制器建立被动SSL连接。
port port-number:指定与控制器建立SSL连接的端口号,OVSDB服务器监听该端口上的SSL连接请求。port-number取值范围为1~65535。如果不指定本参数,则监听6640端口。
配置与控制器建立被动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立被动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的SSL连接端口号。多次执行本命令,最后一次执行的命令生效。
# 配置与控制器建立被动SSL连接,监听端口号采用默认端口号。
[Sysname] ovsdb server pssl
·              ovsdb server ssl
ovsdb server ptcp命令用来配置与控制器建立被动TCP连接。
undo ovsdb server ptcp命令用来恢复缺省情况。
ovsdb server ptcp [ port port-number ]
不会与控制器建立被动TCP连接。
port port-number:指定与控制器建立TCP连接的监听端口号,取值范围为1~65535,如果不指定本参数,则监听6640端口。
通过本命令配置与控制器建立被动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的TCP连接端口号。多次执行本命令,最后一次执行的命令生效。
# 配置与控制器建立被动TCP连接,监听端口号采用默认端口号。
[Sysname] ovsdb server ptcp
·              ovsdb server tcp
ovsdb server ssl命令用来配置与控制器建立主动SSL连接。
undo ovsdb server ssl命令用来删除指定的主动SSL连接。
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
不会与控制器建立主动SSL连接。
ssl ip-address:指定SSL连接的目的IP地址。
port port-number:指定SSL连接的目的端口号,取值范围为1~65535。
配置与控制器建立主动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立主动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的SSL主动连接。
# 配置与控制器建立主动SSL连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
·              ovsdb server pssl
ovsdb server tcp命令用来配置与控制器建立主动TCP连接。
undo ovsdb server tcp命令用来删除指定的主动TCP连接。
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
不会与控制器建立主动TCP连接。
ip ip-address:指定TCP连接的目的IP地址。
port port-number:指定TCP连接的目的端口号。
通过本命令配置与控制器建立主动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的TCP主动连接。
# 配置与控制器建立主动TCP连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
·              ovsdb server ptcp
vtep access port命令用来指定当前接口为用户侧的接入端口。
undo vtep access port命令用来恢复缺省情况。
vtep access port
当前接口不是用户侧的接入端口。
二层以太网接口视图
二层聚合接口视图
只有将接口配置为用户侧的接入端口后,控制器上才能够显示该端口并对其进行控制。
# 指定二层以太网接口Ten-GigabitEthernet1/0/1为用户侧的接入端口。
[Sysname-Ten-GigabitEthernet1/0/1] vtep access port
1.3.9  vtep enable
vtep enable命令用来开启OVSDB VTEP服务。
undo vtep enabl命令用来关闭OVSDB VTEP服务。
vtep enable
undo vtep enable
OVSDB VTEP服务处于关闭状态。
# 开启设备的OVSDB VTEP服务。
[Sysname] vtep enable
