07-NQA命令
本章节下载: 07-NQA命令 (801.43 KB)
1.1.15 display nqa reaction counters
1.1.18 display nqa twamp-light client
1.1.19 display nqa twamp-light client statistics
1.1.20 display nqa twamp-light client test-session reaction counters
1.1.21 expect { data | hex-data }
1.1.22 expect { failed-data | hex-failed-data }
1.1.33 history-record keep-time
1.1.47 nqa agent udp-jitter high-performance enable
1.1.53 operation (FTP operation view)
1.1.54 operation (HTTP operation view)
1.1.55 operation (HTTPS template view)
1.1.67 reaction checked-element { jitter-ds | jitter-sd }
1.1.68 reaction checked-element { owd-ds | owd-sd }
1.1.69 reaction checked-element icpif
1.1.70 reaction checked-element mos
1.1.71 reaction checked-element packet-loss
1.1.72 reaction checked-element probe-duration
1.1.73 reaction checked-element probe-fail (for trap)
1.1.74 reaction checked-element probe-fail (for trigger)
1.1.75 reaction checked-element rtt
1.1.76 reaction checked-element two-way-delay
1.1.77 reaction checked-element two-way-jitter
1.1.78 reaction checked-element two-way-loss
1.1.80 reaction trigger per-probe
1.1.81 reaction trigger probe-fail
1.1.82 reaction trigger probe-pass
1.1.84 reset nqa twamp-light statistics
1.1.87 resource-release { data-fill | hex-data-fill }
1.1.88 reth-member probe enable
1.1.89 route-option bypass-route
1.1.90 source interface (TWAMP Light client-session view)
1.1.97 start (TWAMP-light-sender view)
1.1.101 stop (TWAMP-light-sender view)
1.1.104 test-session (TWAMP-light-client view)
1.1.112 version (HTTP/HTTPS operation view and HTTPS template view)
1.1.113 version (SNMP-DCA template view)
1.2.2 display nqa twamp-light responder
1.2.6 nqa server udp-echo high-performance enable
1.2.7 nqa twamp-light responder
1.2.8 test-session (TWAMP-light-responder view)
advantage-factor命令用来配置用于计算MOS值和ICPIF值的补偿因子。
undo advantage-factor命令用来恢复缺省情况。
advantage-factor factor
补偿因子取值为0。
Voice测试类型视图
context-admin
factor:用于计算MOS值和ICPIF值的补偿因子,取值范围为0~20。
用户对语音质量的评价具有一定的主观性,不同用户对语音质量的容忍程度不同,因此,衡量语音质量时,需要考虑用户的主观因素。对语音质量容忍程度较强的用户,可以通过advantage-factor命令配置补偿因子,在计算ICPIF值时将减去该补偿因子,修正ICPIF和MOS值,以便在比较语音质量时综合考虑客观和主观因素。
# 在Voice测试类型下配置计算MOS值和ICPIF值的补偿因子为10。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
agent-type命令用来配置SNMP-DCA测试的SNMP Agent类型。
undo agent-type命令用来恢复缺省情况。
agent-type { net-snmp | user-defined | windows }
undo agent-type
SNMP-DCA测试的SNMP Agent类型为Net-SNMP。
SNMP-DCA类型的NQA模板视图
context-admin
net-snmp:表示SNMP Agent的类型为Net-SNMP。
user-defined:表示SNMP Agent的类型为User-defined。
windows:表示SNMP Agent的类型为Windows。
SNMP-DCA测试用于监测SNMP Agent的状态。设备通常以SNMP Agent的CPU/内存/硬盘的使用率作为参数,和用户配置的阈值、权重计算后得到的结果来判断SNMP Agent的状态。
不同类型的SNMP Agent,其CPU/内存/硬盘使用率MIB节点的OID不同。建议设备上配置的类型和需要监测的SNMP Agent的类型一致。
对于Net-SNMP和Windows类型,开启SNMP-DCA测试后,设备会自动获取SNMP Agent的CPU/内存/硬盘使用率来判断SNMP Agent的状态。用户可通过cpu、memory和disk命令修改相应的阈值和权重,也可以使用oid命令增加关注的节点。
对于User-defined类型,因为设备不能自动获取到SNMP Agent上MIB节点的OID,所以,需要用户使用oid命令配置每个需要关注的MIB节点,包括CPU/内存/硬盘使用率对应的MIB节点。
# 在SNMP-DCA类型的NQA模板视图下配置SNMP-DCA测试的SNMP Agent类型为Windows。
[Sysname] nqa template snmpdca test
[Sysname-nqatplt-snmpdca-test] agent-type windows
· cpu
· disk
· memory
· oid
codec-type命令用来配置语音测试的编码格式。
undo codec-type命令用来恢复缺省情况。
codec-type { g711a | g711u | g729a }
undo codec-type
语音编码格式为G.711 A律。
Voice测试类型视图
context-admin
g711a:G.711 A律语音编码格式。
g711u:G.711 µ律语音编码格式。
g729a:G.729 A律语音编码格式。
# 在Voice测试类型下配置语音测试的编码格式为G.729 A律。
[Sysname-nqa-admin-test-voice] codec-type g729a
community read命令用来配置用于SNMP测试使用的团体名。
undo community read命令用来恢复缺省情况。
community read { cipher | simple } community-name
undo community read
SNMP测试使用的团体名为public。
SNMP测试类型视图
SNMP/SNMP-DCA类型的模板视图
context-admin
cipher:以密文方式配置团体名。
simple:以明文方式配置团体名,该密码将以密文形式存储。
community-name:测试使用的团体名,区分大小写。当以明文形式配置时,团体名为1~32个字符的字符串;当以密文形式配置时,团体名为33~73个字符的字符串。
当被测试的SNMP Agent的版本为SNMPv1或者SNMPv2c时,若SNMP Agent配置了团体名,则SNMP测试组必须配置本命令,且配置的团体名必须与SNMP Agent上已配置的只读或读写权限团体名保持一致,才能通过SNMP Agent的认证,并进行探测。当SNMP Agent的版本为SNMPv3时,由于SNMPv3没有团体名概念,不需要配置团体名,直接进行探测。有关团体名及SNMP认证的具体介绍请参见“网络管理和监控”中的“SNMP”。
# 配置SNMP探测报文使用的团体名称为readaccess。
[Sysname-nqa-admin-test] type snmp
[Sysname-nqa-admin-test-snmp] community read simple readaccess
cpu命令用来配置SNMP-DCA测试的SNMP Agent的CPU的阈值和权重。
undo cpu命令用来恢复缺省情况。
cpu { threshold threshold-value | weight weight-value } *
undo cpu
SNMP-DCA测试的SNMP Agent的CPU阈值为80,权重为3。
SNMP-DCA类型的NQA模板视图
context-admin
threshold threshold-value:阈值,表示CPU使用率可达到的上限。取值范围为0~100,取值为0时表示CPU不作为判断SNMP Agent是否繁忙的参考。不指定该参数时,表示使用缺省值。
weight weight-value:权重,表示CPU在用于计算SNMP Agent状态时应占有的比重。取值范围为0~100,取值为0时表示CPU不参与SNMP Agent状态的计算。不指定该参数时,表示使用缺省值。
本命令仅对Net-SNMP或Windows类型的SNMP Agent生效。
NQA客户端对Net-SNMP或Windows类型的SNMP Agent进行SNMP-DCA测试时,会自动获取SNMP Agent当前的CPU利用率。
# 在SNMP-DCA类型的NQA模板视图下配置测试的SNMP Agent的CPU阈值为90、权重为90。
[Sysname-nqatplt-snmpdca-test] cpu threshold 90 weight 90
· agent-type
data-fill命令用来配置探测报文的填充字符串。
undo data-fill命令用来恢复缺省情况。
data-fill string [ raw ]
undo data-fill
探测报文的填充内容为十六进制00010203040506070809。
ICMP-echo/UDP-echo测试类型视图
Path-jitter/UDP-jitter/Voice测试类型视图
ICMP/TCP/UDP类型的NQA模板视图
TWAMP-light测试的Client-session视图
context-admin
string:探测报文的填充内容,为1~200个字符的字符串,区分大小写。
raw:表示仅使用string来填充探测报文,该参数仅在UDP类型的NQA模板视图下支持。
对于不同的测试类型,填充字符串的情况有所不同:
· 在ICMP-echo测试中,配置的字符串用来填充ICMP Echo消息的数据字段。
· 在UDP-echo测试中,由于UDP报文数据字段的前5个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
· 在UDP-jitter测试中,UDP报文数据字段的前68个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
· 在Voice测试中,UDP报文数据字段的前16个字节具有特定用途,所以只用所配置的字符串填充报文中剩余的字节。
· 在Path-jitter测试中,由于ICMP探测阶段ICMP报文数据字段的前4个字节具有特定用途,所以只用所配置的字符串填充ICMP报文中剩余的字节。
若指定raw参数,表示string参数位置的填充字符串在探测时将被直接发送。由于NQA发送的数据字段存在特殊字节,如果目的端是H3C设备,那么目的端能够直接识别NQA填充后的探测报文,不建议配置该参数;如果目的端不是H3C设备,则无法识别NQA填充后的探测报文,那么必须指定该参数,填充字符串需要是目的端服务器开启的UDP服务类型要求的报文格式。
未指定raw参数时,实际填充的字符与填充数据长度有关:
· 如果探测报文的数据段长度比配置的填充数据长度小,系统在报文封装时以报文的数据段长度为界截取该字符串的前一部分;
· 如果探测报文的数据段长度比配置的填充数据长度大,系统在报文封装时用该字符串进行循环填充,直到填满。
例如,配置填充数据为“abcd”,当探测报文数据段长度为3字节时,则取“abc”作为填充数据;当探测报文数据段长度为6字节时,则使用“adcdab”作为填充数据。
# 在ICMP-echo测试类型下配置探测报文的填充字符串为abcd。
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
# 在TCP类型的NQA模板视图下配置探测报文的填充字符串为abcd。
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] data-fill abcd
data-size命令用来配置探测报文中的填充内容的大小。
undo data-size命令用来恢复缺省情况。
data-size size
undo data-size
缺省情况如表1-1所示。
测试类型 |
编码类型 |
缺省值(字节) |
ICMP-echo |
100 |
UDP-echo |
100 |
UDP-jitter |
100 |
UDP-tracert |
100 |
Path-jitter |
100 |
Voice |
G.711 A律 |
172 |
Voice |
G.711 µ律 |
172 |
Voice |
G.729 A律 |
32 |
TWAMP-light |
142 |
ICMP-echo/UDP-echo 测试类型视图
UDP-tracert测试类型视图
ICMP/UDP类型的NQA模板视图
context-admin
size:探测报文中的填充内容的大小,单位为字节,ICMP-echo、UDP-echo和UDP-tracert测试类型取值范围为20~65507,UDP-jitter和Path-jitter测试类型取值范围为68~65507,Voice测试类型取值范围为16~65507,TWAMP-light测试类型取值范围为44~1518。
对于ICMP-echo和Path-jitter测试,探测报文中填充内容的大小为ICMP Echo消息中数据字段的长度。
对于UDP-echo、UDP-jitter、UDP-tracert和Voice测试,探测报文中填充内容的大小为UDP报文中数据字段的长度。
TWAMP-light测试的探测报文中填充内容的大小不能大于测试链路上所有接口的MTU值。
# 在ICMP-echo测试类型下配置探测报文中的填充内容的大小为80字节。
[Sysname-nqa-admin-test-icmp-echo] data-size 80
# 在ICMP类型的NQA模板视图下配置ICMP-echo探测报文中的填充内容的大小为80字节。
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] data-size 80
description命令用来配置测试组的描述信息,通常用于描述一个测试组的测试类型或测试目的。undo description命令用来恢复缺省情况。
未配置描述信息。
ICMP-echo/UDP-echo/TCP测试类型视图
ARP/DHCP/DLSw/DNS/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
ICMP-jitter/UDP-jitter/Path-jitter/Voice测试类型视图
任意类型的NQA模板视图
context-admin
text:测试组的描述,为1~200个字符的字符串,区分大小写。
# 在ICMP-echo测试类型下配置测试组的描述信息为icmp-probe。
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
# 在ICMP类型的NQA模板视图下配置描述信息为icmp-probe。
[Sysname-nqatplt-icmp-icmptplt] description icmp-probe
destination ip命令用来配置探测报文的目的IPv4地址。
undo destination ip命令用来恢复缺省情况。
destination ip ip-address
undo destination ip
未配置探测报文的目的IPv4地址。
ICMP-echo/TCP/UDP-echo测试类型视图
ARP/DHCP/DLSw/DNS/SNMP测试类型视图
UDP-tracert测试类型视图
ICMP-jitter/Path-jitter/UDP-jitter/Voice测试类型视图
ARP/DNS/ICMP/IMAP/POP3/RADIUS认证探测/RADIUS-ACCOUNT计费探测/SMTP/SNMP/SNMP-DCA/SSL/TCP/TCPHalf Open/UDP/WAP类型的NQA模板视图
context-admin
ip-address:探测报文的目的IPv4地址。
# 在ICMP-echo测试类型下配置探测报文的目的IPv4地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# 在ICMP类型的NQA模板视图下配置探测报文的目的IPv4地址为10.1.1.1。
[Sysname-nqatplt-icmp-icmptplt] destination ip 10.1.1.1
destination ipv6命令用来配置探测报文的目的IPv6地址。
undo destination ipv6命令用来恢复缺省情况。
destination ipv6 ipv6-address
未配置探测报文的目的IPv6地址。
ICMP-echo/TCP/UDP-echo/UDP-jitter测试类型视图
DNS/ICMP/IMAP/POP3/RADIUS认证探测/RADIUS-ACCOUNT计费探测/SMTP/SIP/SNMP/SNMP-DCA/SSL/TCP/TCP Half Open/UDP/WAP类型的NQA模板视图
context-admin
ipv6-address:探测报文的目的IPv6地址,不支持IPv6链路本地地址。
# 在ICMP-echo测试类型下配置探测报文的目的IPv6地址为1::1。
[Sysname-nqa-admin-test-icmp-echo] destination ipv6 1::1
# 在ICMP类型的NQA模板视图下配置探测报文的目的IPv6地址为1::1。
[Sysname-nqatplt-icmp-icmptplt] destination ipv6 1::1
destination port命令用来配置测试操作的目的端口号。
undo destination port命令用来恢复缺省情况。
destination port port-number
对于UDP-tracert测试,目的端口号缺省为33434;对于SNMP测试,目的端口号缺省为161;对于其他类型测试,未配置测试操作的目的端口号。
对于NQA模板,缺省目的端口号分别为:DNS(53)、IMAP(143)、POP3(110)、RADIUS认证探测(1812)、RADIUS-ACCOUNT计费探测(1813)、SIP(5060)、SMTP(25)、SNMP(161)、SNMP-DCA(161)、WAP(9201)、其他类型模板未配置测试操作的目的端口号。
TCP/UDP-echo测试类型视图
SNMP测试类型视图
UDP-tracert测试类型视图
DNS/IMAP/POP3/RADIUS认证探测/RADIUS-ACCOUNT计费探测/SIP/SMTP/SNMP/SNMP-DCA/SSL/TCP/TCP Half Open /UDP/WAP类型的NQA模板视图
context-admin
port-number:测试操作的目的端口号,取值范围为1~65535。
对于TCP Half Open类型的NQA模板,只有在通过port-detect enable命令开启TCP Half Open的端口检测功能的情况下,才需要配置本命令。
# 在UDP-echo测试类型视图下配置测试操作的目的端口号为9000。
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
# 在TCP类型的NQA模板视图下配置测试操作的目的端口号为9000。
[Sysname-nqatplt-tcp-tcptplt] destination port 9000
· port-detect enable
disconnect-mode命令用来设置TCP测试的TCP连接断开方式。
undo disconnect-mode命令用来恢复缺省情况。
disconnect-mode { fin | rst }
TCP测试的TCP连接断开方式为RST。
TCP类型的模板视图
context-admin
fin:TCP测试的TCP连接断开方式为FIN。
rst:TCP测试的TCP连接断开方式为RST。
一次TCP测试包括三次握手建立TCP连接和断开TCP连接,完成该过程表示NQA的TCP测试成功,本命令可以设置断开TCP连接的方式:
· RST:通过发送RST报文,快速释放TCP连接。收到RST报文后,另一端就终止连接,不需要发送任何响应。
· FIN:四次握手断开TCP连接,不支持RST方式情况下可以设置为该方式。被断开的一方收到FIN报文后需要发送ACK。
# 在TCP类型的NQA模板视图下设置TCP测试的TCP连接断开方式为FIN。
[Sysname] nqa template tcp test
[Sysname-nqatplt-tcp-test] disconnect-mode fin
disk命令用来配置SNMP-DCA测试的SNMP Agent硬盘的阈值和权重。
undo disk命令用来恢复缺省情况。
disk { threshold threshold-value | weight weight-value } *
undo disk
SNMP-DCA测试的SNMP Agent硬盘的阈值为90,权重为4。
SNMP-DCA类型的NQA模板视图
context-admin
threshold threshold-value:阈值,表示硬盘使用率可达到的上限。取值范围为0~100,取值为0时表示硬盘不作为判断SNMP Agent是否繁忙的参考。不指定该参数时,表示使用缺省值。
weight weight-value:权重,表示硬盘在用于计算SNMP Agent状态时应占有的比重,取值范围为0~100,取值为0时表示硬盘不参与SNMP Agent状态的计算。不指定该参数时,表示使用缺省值。
NQA客户端对Net-SNMP或Windows类型的SNMP Agent进行SNMP-DCA测试时,会自动获取SNMP Agent当前的硬盘使用率
# 在SNMP-DCA类型的NQA模板视图下配置测试的SNMP Agent硬盘阈值为90、权重为90。
[Sysname-nqatplt-snmpdca-test] disk threshold 90 weight 90
· agent-type
display nqa history命令用来显示NQA测试组的历史记录。
display nqa history [ admin-name operation-tag ]
context-admin
context-operator
admin-name:创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
operation-tag:测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
display nqa history命令的显示信息无法反映ICMP-jitter、Path-jitter、UDP-jitter和Voice测试的结果。如果想了解ICMP-jitter、Path-jitter、UDP-jitter和Voice测试的结果,建议通过display nqa result命令查看最近一次NQA测试的结果,或通过display nqa statistics命令查看NQA测试的统计信息。
不指定任何参数,则表示显示所有测试组的历史记录。
# 显示管理员名称为administrator、测试类型标签为tracert的UDP-tracert测试项的历史记录。
<Sysname> display nqa history administrator tracert
NQA entry (admin administrator, tag tracert) history records:
Index TTL Response Hop IP Status Time
1 2 328 4.1.1.1 Succeeded 2013-09-09 14:46:06.2
1 2 328 4.1.1.1 Succeeded 2013-09-09 14:46:05.2
1 2 328 4.1.1.1 Succeeded 2013-09-09 14:46:04.2
1 1 328 3.1.1.2 Succeeded 2013-09-09 14:46:03.2
1 1 328 3.1.1.1 Succeeded 2013-09-09 14:46:02.2
1 1 328 3.1.1.1 Succeeded 2013-09-09 14:46:01.2
# 查看管理员名称为administrator、测试操作标签为test的NQA测试组的历史记录。
<Sysname> display nqa history administrator test
NQA entry (admin administrator, tag test) history records:
Index Response Status Time
10 329 Succeeded 2011-04-29 20:54:26.5
9 344 Succeeded 2011-04-29 20:54:26.2
8 328 Succeeded 2011-04-29 20:54:25.8
7 328 Succeeded 2011-04-29 20:54:25.5
6 328 Succeeded 2011-04-29 20:54:25.1
5 328 Succeeded 2011-04-29 20:54:24.8
4 328 Succeeded 2011-04-29 20:54:24.5
3 328 Succeeded 2011-04-29 20:54:24.1
2 328 Succeeded 2011-04-29 20:54:23.8
1 328 Succeeded 2011-04-29 20:54:23.4
表1-2 display nqa history命令显示信息描述表
Index |
历史记录的编号,一次UDP-tracert测试中的所有记录此编号一致 |
TTL |
本次探测发送的探测报文的TTL值。如果设备配置了路由旁路功能,则TTL显示值与init-ttl命令配置相关,实际发送的TTL值固定为1 |
Response |
测试成功时,为探测报文的往返时延;如果测试超时,则为超时时间;不能完成测试时,则为0。单位为毫秒 |
Hop IP |
回复应答的节点IP地址 |
Status |
测试结果的状态值,具体如下: · Succeeded:测试成功,接收到响应报文 · Unknown error:未知错误导致NQA测试失败(如果配置了NQA与Track联动,则该状态会触发Track状态切换) · Internal error:内部错误导致NQA测试失败(如果配置了NQA与Track联动,则该状态不会触发Track状态切换) · Timeout:请求超时导致NQA测试失败(如果配置了NQA与Track联动,则该状态会触发Track状态切换) |
Time |
测试完成时间 |
display nqa reaction counters命令用来显示阈值告警组的当前监测结果。
display nqa reaction counters [ admin-name operation-tag [ item-number ] ]
context-admin
context-operator
item-number:显示指定阈值告警组的当前监测结果。如果不指定该参数,将显示所有阈值告警组的当前监测结果。item-number为阈值告警组的编号,取值范围为1~10。
如果NQA阈值告警组的阈值类型为平均值,或监测对象为Voice测试的ICPIF或MOS值,则显示的监测结果为无效值。
测试结束后,不会清除监测结果,即测试组启动后,监测结果会不断累加。
不指定任何参数,则表示显示所有测试组中所有阈值告警组的当前监测结果。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-echo测试组的所有阈值告警组的当前监测结果。
<Sysname> display nqa reaction counters admin test
NQA entry (admin admin, tag test) reaction counters:
Index Checked Element Threshold Type Checked Num Over-threshold Num
1 probe-duration accumulate 12 4
2 probe-duration average - -
3 probe-duration consecutive 160 56
4 probe-fail accumulate 12 0
5 probe-fail consecutive 162 2
表1-3 display nqa reaction counters命令显示信息描述
Index |
阈值告警组的编号 |
Checked Element |
Threshold Type |
阈值类型 |
Checked Num |
已监测的样本个数 |
Over-threshold Num |
超出阈值的样本个数 |
表1-4 display nqa reaction counters命令显示字段取值描述(ARP/DHCP/DLSw/DNS/FTP/HTTP/ICMP-echo/SNMP/TCP/UDP-echo测试类型)
监测对象 |
阈值类型 |
监测的样本范围 |
Checked Num取值 |
Over-threshold Num取值 |
probe-duration |
accumulate |
启动NQA测试组后进行的探测 |
启动NQA测试组后已完成的探测次数 |
启动NQA测试组后累计的探测持续时间不在阈值范围内的探测次数 |
average |
consecutive |
启动NQA测试组后进行的探测 |
启动NQA测试组后已完成的探测次数 |
启动NQA测试组后连续的探测持续时间不在阈值范围内的探测次数 |
probe-fail |
accumulate |
启动NQA测试组后进行的探测 |
启动NQA测试组后已完成的探测次数 |
启动NQA测试组后累计的探测失败次数 |
consecutive |
启动NQA测试组后进行的探测 |
启动NQA测试组后已完成的探测次数 |
启动NQA测试组后连续的探测失败次数 |
表1-5 display nqa reaction counters命令显示字段取值描述(ICMP-jitter/UDP-jitter/Voice测试类型)
监测对象 |
阈值类型 |
监测的样本范围 |
Checked Num取值 |
RTT |
accumulate |
启动NQA测试组后发送的报文 |
启动NQA测试组后已发送的报文个数 |
启动NQA测试组后累计的往返时间不在阈值范围内的报文个数 |
average |
jitter-DS/jitter-SD |
accumulate |
启动NQA测试组后发送的报文 |
启动NQA测试组后已发送的报文个数 |
启动NQA测试组后累计的单向抖动时间不在阈值范围内的报文个数 |
average |
OWD-DS/OWD-SD |
启动NQA测试组后发送的报文 |
启动NQA测试组后已发送的报文个数 |
启动NQA测试组后单向时延不在阈值范围内的报文个数 |
packet-loss |
accumulate |
启动NQA测试组后发送的报文 |
启动NQA测试组后已发送的报文个数 |
启动NQA测试组后累计的丢包数 |
ICPIF/MOS(仅Voice测试支持) |
display nqa result命令用来显示最近一次NQA测试的结果。
display nqa result [ admin-name operation-tag ]
context-admin
context-operator
operation-tag:为测试操作的标签,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
不指定任何参数,则表示显示所有测试组的最近一次测试的结果。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ARP测试的最近一次测试结果。
<Sysname> display nqa result admin test
NQA entry (admin admin, tag test) test results:
Send operation times: 1 Receive response times: 1
Min/Max/Average round trip time: 35/35/35
Square-Sum of round trip time: 1225
Last succeeded probe time: 2011-05-29 10:50:33.2
Extended results:
Packet loss ratio: 0%
Failures due to timeout: 0
Failures due to internal error: 0
Failures due to other errors: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的TCP测试的最近一次测试结果。
Extended results:
Failures due to disconnect: 0
Failures due to no connection: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-jitter测试的最近一次测试结果。
Send operation times: 10 Receive response times: 10
Min/Max/Average round trip time: 1/2/1
Square-Sum of round trip time: 13
Last packet received time: 2015-03-09 17:40:29.8
Extended results:
Packet loss ratio: 0.0%
Packets out of sequence: 0
Packets arrived late: 0
ICMP-jitter results:
RTT number: 10
Min positive SD: 0 Min positive DS: 0
Max positive SD: 0 Max positive DS: 0
Positive SD number: 0 Positive DS number: 0
Positive SD sum: 0 Positive DS sum: 0
Positive SD average: 0 Positive DS average: 0
Positive SD square-sum: 0 Positive DS square-sum: 0
Min negative SD: 1 Min negative DS: 2
Max negative SD: 1 Max negative DS: 2
Negative SD number: 1 Negative DS number: 1
Negative SD sum: 1 Negative DS sum: 2
Negative SD average: 1 Negative DS average: 2
Negative SD square-sum: 1 Negative DS square-sum: 4
SD average: 1 DS average: 2
One way results:
Max SD delay: 1 Max DS delay: 2
Min SD delay: 1 Min DS delay: 2
Number of SD delay: 1 Number of DS delay: 1
Sum of SD delay: 1 Sum of DS delay: 2
Square-Sum of SD delay: 1 Square-Sum of DS delay: 4
Lost packets for unknown reason: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-jitter测试的最近一次测试结果。
Min/Max/Average round trip time: 15/46/26
Square-Sum of round trip time: 8103
Last packet received time: 2011-05-29 10:56:38.7
Extended results:
UDP-jitter results:
RTT number: 10
Min positive SD: 8 Min positive DS: 8
Max positive SD: 18 Max positive DS: 8
Positive SD number: 5 Positive DS number: 2
Positive SD sum: 75 Positive DS sum: 32
Positive SD average: 15 Positive DS average: 16
Positive SD square-sum: 1189 Positive DS square-sum: 640
Min negative SD: 8 Min negative DS: 1
Max negative SD: 24 Max negative DS: 30
Negative SD number: 4 Negative DS number: 7
Negative SD sum: 56 Negative DS sum: 99
Negative SD average: 14 Negative DS average: 14
Negative SD square-sum: 946 Negative DS square-sum: 1495
SD average: 14 DS average: 14
One way results:
Max SD delay: 22 Max DS delay: 23
Min SD delay: 7 Min DS delay: 7
Number of SD delay: 10 Number of DS delay: 10
Sum of SD delay: 125 Sum of DS delay: 132
Square-Sum of SD delay: 1805 Square-Sum of DS delay: 1988
SD lost packets: 0 DS lost packets: 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Voice测试的最近一次测试结果。
Send operation times: 1000 Receive response times: 0
Min/Max/Average round trip time: 0/0/0
Square-Sum of round trip time: 0
Last packet received time: 0-00-00 00:00:00.0
Extended results:
Packet loss ratio: 100.0%
Failures due to timeout: 1000
Voice results:
RTT number: 0
Min negative SD: 0 Min negative DS: 0
Max negative SD: 0 Max negative DS: 0
Negative SD number: 0 Negative DS number: 0
Negative SD sum: 0 Negative DS sum: 0
Negative SD average: 0 Negative DS average: 0
Negative SD square-sum: 0 Negative DS square-sum: 0
SD average: 0 DS average: 0
One way results:
Max SD delay: 0 Max DS delay: 0
Min SD delay: 0 Min DS delay: 0
Number of SD delay: 0 Number of DS delay: 0
Sum of SD delay: 0 Sum of DS delay: 0
Square-Sum of SD delay: 0 Square-Sum of DS delay: 0
Lost packets for unknown reason: 1000
Voice scores:
MOS value: 0.99 ICPIF value: 87
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Path-jitter测试的最近一次测试结果。
Hop IP 192.168.40.210
Basic Results:
Min/Max/Average round trip time: 1/1/1
Square-Sum of round trip time: 10
Extended Results:
Path-Jitter Results:
Jitter number: 9
Min/Max/Average jitter: 0/0/0
Positive jitter number: 0
Min/Max/Average positive jitter: 0/0/0
Sum/Square-Sum positive jitter: 0/0
Negative jitter number: 0
Min/Max/Average negative jitter: 0/0/0
Sum/Square-Sum negative jitter: 0/0
Hop IP 192.168.50.209
Basic Results:
Extended Results:
Jitter number: 9
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-tracert测试的最近一次测试结果。
Send operation times: 6 Receive response times: 6
Last succeeded probe time: 2013-09-09 14:23:24.5
Extended results:
UDP-tracert results:
TTL Hop IP Time
1 3.1.1.1 2013-09-09 14:23:24.5
2 4.1.1.1 2013-09-09 14:23:24.5
# 显示Throughput类型的NQA测试组(管理员为admin,操作标签为test)的最近一次测试结果。
Basic results :
Initial speed(Kbps) : 100000
Speed granularity(Kbps): 1000
Probe duration(s) : 60
Probe interval(s) : 4
Allowed-loss-ratio : 1/10000
Throughput results:
Frame size(Byte): 64
Current speed(Kbps): -
Frame-loss(Loss/Tx): -
Status : Failed
Time : 2022-01-01 07:20:40.8
Frame size(Byte): 512
Current speed(Kbps): 4000
Frame-loss(Loss/Tx): 0/10000
Status : Succeeded
Time : 2022-01-01 07:21:40.8
Frame size(Byte): 1024
Current speed(Kbps): 8000
Status : Succeeded
Time : 2022-01-01 07:22:52.8
Frame size(Byte): 1280
Current speed(Kbps): 10000
Status : Succeeded
Time : 2022-01-01 07:23:45.8
Frame size(Byte): 1518
Status : Succeeded
Time : 2022-01-01 07:24:45.8
表1-6 display nqa result命令显示信息描述
NQA entry (admin admin, tag test) test results |
NQA(测试操作的标签,测试操作的标签)测试组的测试结果 |
Data collecting in progress |
测试正在进行中 |
Path jitter result is not available |
测试没有生成结果 |
Send operation times |
发送的探测报文数 |
Receive response times |
收到的响应报文数 |
Min/Max/Average round trip time |
最小/最大/平均往返时间,单位为毫秒 |
Square-Sum of round trip time |
往返时间平方和 |
Last succeeded probe time |
一次测试中最后一次成功探测的完成时间,如果一次测试中的探测均失败,则该时间显示为全0,UDP-jitter、Path-jitter和Voice测试中无此信息 |
Last packet received time |
一次探测中最后一次成功收到正确响应报文的时间,如果一次探测中没有收到过正确的响应报文,则该时间显示为全0,只在UDP-jitter和Voice测试中存在此信息 |
Extended results |
扩展项的测试结果 |
Packet loss ratio |
平均丢包率。ICMP-jitter、UDP-jitter和Voice类型时,精度为0.1% |
Failures due to timeout |
测试过程中超时的次数 |
Failures due to disconnect |
对方强制断开连接的次数 |
Failures due to no connection |
和对方建立连接失败的次数 |
Failures due to internal error |
因内部错误失败的次数 |
Failures due to other errors |
因其它错误失败的次数 |
Packets out of sequence |
报文失序的次数 |
ICMP-jitter results |
ICMP-jitter测试的结果,只在ICMP-jitter测试中存在此信息 |
Packets arrived late |
探测超时后,收到的响应报文个数 |
UDP-jitter results |
UDP-jitter测试的结果,只在UDP-jitter测试中存在此信息 |
Voice results |
Voice测试的结果,只在Voice测试中存在此信息 |
RTT number |
收到的响应报文数 |
Min positive SD |
源到目的方向正抖动时延的最小值 |
Min positive DS |
目的到源方向正抖动时延的最小值 |
Max positive SD |
源到目的方向正抖动时延的最大值 |
Max positive DS |
目的到源方向正抖动时延的最大值 |
Positive SD number |
源到目的方向正抖动时延的数目 |
Positive DS number |
目的到源方向正抖动时延的数目 |
Positive SD sum |
源到目的方向正抖动时延之和 |
Positive DS sum |
目的到源方向正抖动时延之和 |
Positive SD average |
源到目的方向正抖动时延的平均值 |
Positive DS average |
目的到源方向正抖动时延的平均值 |
Positive SD square-sum |
源到目的方向正抖动时延的平方和 |
Positive DS square-sum |
目的到源方向正抖动时延的平方和 |
Min negative SD |
源到目的方向负抖动时延的绝对值的最小值 |
Min negative DS |
目的到源方向负抖动时延的绝对值的最小值 |
Max negative SD |
源到目的方向负抖动时延的绝对值的最大值 |
Max negative DS |
目的到源方向负抖动时延的绝对值的最大值 |
Negative SD number |
源到目的方向负抖动时延的数目 |
Negative DS number |
目的到源方向负抖动时延的数目 |
Negative SD sum |
源到目的方向负抖动时延的绝对值之和 |
Negative DS sum |
目的到源方向负抖动时延的绝对值之和 |
Negative SD average |
源到目的方向负抖动时延的绝对值的平均值 |
Negative DS average |
目的到源方向负抖动时延的绝对值的平均值 |
Negative SD square-sum |
源到目的方向负抖动时延的平方和 |
Negative DS square-sum |
目的到源方向负抖动时延的平方和 |
SD average |
源到目的方向抖动时延的平均值 |
DS average |
目的到源方向抖动时延的平均值 |
One way results |
单向延迟测试结果,单位为毫秒。只有ICMP-jitter、UDP-Jitter和Voice类型测试有单向延迟测试结果 |
Max SD delay |
源到目的的最大时延 |
Max DS delay |
目的到源的最大时延 |
Min SD delay |
源到目的的最小时延 |
Min DS delay |
目的到源的最小时延 |
Number of SD delay |
源到目的计算的时延数 |
Number of DS delay |
目的到源计算的时延数 |
Sum of SD delay |
源到目的的时延和 |
Sum of DS delay |
目的到源的时延和 |
Square-Sum of SD delay |
源到目的的时延的平方和 |
Square-Sum of DS delay |
目的到源的时延的平方和 |
SD lost packets |
源到目的方向丢失的报文个数 |
DS lost packets |
目的到源方向丢失的报文个数 |
Lost packets for unknown reason |
不能确定原因丢失的报文个数 |
Voice scores |
语音参数,只在Voice类型测试有此信息 |
MOS value |
为语音计算的MOS值 |
ICPIF value |
为语音计算的ICPIF值 |
Hop IP |
本跳IP地址,只在Path-jitter测试中存在此信息 |
Path-jitter results |
Path-jitter测试的结果,只在Path-jitter测试中存在此信息 |
Jitter number |
计算抖动次数,只在Path-jitter测试中存在此信息 |
Min/Max/Average jitter |
最小/最大/平均抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息 |
Positive jitter number |
正抖动时延的数目,只在Path-jitter测试中存在此信息 |
Min/Max/Average positive jitter |
最小/最大/平均正抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息 |
Sum/Square-Sum positive jitter |
正抖动时延之和/平方和,只在Path-jitter测试中存在此信息 |
Negative jitter number |
负抖动时延的数目,只在Path-jitter测试中存在此信息 |
Min/Max/Average negative jitter |
最小/最大/平均负抖动时延,单位为毫秒,只在Path-jitter测试中存在此信息 |
Sum/Square-Sum negative jitter |
负抖动时延之和/平方和,只在Path-jitter测试中存在此信息 |
TTL |
Hop IP |
回复应答的节点IP地址 |
Time |
收到应答报文的时间 |
Status |
测试状态: · Failed:测试失败。 · In progress:测试正在进行 · Aborted:测试终止,表示用户手动停止测试 · Timeout:测试超时 · Unknown error:未知错误 · --:表示测试状态无意义 |
Last test |
当前完成的最后一步测试: · CIR test:CIR测试 · PIR test:PIR测试 · Traffic policing test:流量监管测试 · Service performance test:服务性能测试 |
Estimated total time |
测试估算全部时间,单位秒 |
Actual test time used |
测试实际使用时间,单位秒 说明: 测试开始结束时间以秒为单位,定时器精度为1秒,因此结果表中显示的实际测试时长(结束时间 - 开始时间)与用户配置时长存在1秒误差 |
CIR test (with the step of 1) |
CIR测试,step取值范围为1~1000 |
Start time |
测试开始时间 |
End time |
测试结束时间 |
Min/Max/Average IR(Kbps) |
最小/最大/平均速率,单位为kbit/s |
Min/Max/Average FTD(us) |
最小/最大/平均传输时延,单位为微秒 |
Min/Max/Average FDV(us) |
最小/最大/平均时延抖动,单位为微秒 |
FL count/FLR |
丢包个数/丢包率 |
Packets out of order |
乱序报文个数 |
Severely Err Secs/AVAIL |
SES(Severely Errored Second,严重错误秒):测试开始后,每一秒统计一次丢包率,若该秒内丢包率大于50%,记为严重错误秒。 · 不可用周期:连续10个SES发生时,进入不可用周期,直到连续10个非SES发生时结束。 · 可用周期:连续10个非SES发生时,进入可用周期,直到连续10个SES发生时结束。 Severely Err Secs:严重错误秒总数。 AVAIL = 可用周期/总时间。测试开始时,默认为可用周期。 |
PIR test (color green) |
PIR测试,颜色标记为绿色 |
PIR test (color yellow) |
PIR测试,颜色标记为黄色 |
PIR test (total) |
PIR测试,汇总 |
PIR test (color-blind) |
PIR测试,非颜色标记模式 |
Traffic policing test (color green) |
流量监管测试,颜色标记为绿色 |
Traffic policing test (color yellow) |
流量监管测试,颜色标记为黄色 |
Traffic policing test (total) |
流量监管测试,汇总 |
Traffic policing test (color-blind) |
流量监管测试,非颜色标记模式 |
Service performance test |
服务性能测试 |
Basic results |
基础测试结果 |
Throughput results |
Throughput测试结果 |
Frame-loss results |
Frame-loss测试结果 |
Latency results |
Latency测试结果 |
Initial speed(Kbps) |
发送探测报文的初始速率,单位为kbps |
Speed granularity(Kbps) |
探测报文的速率调整精度,单位为kbps |
Probe duration(s) |
探测周期的时长,单位为秒 |
Probe interval(s) |
探测的时间间隔,单位为秒 |
Allowed-loss-ratio |
可接受的丢包率上限 |
Frame size(Byte) |
探测报文的长度,单位为字节 |
Current speed(Kbps) |
当前速率,单位为kbps |
Frame-loss(Loss/Tx) |
丢包率 |
Min-latency(us) |
最小时延,单位为微秒 |
Max-latency(us) |
最大时延,单位为微秒 |
Avg-latency(us) |
平均时延,单位为微秒 |
Min-jitter(ns) |
最小抖动时延,单位为纳秒 |
Max-jitter(ns) |
最大抖动时延,单位为纳秒 |
Avg-jitter(ns) |
平均抖动时延,单位为纳秒 |
Sent packets |
发送报文数 |
Received packets |
接收报文数 |
Status |
探测结果: · Succeeded:成功 · Failed:失败 |
Time |
探测完成时间 |
display nqa statistics命令用来显示NQA测试的统计信息。
display nqa statistics [ admin-name operation-tag ]
context-admin
context-operator
admin-name :创建NQA测试组的管理员名称,为1~32个字符的字符串,字符串中不能包括“-”,不区分大小写。
测试开始后,如果第一次测试中的所有探测尚未完成,则无法生成统计信息。若此时通过该命令查看统计信息,则显示信息为全0。
如果配置了阈值告警组,将显示在statistics interval命令指定的统计周期内的监测结果。若阈值告警组的阈值类型为平均值,或监测对象为Voice测试的ICPIF或MOS值,则显示的监测结果为无效值。
不指定任何参数,则表示显示所有测试组的统计信息。
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ARP测试的统计信息。
<Sysname> display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
NO. : 1
Start time: 2007-01-01 09:30:20.0
Life time: 2 seconds
Min/Max/Average round trip time: 13/13/13
Square-Sum of round trip time: 169
Extended results:
# 显示NQA测试组管理员名称为admin、测试操作标签为test的TCP测试的统计信息。
NO. : 1
Extended results:
# 显示NQA测试组管理员名称为admin、测试操作标签为test的ICMP-jitter测试的统计信息。
NO. : 1
Start time: 2015-03-09 17:42:10.7
Life time: 156 seconds
Send operation times: 1560 Receive response times: 1560
Square-Sum of round trip time: 1563
Extended results:
RTT number: 1560
Min positive SD: 1 Min positive DS: 1
Max positive SD: 1 Max positive DS: 2
Positive SD number: 18 Positive DS number: 46
Positive SD sum: 18 Positive DS sum: 49
Positive SD average: 1 Positive DS average: 1
Positive SD square-sum: 18 Positive DS square-sum: 55
Min negative SD: 1 Min negative DS: 1
Negative SD number: 24 Negative DS number: 57
Negative SD sum: 24 Negative DS sum: 58
Negative SD average: 1 Negative DS average: 1
Negative SD square-sum: 24 Negative DS square-sum: 60
SD average: 1 DS average: 1
One way results:
Min SD delay: 1 Min DS delay: 1
Number of SD delay: 4 Number of DS delay: 4
Sum of SD delay: 4 Sum of DS delay: 5
Square-Sum of SD delay: 4 Square-Sum of DS delay: 7
Reaction statistics:
1 jitter-DS accumulate 1500 10
2 jitter-SD average - -
3 OWD-DS - 1560 2
4 OWD-SD - 1560 0
5 packet-loss accumulate 0 0
6 RTT accumulate 1560 0
# 显示NQA测试组管理员名称为admin、测试操作标签为test的UDP-jitter测试的统计信息。
NO. : 1
Start time: 2007-01-01 09:33:22.3
Life time: 23 seconds
Send operation times: 100 Receive response times: 100
Min/Max/Average round trip time: 1/11/5
Square-Sum of round trip time: 24360
Extended results:
UDP-jitter results:
RTT number: 550
Max positive SD: 7 Max positive DS: 1
Positive SD number: 220 Positive DS number: 97
Positive SD sum: 283 Positive DS sum: 287
Positive SD average: 1 Positive DS average: 2
Positive SD square-sum: 709 Positive DS square-sum: 1937
Min negative SD: 2 Min negative DS: 1
Max negative SD: 10 Max negative DS: 1
Negative SD number: 81 Negative DS number: 94
Negative SD sum: 556 Negative DS sum: 191
Negative SD average: 6 Negative DS average: 2
Negative SD square-sum: 4292 Negative DS square-sum: 967
SD average: 2 DS average: 2
One way results:
Max SD delay: 5 Max DS delay: 5
Number of SD delay: 550 Number of DS delay: 550
Sum of SD delay: 1475 Sum of DS delay: 1201
Square-Sum of SD delay: 5407 Square-Sum of DS delay: 3959
1 jitter-DS accumulate 90 25
3 OWD-DS - 100 24
4 OWD-SD - 100 13
6 RTT accumulate 100 52
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Voice测试的统计信息。
NO. : 1
Start time: 2007-01-01 09:33:45.3
Life time: 120 seconds
Min/Max/Average round trip time: 1/12/7
Square-Sum of round trip time: 620
Extended results:
Voice results:
RTT number: 10
Min positive SD: 3 Min positive DS: 1
Max positive SD: 10 Max positive DS: 1
Positive SD number: 3 Positive DS number: 2
Positive SD sum: 18 Positive DS sum: 2
Positive SD average: 6 Positive DS average: 1
Positive SD square-sum: 134 Positive DS square-sum: 2
Min negative SD: 3 Min negative DS: 1
Max negative SD: 9 Max negative DS: 1
Negative SD number: 4 Negative DS number: 2
Negative SD sum: 25 Negative DS sum: 2
Negative SD average: 6 Negative DS average: 1
Negative SD square-sum: 187 Negative DS square-sum: 2
SD average: 6 DS average: 1
One way results:
Voice scores:
Max MOS value: 4.40 Min MOS value: 4.40
Max ICPIF value: 0 Min ICPIF value: 0
1 ICPIF - - -
2 MOS - - -
# 显示NQA测试组管理员名称为admin、测试操作标签为test的Path-jitter测试的统计信息。
NO. : 1
Path 1:
Basic Results:
Extended Results:
Jitter number: 9
Basic Results:
Extended Results:
Jitter number: 9
表1-7 display nqa statistics命令显示信息描述
No. |
统计组的组号 |
Start time |
测试组启动时间 |
Life time |
测试的持续时间,单位为秒 |
发送的探测报文数 |
收到的响应报文数 |
往返时间平方和 |
Packet loss ratio |
测试过程中超时的次数 |
对方强制断开连接的次数 |
和对方建立连接失败的次数 |
因内部错误失败的次数 |
因其它错误失败的次数 |
报文失序的次数 |
迟到报文个数 |
Voice results |
RTT number |
收到的响应报文数 |
Min positive SD |
源到目的方向抖动时延为正值的最小值 |
Min positive DS |
目的到源方向抖动时延为正值的最小值 |
Max positive SD |
源到目的方向抖动时延为正值的最大值 |
Max positive DS |
目的到源方向抖动时延为正值的最大值 |
源到目的方向抖动时延为正值的数目 |
目的到源方向抖动时延为正值的数目 |
Positive SD sum |
源到目的方向抖动时延为正值的和 |
Positive DS sum |
目的到源方向抖动时延为正值的和 |
源到目的方向抖动时延为正值的平均值 |
目的到源方向抖动时延为正值的平均值 |
源到目的方向抖动时延为正值的平方和 |
目的到源方向抖动时延为正值的平方和 |
Min negative SD |
源到目的方向抖动时延为负值的最小绝对值 |
Min negative DS |
目的到源方向抖动时延为负值的最小绝对值 |
Max negative SD |
源到目的方向抖动时延为负值的最大绝对值 |
Max negative DS |
目的到源方向抖动时延为负值的最大绝对值 |
源到目的方向抖动时延为负值的数目 |
目的到源方向抖动时延为负值的数目 |
Negative SD sum |
源到目的方向抖动时延为负值的绝对值和 |
Negative DS sum |
目的到源方向抖动时延为负值的绝对值和 |
源到目的方向抖动时延为负值的绝对值的平均值 |
目的到源方向抖动时延为负值的绝对值的平均值 |
源到目的方向抖动时延为负值的平方和 |
目的到源方向抖动时延为负值的平方和 |
SD average |
源到目的方向抖动时延的平均值 |
DS average |
目的到源方向抖动时延的平均值 |
One way results |
Max SD delay |
源到目的的最大时延 |
Max DS delay |
目的到源的最大时延 |
Min SD delay |
源到目的的最小时延 |
Min DS delay |
目的到源的最小时延 |
源到目的计算的时延数 |
目的到源计算的时延数 |
Sum of SD delay |
源到目的的时延和 |
Sum of DS delay |
目的到源的时延和 |
源到目的的时延的平方和 |
目的到源的时延的平方和 |
SD lost packets |
源到目的方向丢失的报文个数 |
DS lost packets |
目的到源方向丢失的报文个数 |
不能确定原因丢失的报文个数 |
Voice scores |
语音参数,只在voice类型测试有此信息 |
Max MOS value |
最大MOS值 |
Min MOS value |
最小MOS值 |
Max ICPIF value |
最大ICPIF值 |
Min ICPIF value |
最小ICPIF值 |
Reaction statistics |
阈值告警组在统计周期内的监测结果 |
Index |
阈值告警组的编号 |
Checked Element |
监测对象 |
Threshold Type |
阈值类型 |
Checked Num |
已监测的样本个数 |
超出阈值的样本个数 |
Path |
Path-jitter测试结果的路径序号,只在Path-jitter测试中存在此信息 |
Hop IP |
Jitter number |
表1-8 display nqa statistics命令显示阈值告警功能相关字段取值描述(ARP/DHCP/DLSw/DNS/FTP/HTTP/ICMP-echo/SNMP/TCP/UDP-echo测试类型)
监测对象 |
阈值类型 |
监测的样本范围 |
Checked Num取值 |
probe-duration |
accumulate |
统计周期内,进行的探测 |
统计周期内,已完成的探测次数 |
统计周期内,累计的探测持续时间不在阈值范围内的探测次数 |
average |
consecutive |
统计周期内,进行的探测 |
统计周期内,已完成的探测次数 |
统计周期内,连续的探测持续时间不在阈值范围内的探测次数 |
probe-fail |
accumulate |
统计周期内,进行的探测 |
统计周期内,已完成的探测次数 |
统计周期内,累计的失败的探测次数 |
consecutive |
统计周期内,进行的探测 |
统计周期内,已完成的探测次数 |
统计周期内,连续的失败的探测次数 |
表1-9 display nqa statistics命令显示阈值告警功能相关字段取值描述(ICMP-jitter/UDP-jitter/Voice测试类型)
监测对象 |
阈值类型 |
监测的样本范围 |
Checked Num取值 |
RTT |
accumulate |
统计周期内,发送的报文 |
统计周期内,已发送的报文个数 |
统计周期内,累计的往返时间不在阈值范围内的报文个数 |
average |
accumulate |
统计周期内,发送的报文 |
统计周期内,已发送的报文个数 |
统计周期内,累计的单向抖动时间不在阈值范围内的报文个数 |
average |
OWD-DS/OWD-SD |
统计周期内,发送的报文 |
统计周期内,已发送的报文个数 |
统计周期内,单向时延不在阈值范围内的报文个数 |
packet-loss |
accumulate |
统计周期内,发送的报文 |
统计周期内,已发送的报文个数 |
统计周期内累计的丢包数 |
· statistics interval
display nqa twamp-light client命令用来查看TWAMP-light Client会话的信息。
display nqa twamp-light client [ test-session session-id | verbose ]
context-admin
context-operator
test-session session-id:显示指定会话的详细信息。session-id表示会话ID,取值范围为1~256。verbose:表示显示所有会话的详细信息。
本命令未指定任何参数时,表示显示所有会话的简要信息。
# 查看所有会话的简要信息。
<Sysname> display nqa twamp-light client
Brief information about all test sessions:
Total sessions: 1
Active sessions: 1
ID Status Source IP/Port Destination IP/Port
1 Active 10.2.2.1/10000 10.2.2.2/20000
# 查看所有会话的详细信息。
<Sysname> display nqa twamp-light client verbose
Session ID : 1
Status : Active
Session type : Permanent
Source interface : -
Service instance : -
Source IP : 10.2.2.1
Source IPv6 : -
Destination IP : 10.2.2.2
Destination IPv6 : -
Source port : 10000
Destination port : 20000
Source MAC : -
Destination MAC : -
VLAN ID : -
Service VLAN ID : -
Customer VLAN ID : -
ToS : 0
Padding length : 142
Timestamp format : PTP
VPN instance : -
Priority 802.1p : 0
Last start time : 2020-01-14 10:57:10.1
Last stop time : Never
Packet sending interval(ms) : 100
Timeout(sec) : 5
Duration(sec) : -
Packets sent : -
Statistics interval(ms) : 10000
Monitor time(ms) : 20000
表1-10 display nqa twamp-light client命令显示信息描述表
Total sessions |
会话总数 |
Active sessions |
正在运行的会话个数 |
Session ID |
会话ID |
Status |
会话的状态: · Active:表示测试会话的测试功能处于激活状态 · Inactive:表示测试会话的测试功能处于未激活状态 |
Session type |
会话类型: · On-demand:按需统计 · Permanent:连续统计 |
Source interface |
测试会话的源AC口 |
Service instance |
关联的以太网服务实例 |
Source IP |
测试会话的源IP地址 |
Source IPv6 |
测试会话的源IPv6地址 |
Destination IP |
测试会话的目的IP地址 |
Destination IPv6 |
测试会话的目的IPv6地址 |
Source port |
测试会话的源端口号 |
Destination port |
测试会话的目的端口号 |
Source MAC |
测试会话源MAC地址 |
Destination MAC |
测试会话目的MAC地址 |
VLAN ID |
测试会话的VLAN ID |
Service VLAN ID |
测试会话的外层VLAN ID |
Customer VLAN ID |
测试会话的内层VLAN ID |
ToS |
测试会话的ToS(Type of Service,服务类型)信息 |
Padding length |
测试会话的填充长度信息 |
Timestamp format |
时间戳格式,取值包括: · NTP:NTP格式 · PTP:PTP格式 |
VPN instance |
MPLS L3VPN实例名称 |
Priority 802.1p |
802.1p优先级 |
Last start time |
TWAMP-light测试最近一次测试的最新开始时间,取值为Never时表示测试未开始 |
Last stop time |
TWAMP-light测试最近一次测试的停止时间,取值为Never时表示测试未结束 |
Packet sending interval(ms) |
TWAMP-light测试的发送报文周期,单位为毫秒 |
Timeout(sec) |
TWAMP-light测试的统计周期内反射报文超时时间,单位为秒 |
Duration(sec) |
TWAMP-light测试的持续时间,只有按需统计且配置了测试持续时间时会显示计数,单位为秒 |
Packets sent |
TWAMP-light测试的发送报文个数,只有按需统计且配置了测试发送报文个数时会显示计数 |
Statistics interval(ms) |
TWAMP-light测试的统计周期,单位为毫秒 |
Monitor time(ms) |
TWAMP-light测试的报文监控时间,单位为毫秒;仅显示用户通过start(TWAMP-light-sender view)命令配置的值 |
· test-session
display nqa twamp-light client statistics命令用来查看TWAMP-light Client会话的统计信息,包括双向时延、双向抖动和双向丢包信息。
display nqa twamp-light client statistics { two-way-delay | two-way-loss } test-session session-id
context-admin
context-operator
two-way-delay:显示双向时延和抖动的统计信息。
two-way-loss:显示双向丢包的统计信息。
session-id:显示指定会话的统计信息;整数形式,取值范围为1~256。
# 查看指定会话的双向时延和抖动的统计信息。
<Sysname> display nqa twamp-light client statistics two-way-delay test-session 1
Latest two-way delay statistics(us):
Index Delay(Avg) Jitter(Avg) SD-jitter(Avg) DS-jitter(Avg)
98 3930 941 2992 3054
99 4184 1550 3136 2969
100 3799 1273 3135 3103
101 3881 1345 2932 2906
102 3850 1310 3290 3226
103 4202 1579 3694 3703
104 3893 1033 2999 3000
105 3891 1206 2935 2982
106 3861 1076 2947 2906
107 3911 1246 3011 2886
108 4088 1617 3083 2890
109 3832 1380 3041 2976
110 4332 1478 3610 3784
111 3908 1115 2953 2943
112 4111 1646 3391 3028
113 3982 1215 2905 2885
114 3799 1207 2951 2902
115 4824 2107 3952 3343
116 4137 1433 3658 3625
117 3986 1337 2914 2904
118 3904 1087 3873 3883
119 3737 1337 4612 4539
120 4285 1621 3910 3949
121 4390 1886 3211 3065
122 3756 1338 2967 2956
123 4200 1181 3190 3087
124 4674 1769 2938 3103
125 4248 1333 2841 2898
126 4074 1314 2965 2897
127 4010 1156 2997 2906
Average delay : 4056 Average jitter : 1372
Maximum delay : 28999 Maximum jitter : 25000
Minimum delay : 952 Minimum jitter : 1
Average SD jitter: 3234 Average DS jitter: 3177
Maximum SD jitter: 28115 Maximum DS jitter: 16996
Minimum SD jitter: 0 Minimum DS jitter: 0
表1-11 display nqa twamp-light client statistic two-way-delay命令显示信息描述表
Latest two-way delay statistics(μs) |
最近一次测试最新的双向时延统计信息,单位为微秒 |
Index |
统计数据的序列号 |
Delay(Avg) |
平均时延值 |
Jitter(Avg) |
平均抖动值 |
SD jitter(Avg) |
源到目的方向平均抖动值 |
DS jitter(Avg) |
目的到源方向平均抖动值 |
Average delay |
平均时延值 |
Average jitter |
平均抖动值 |
Maximum delay |
最大时延值 |
Maximum jitter |
最大抖动值 |
Minimum delay |
最小时延值 |
Minimum jitter |
最小抖动值 |
Average SD jitter |
源到目的方向平均抖动值 |
Average DS jitter |
目的到源方向平均抖动值 |
Maximum SD jitter |
源到目的方向最大抖动值 |
Maximum DS jitter |
目的到源方向最大抖动值 |
Minimum SD jitter |
源到目的方向最小抖动值 |
Minimum DS jitter |
目的到源方向最小抖动值 |
# 查看指定会话的双向丢包统计信息。
<Sysname> display nqa twamp-light client statistics two-way-loss test-session 1
Latest two-way loss statistics:
Index Loss count Loss ratio Error count Error ratio
104 0 0.0000% 0 0.0000%
105 0 0.0000% 0 0.0000%
106 0 0.0000% 0 0.0000%
107 0 0.0000% 0 0.0000%
108 0 0.0000% 0 0.0000%
109 0 0.0000% 0 0.0000%
110 0 0.0000% 0 0.0000%
111 0 0.0000% 0 0.0000%
112 0 0.0000% 0 0.0000%
113 0 0.0000% 0 0.0000%
114 0 0.0000% 0 0.0000%
115 0 0.0000% 0 0.0000%
116 0 0.0000% 0 0.0000%
117 0 0.0000% 0 0.0000%
118 0 0.0000% 0 0.0000%
119 0 0.0000% 0 0.0000%
120 0 0.0000% 0 0.0000%
121 0 0.0000% 0 0.0000%
122 0 0.0000% 0 0.0000%
123 0 0.0000% 0 0.0000%
124 0 0.0000% 0 0.0000%
125 0 0.0000% 0 0.0000%
126 0 0.0000% 0 0.0000%
127 0 0.0000% 0 0.0000%
128 0 0.0000% 0 0.0000%
129 0 0.0000% 0 0.0000%
130 0 0.0000% 0 0.0000%
131 0 0.0000% 0 0.0000%
132 0 0.0000% 0 0.0000%
133 0 0.0000% 0 0.0000%
Average loss count : 0 Average loss ratio : 0.0000%
Maximum loss count : 0 Maximum loss ratio : 0.0000%
Minimum loss count : 0 Minimum loss ratio : 0.0000%
Average error count : 0 Average error ratio : 0.0000%
Maximum error count : 0 Maximum error ratio : 0.0000%
Minimum error count : 0 Minimum error ratio : 0.0000%
表1-12 display nqa twamp-light client statistic two-way-loss命令显示信息描述表
Latest two-way loss statistics |
双向丢包统计信息 |
Index |
统计数据的序列号 |
Loss count |
丢包个数 |
Loss ratio |
丢包率 |
Error count |
错包个数 |
Error ratio |
错包率 |
Average loss count |
平均丢包个数 |
Average loss ratio |
平均丢包率 |
Maximum loss count |
最大丢包个数 |
Maximum loss ratio |
最大丢包率 |
Minimum loss count |
最小丢包个数 |
Minimum loss ratio |
最小丢包率 |
Average error count |
平均错包个数 |
Average error ratio |
平均错包率 |
Maximum error count |
最大错包个数 |
Maximum error ratio |
最大错包率 |
Minimum error count |
最小错包个数 |
Minimum error ratio |
最小错包率 |
· reset nqa twamp-light statistics
· test-session (TWAMP-light-client view)
display nqa twamp-light client test-session reaction counters命令用来显示TWAMP-light测试会话阈值告警组的监测结果。
display nqa twamp-light client test-session reaction counters [ session-id [ item-number ] ]
context-admin
context-operator
session-id:会话ID,取值范围为1~256。指定该参数时,可以显示该会话的所有统计信息。
不指定任何参数,则表示显示TWAMP-light所有测试会话中所有阈值告警组的当前监测结果。
# 显示TWAMP-light测试会话1阈值告警组的当前监测结果。
<Sysname> display nqa twamp-light client test-session reaction counters 1
Reaction counters for session 1:
Index: 1
Checked element: two-way-delay
Lower-threshold: 5
Upper-threshold: 50
Action type: trap-only
Check-objects: 1
Threshold violations: 1
表1-13 display nqa twamp-light client test-session reaction counters命令显示信息描述表
Index |
阈值告警组的编号 |
Checked element |
监测的对象 |
Lower-threshold |
阈值告警范围的最低阈值 |
Upper-threshold |
阈值告警范围的最高阈值 |
Action type |
告警类型,取值为: · trap-only:条件满足时,本地记录监测结果的同时,向网管发送Trap消息 · none:只在本地记录监测结果,不向网管发送Trap消息 |
Check-objects |
已监测的样本个数 |
Threshold violations |
超出阈值的样本个数 |
· reaction checked-element two-way-delay
· reaction checked-element two-way-loss
· reaction checked-element two-way-jitter
expect { data | hex-data }命令用来配置期望测试成功的应答内容。
undo expect { data | hex-data }命令用来恢复缺省情况。
expect { data | hex-data } string [ { offset | strict-offset } number ]
未配置期望测试成功的应答内容。
HTTP/HTTPS/TCP/UDP/WAP类型的NQA模板视图
context-admin
data: 表示使用文本格式的字符串来填充探测报文。
hex-data:表示使用十六进制字符串来填充探测报文。该参数仅在TCP/UDP/WAP类型的NQA模板视图下支持。
string:期望测试成功的应答内容。和data关键字配合使用时,为1~200个字符的字符串,区分大小写;和hex-data关键字配合使用时,为2~200个字符的字符串,字符串长度必须是偶数且不区分大小写。
offset number:所期望的内容在返回报文中的偏移量,取值范围为0~1000,缺省值为0。
strict-offset number:所期望的内容在返回报文中的严格偏移量,取值范围为0~1000,缺省值为0。
NQA客户端对于返回报文中期望成功的应答内容匹配方式如下:
· 如果未配置offset参数和strict-offset参数,则设备直接从返回报文对应字段的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推,直到匹配成功,则认为测试成功,否则认为测试失败。
· 如果配置了offset参数,则设备从返回报文对应字段偏移量之后的第一个字节开始匹配,若匹配失败,则忽略该偏移量,从返回报文的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推,直到匹配成功,则认为测试成功,否则认为测试失败。
· 如果配置了strict-offset参数,则设备从返回报文对应字段偏移量之后的第一个字节开始匹配,若匹配失败,继续从第二个字节开始匹配,以此类推,直到匹配成功,则认为测试成功,否则认为测试失败。
对于HTTP/HTTPS类型的NQA模板,仅当回应报文的BODY类型为CONTENT或CHUNK时,进行期望应答内容的检查,否则不做检查。
对于TCP类型的NQA模板,仅当data-fill和expect { data | hex-data }命令都配置时,进行期望应答内容的检查,否则不做检查。
对于UDP类型的NQA模板:
· 仅当data-fill和expect { data | hex-data }命令都配置时,进行期望应答内容的检查,否则不做检查。
· 偏移检查和data-fill是否指定raw关键字命令有关,当指定raw关键字时,从收到报文的第一个字节开始检查;当未指定raw关键字时, UDP报文数据字段的前五个字节具有特定用途,从第六个字节开始进行偏移检查。
对于WAP类型的NQA模板,从WSP reply报文的headers字段开始进行期望应答内容的检查。当配置url命令时,WAP测试需要通过配置本命令进行期望应答内容的检查来判断测试是否成功。
测试过程中若未配置期望应答状态码,且收到的NQA应答报文中的内容匹配上本命令配置的期望应答内容,则判断本次测试为成功测试;若配置了期望应答状态码,则只有在匹配上期望的、测试成功应答状态码或者未匹配上期望的、测试失败应答状态码之后,才以本命令的匹配结果判断本次测试的成功与否。
对于HTTP/HTTPS类型的NQA模板,本命令不能与expect { failed-data | hex-failed-data }命令同时配置。
对于TCP/UDP类型的NQA模板,当同时配置了本命令和expect { failed-data | hex-failed-data }时,如果两条命令同时匹配上,则以expect { failed-data | hex-failed-data }的匹配结果为准,认为测试失败。
# 在HTTP类型的NQA模板视图下配置期望的应答内容为welcome!。
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] expect data welcome!
expect { failed-data | hex-failed-data }命令用来配置期望测试失败的应答内容。
undo expect { failed-data | hex-failed-data }命令用来恢复缺省情况。
expect { failed-data | hex-failed-data } string [ { offset | strict-offset } number ]
未配置期望测试失败的应答内容。
HTTP/HTTPS/TCP/UDP类型的NQA模板视图
context-admin
failed-data:表示使用文本格式的字符串来填充探测报文。
hex-failed-data:表示使用十六进制字符串来填充探测报文。
string:期望测试失败的应答内容。和failed-data关键字配合使用时,为1~200个字符的字符串,区分大小写;和hex-failed-data关键字配合使用时,为2~200个字符的字符串,字符串长度必须是偶数且不区分大小写。
NQA客户端对于返回报文中期望失败的应答字符串匹配方式如下:
· 如果未配置offset参数和strict-offset参数,则设备直接从返回报文对应字段的第一个字节开始匹配,若不匹配,继续从第二个字节开始匹配,以此类推,如果剩余的字符串中包含期望的应答字符串,或者剩余字符串的长度小于期望应答字符串的长度,则认为测试失败,否则认为测试成功。
· 如果配置了offset参数,则设备从返回报文对应字段偏移量之后的第一个字节开始匹配,如果剩余的字符串中包含期望的应答字符串,或者剩余字符串的长度小于期望应答字符串的长度,则认为测试失败,否则忽略该偏移量,从返回报文的第一个字节开始匹配,如果剩余的字符串中包含期望的应答字符串,或者剩余字符串的长度小于期望应答字符串的长度,则认为测试失败,否则认为测试成功。
· 如果配置了strict-offset参数,则设备从返回报文对应字段偏移量之后的第一个字节开始匹配,如果剩余的字符串中包含期望的应答字符串,或者剩余字符串的长度小于期望应答字符串的长度,则认为测试失败,否则认为测试成功。
对于TCP类型的NQA模板,仅当data-fill和expect { failed-data | hex-failed-data }命令都配置时,进行期望失败应答内容的检查,否则不做检查。
对于UDP类型的NQA模板:
· 仅当data-fill和expect { failed-data | hex-failed-data }命令都配置时,进行期望失败应答内容的检查,否则不做检查。
· 偏移检查和data-fill是否指定raw关键字命令有关,当指定raw关键字时,从收到报文的第一个字节开始检查;当未指定raw关键字时,UDP报文数据字段的前五个字节具有特定用途,从第六个字节开始进行偏移检查。
· 测试过程中若未配置期望应答状态码,且收到的NQA应答报文中的内容匹配上本命令配置的期望应答内容,则判断本次测试为失败测试;若配置了期望应答状态码,则只有在匹配上期望的、测试成功应答状态码或者未匹配上期望的、测试失败应答状态码之后,才以本命令的匹配结果判断本次测试的成功与否。
对于HTTP/HTTPS类型的NQA模板,本命令不能与expect { data | hex-data }命令同时配置。
对于TCP/UDP类型的NQA模板,当同时配置了本命令和expect { data | hex-data }时,如果两条命令同时匹配上,则以本命令的匹配结果为准。
# 在TCP类型的NQA模板视图下配置期望失败的应答内容为error。
[Sysname-nqatplt-tcp-tcptplt] expect failed-data error
expect failed-status命令用来配置期望的、测试失败应答状态码。
undo expect failed-status命令用来恢复缺省情况。
expect failed-status status-list
undo expect failed-status [ status-list ]
未配置期望的、测试失败应答状态码。
HTTP/HTTPS类型的模板视图
context-admin
status-list:状态码列表,即HTTP/HTTPS模板类型期望收到的测试失败状态码范围。表示方式为status-list = { status-number1 [ to status-number2 ] }&<1-10>,status-number取值范围为0~999,status-number2的值要大于或等于status-number1的值,&<1-10>表示前面的参数最多可以重复输入10次。
HTTP/HTTPS类型的NQA模板支持配置期望的、测试失败应答状态码。报文的状态码是由3位十进制数组成的字段,它包含服务器的状态信息,用户可以根据该状态码了解服务器的状态。状态码的第一位规定状态码的类型。
测试过程中若收到的NQA应答报文中的状态码匹配上本命令配置的应答状态码,则判断本次测试为失败测试;若未匹配上本命令配置的应答状态码,且未配置期望应答内容,则判断本次测试为成功测试,若配置了期望应答内容,以能否匹配期望应答内容判断本次测试的成功与否。
本命令不能与expect status命令同时配置。
# 在HTTP类型的NQA模板视图下配置期望的、测试失败应答状态码为300、400~500。
[Sysname] nqa template http tplt
[Sysname-nqatplt-http-tplt] expect failed-status 300 400 to 500
expect ip命令用来配置期望返回的IP地址。
undo expect ip命令用来恢复缺省情况。
expect ip ip-address
undo expect ip
未配置期望返回的IP地址。
DNS类型的NQA模板视图
context-admin
ip-address:DNS探测期望返回的IP地址。
在DNS测试中,NQA客户端通过该命令配置的IP地址与DNS服务器通过域名解析出的IP地址进行比较,若相同,则证明目前测试的DNS服务器合法,否则为非法DNS服务器。
# 在DNS类型的NQA模板视图下配置期望返回的IP地址为1.1.1.1。
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] expect ip 1.1.1.1
expect ipv6命令用来配置期望返回的IPv6地址。
undo expect ipv6命令用来恢复缺省情况。
expect ipv6 ipv6-address
undo expect ipv6
未配置期望返回的IPv6地址。
DNS类型的NQA模板视图
context-admin
ipv6-address:DNS探测期望返回的IPv6地址。
在DNS测试中,NQA客户端通过该命令配置的IPv6地址与DNS服务器通过域名解析出的IPv6地址进行比较,若相同,则证明目前测试的DNS服务器合法,否则为非法DNS服务器。
# 在DNS类型的NQA模板视图下配置期望返回的IPv6地址为1::1。
[Sysname-nqatplt-dns-dnstplt] expect ipv6 1::1
expect status命令用来配置期望的应答状态码。
undo expect status命令用来恢复缺省情况。
expect status status-list
undo expect status [ status-list ]
未配置期望的应答状态码。
HTTP/HTTPS/RTSP/SIP类型的模板视图
context-admin
status-list:状态码列表,即HTTP/HTTPS/RTSP/SIP模板类型期望收到的状态码范围。表示方式为status-list = { status-num1 [ to status-num2 ] }&<1-10>,status-num取值范围为0~999,status-num2的值要大于或等于status-num1的值,&<1-10>表示前面的参数最多可以重复输入10次。
HTTP/HTTPS/RTSP/SIP类型的NQA模板支持配置状态码。报文的状态码是由3位十进制数组成的字段,它包含服务器的状态信息,用户可以根据该状态码了解服务器的状态。状态码的第一位规定状态码的类型。
测试过程中若收到的NQA应答报文中的状态码匹配上本命令配置的应答状态码,且未配置期望应答内容,则判断本次测试为成功测试,若配置了期望应答内容,以能否匹配期望应答内容判断本次测试的成功与否;若收到的NQA应答报文中的状态码未匹配上本命令配置的应答状态码,则判断本次测试为失败测试。
对于HTTP/HTTPS类型的NQA模板,本命令不能与expect failed-status命令同时配置。
# 在HTTP类型的NQA模板视图下配置期望的应答状态码,允许状态码为200、300、400~500。
[Sysname-nqatplt-http-httptplt] expect status 200 300 400 to 500
filename命令用来配置FTP服务器和客户端之间传送文件的文件名。
undo filename命令用来恢复缺省情况。
filename filename
undo filename
未配置FTP服务器和客户端之间传送文件的文件名。
FTP测试类型视图
FTP类型的NQA模板视图
context-admin
filename:FTP服务器和客户端之间传送文件的文件名,为1~200个字符的字符串,字符串中不能包括“/”,不区分大小写。
# 在FTP测试类型下配置FTP服务器和客户端之间要传送文件的文件名为config.txt。
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
# 在FTP类型的NQA模板视图下配置FTP服务器和客户端之间要传送文件的文件名为config.txt。
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] filename config.txt
frequency命令用来配置测试组连续两次测试开始时间的时间间隔。
undo frequency命令用来恢复缺省情况。
frequency interval
undo frequency
在NQA测试类型视图下,Voice、Path-jitter测试中连续两次测试开始时间的时间间隔为60000毫秒;其他类型的测试中连续两次测试开始时间的时间间隔为0毫秒,即只进行一次测试。
在NQA模板视图下,测试中连续两次测试开始时间的时间间隔为5000毫秒。
ICMP-echo/TCP/UDP-echo 测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
context-admin
interval:连续两次测试开始时间的时间间隔,取值范围为0~604800000,单位为毫秒。时间间隔为0,表示两次测试的时间间隔为无穷,即只进行一次测试,此时不会生成统计结果。
通过nqa schedule命令启动NQA测试组后,每隔interval时间启动一次测试。
到达本命令指定的时间间隔时,将开始下一个间隔的计时,此时如果上次测试尚未完成,则不启动新一轮测试,直到上次测试完成后并等待时间间隔超时,才开始新一轮测试。
到达本命令指定的时间间隔时,将开始下一个间隔的计时,但如果此时测试尚未完成或者测试未超时,则不启动新一轮测试,直到测试完成或者测试超时,才开始新一轮测试。
# 在ICMP-echo测试类型下配置连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
# 在DNS类型的NQA模板视图下配置连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqatplt-dns-dnstplt] frequency 1000
· probe timeout
frequency-adjustment命令用来配置测试失败时,测试组连续两次测试开始时间的时间间隔。
undo frequency-adjustment命令用来恢复缺省情况。
frequency-adjustment adj-interval
未配置测试失败时,测试组连续两次测试开始时间的时间间隔。
任意类型的NQA模板视图
context-admin
adj-interval:测试组连续两次测试开始时间的时间间隔,取值范围0~604800000,单位为毫秒。
NQA测试失败时,为了设备能够快速感知服务器的状态,尽快恢复应用,需要配置本命令,使NQA启动更高频率的测试。
缺省情况下,不管本次测试成功还是失败,下次探测报文发送的时间间隔不会发生改变,始终为frequency命令配置的时间。
配置本命令后,如果测试结果为失败,则使用本命令配置的时间为后两次测试开始的时间间隔。如果测试结果为成功,则使用frequency命令配置的时间作为后两次测试开始的时间间隔。
# 在HTTP类型的NQA模板视图下配置测试失败时,测试组连续两次测试开始时间的时间间隔为1000毫秒。
[Sysname-nqatplt-http-tplt] frequency-adjustment 1000
hex-data-fill命令用来配置探测报文十六进制的填充字符串。
undo hex-data-fill命令用来恢复缺省情况。
hex-data-fill hex [ raw ]
undo hex-data-fill
探测报文的填充内容为十六进制数值00010203040506070809。
TCP/UDP类型的NQA模板视图
context-admin
hex:探测报文的填充内容,为2~200个字符的十六进制字符串,字符串长度必须是偶数位,不区分大小写。
raw:表示仅使用hex来填充探测报文,该参数仅在UDP类型的NQA模板视图下支持。
若指定raw参数,表示hex参数位置的填充字符串在探测时将被直接发送。由于NQA发送的数据字段存在特殊字节,如果目的端是H3C设备,那么目的端能够直接识别NQA填充后的探测报文,不建议配置该参数;如果目的端不是H3C设备,则无法识别NQA填充后的探测报文,那么必须指定该参数,填充字符串需要是目的端服务器所开启的UDP服务类型并从该类型要求的填充报文类型确定填充字符串。
未指定raw参数,填充时,实际填充的字符与填充数据长度有关:
例如,配置填充数据为“abcd”,当探测报文数据段长度为3字节时,则取“abc”作为填充数据;当探测报文大小为6字节时,则使用“adcdab”作为填充数据。
[Sysname-nqatplt-tcp-tcptplt] hex-data-fill abcd
high-performance-mode enable命令用来开启UDP-jitter测试的高性能模式。
undo high-performance-mode enable命令用来关闭UDP-jitter测试的高性能模式。
UDP-jitter测试的高性能模式处于关闭状态。
UDP-jitter测试类型视图
context-admin
配置本命令后,UDP-jitter测试将开启高性能模式,该模式下UDP-jitter测试的测试效率和测试结果的精确度将大大提升。
开启高性能模式后,命令route-option bypass-route、data-size、reaction checked-element { jitter-ds | jitter-sd } threshold-type accumulate、reaction checked-element rtt threshold-type accumulate将不再生效。
当有多个UDP-jitter测试需要开启高性能模式时,可以通过nqa agent udp-jitter high-performance enable命令开启NQA客户端所有UDP-jitter测试类型的高性能模式。
# 开启UDP-jitter测试的高性能模式。
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] high-performance-mode enable
· nqa agent udp-jitter high-performance enable
history-record enable命令用来开启NQA测试组的历史记录保存功能。
undo history-record enable命令用来关闭NQA测试组的历史记录保存功能。
UDP-tracert测试类型的历史记录保存功能处于开启状态,其他类型的NQA测试组的历史记录保存功能处于关闭状态。
UDP-tracert测试类型视图
context-admin
如果开启NQA测试组的历史记录保存功能,则系统会记录该NQA测试组的历史信息,通过display nqa history命令可以查看该测试组的历史记录信息。
如果关闭NQA测试组的历史记录保存功能,则系统不会记录该测试组的历史信息,原有的历史记录信息也会被删除。
# 在ICMP-echo测试类型下开启NQA测试组的历史记录保存功能。
[Sysname-nqa-admin-test-icmp-echo] history-record enable
· display nqa history
history-record keep-time命令用来配置NQA测试组中历史记录的保存时间。
undo history-record keep-time命令用来恢复缺省情况。
history-record keep-time keep-time
NQA测试组中历史记录的保存时间为120分钟。
UDP-tracert测试类型视图
context-admin
keep-time:历史记录的保存时间,取值范围为1~1440,单位为分钟。
NQA测试结束后,开始计算该测试组中所有历史记录的保存时间。保存时间达到配置的值后,将删除这些记录。
# 在ICMP-echo测试类型下配置NQA测试组中历史记录的保存时间为100分钟。
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
history-record number命令用来配置在一个测试组中能够保存的最大历史记录个数。
undo history-record number命令用来恢复缺省情况。
history-record number number
一个测试组中能够保存的最大历史记录个数为50。
UDP-tracert测试类型视图
context-admin
number:在一个测试组中能够保存的最大历史记录个数,取值范围为0~50。
如果一个测试组中历史记录个数超过设定的最大数目,则最早的历史记录将会被删除。
# 在ICMP-echo测试类型下配置一个测试组中能够保存的最大历史记录数为10个。
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
init-ttl命令用来配置UDP-tracert探测报文的初始跳数。
undo init-ttl命令用来恢复缺省情况。
init-ttl value
undo init-ttl
UDP-tracert探测报文的初始跳数为1。
UDP-tracert测试类型视图
context-admin
value:UDP-tracert探测报文的初始跳数,取值范围1~255。
# 在UDP-tracert测试类型下配置UDP-tracert探测报文的初始跳数为5跳。
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] init-ttl 5
key命令用来设置RADIUS认证和计费使用的共享密钥。
undo key命令用来恢复缺省情况。
key { cipher | simple } string
undo key
未设置RADIUS认证和计费使用的共享密钥。
RADIUS认证探测/RADIUS-ACCOUNT计费探测类型的NQA模板视图
context-admin
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~64个字符的字符串,密文密钥为1~117个字符的字符串。
必须保证设备上设置的共享密钥与RADIUS认证和计费服务器上的完全一致。
# 在RADIUS类型的NQA模板视图下设置RADIUS认证使用的共享密钥为明文abc。
[Sysname] nqa template radius radiustplt
[Sysname-nqatplt-radius-radiustplt] key simple abc
lsr-path命令用来配置松散路由。
undo lsr-path命令用来恢复缺省情况。
lsr-path ip-address&<1-8>
undo lsr-path
未配置松散路由。
Path-jitter测试类型视图
context-admin
ip-address&<1-8>:松散路由IP地址,&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
通过本命令配置松散路由,用户只需给出NQA探测报文必须经过的一些“节点”,并不需要给出一条完备的路径,无直接连接的“节点”之间的路由需要路由器寻址功能补充。
Path-jitter测试中,NQA客户端通过tracert过程使用该命令配置的松散路由进行探路,并根据收到ICMP报文计算主要“节点”时延和抖动时间。
# 在Path-jitter测试类型下配置松散路由为10.1.1.20和10.1.2.10两跳。
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test- path-jitter] lsr-path 10.1.1.20 10.1.2.10
mailbox命令用来配置IMAP测试操作的邮箱名称。
undo mailbox命令用来恢复缺省情况。
mailbox mailbox-name
undo mailbox
IMAP测试操作的邮箱名称为INBOX。
IMAP类型的NQA模板视图
context-admin
mailbox-name:IMAP探测使用的邮箱名称,为1~64个字符的字符串,区分大小写。
# 在IMAP类型的NQA模板视图下配置邮箱名称为fortest1。
[Sysname] nqa template imap imaptplt
[Sysname-nqatplt-imap-imaptplt] mailbox fortest1
max-failure命令用来配置一次UDP-tracert测试中连续探测失败的最大次数。
undo max-failure命令用来恢复缺省情况。
max-failure times
undo max-failure
一次UDP-tracert测试中连续探测失败的最大次数为5。
UDP-tracert测试类型视图
context-admin
times:表示一次UDP-tracert测试中连续探测失败的最大次数,取值范围0~255。0和255意味着UDP-tracert探测不会因为连续探测失败而停止测试。
当UDP-tracert测试中连续探测失败的次数达到指定的最大值时,设备认为测试失败并停止探测。
# 在UDP-tracert测试类型下配置一次UDP-tracert测试中连续探测失败的最大次数为20次。
[Sysname-nqa-admin-test-udp-tracert] max-failure 20
memory命令用来配置SNMP-DCA测试的SNMP Agent内存的阈值和权重。
undo memory命令用来恢复缺省情况。
memory { threshold threshold-value | weight weight-value } *
undo memory
SNMP-DCA测试的SNMP Agent内存的阈值为70,权重为2。
SNMP-DCA类型的NQA模板视图
context-admin
threshold threshold-value:阈值,表示内存使用率可达到的上限。取值范围为0~100,取值为0时表示内存不作为判断SNMP Agent是否繁忙的参考。不指定该参数时,表示使用缺省值。
weight weight-value:权重,表示内存在用于计算SNMP Agent状态时应占有的比重。取值范围为0~100,取值为0时表示内存权重不参与计算SNMP Agent的状态。不指定该参数时,表示使用缺省值。
NQA客户端对Net-SNMP或Windows类型的SNMP Agent进行SNMP-DCA测试时,会自动获取SNMP Agent当前的内存使用率。
# 在SNMP-DCA类型的NQA模板视图下配置测试的SNMP Agent内存的阈值为90、权重为90。
[Sysname-nqatplt-snmpdca-test] memory threshold 90 weight 90
· agent-type
mode命令用来配置FTP测试的数据传输方式。
undo mode命令用来恢复缺省情况。
mode { active | passive }
undo mode
FTP测试的数据传输方式为主动方式。
FTP测试类型视图
FTP类型的NQA模板视图
context-admin
active:设置FTP的数据传输方式为主动方式。表示在建立数据连接时由服务器主动发起连接请求。
passive:设置FTP的数据传输方式为被动方式。表示在建立数据连接时由客户端主动发起连接请求。
# 在FTP测试类型下配置FTP测试的数据传输方式为被动方式。
[Sysname-nqa-admin-test-ftp] mode passive
# 在FTP类型的NQA模板视图下配置数据传输方式为被动方式。
[Sysname-nqatplt-ftp-ftptplt] mode passive
next-hop ip命令用来配置探测报文的下一跳IP地址。
undo next-hop ip命令用来恢复缺省情况。
next-hop ip ip-address
undo next-hop ip
未配置探测报文的下一跳IP地址。
ICMP-echo测试类型视图
DNS/ICMP/TCP Half Open类型的NQA模板视图
context-admin
ip-address:探测报文的下一跳IP地址。
配置本命令之后,设备按照指定的下一跳地址发送探测报文;若未配置本命令,则按照路由表缺省的转发规则发送探测报文。
# 在ICMP-echo测试类型下配置探测报文的下一跳IP地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.1
next-hop ipv6命令用来配置探测报文的下一跳IPv6地址。
undo next-hop ipv6命令用来恢复缺省情况。
next-hop ipv6 ipv6-address
undo next-hop ipv6
未配置探测报文的下一跳IPv6地址。
ICMP-echo测试类型视图
context-admin
ipv6-address:探测报文的下一跳IPv6地址,不支持IPv6链路本地地址。
# 在ICMP-echo测试类型下配置探测报文的下一跳IPv6地址为10::1。
[Sysname-nqa-admin-test-icmp-echo] next-hop ipv6 10::1
no-fragment enable命令用来开启UDP-tracert探测类型的禁止报文分片功能。
undo no-fragment enable命令用来关闭UDP-tracert探测类型的禁止报文分片功能。
no-fragment enable
UDP-tracert测试类型的禁止报文分片功能处于关闭状态。
UDP-tracert测试类型视图
context-admin
开启此功能后,设备发送的IP报文头部的DF(don't fragment)字段会被置一,这样报文在转发过程中将无法被分片。通过配置这条命令可以对一条链路的路径MTU值进行测试。
# 在UDP-tracert测试类型下开启UDP-tracert探测类型的禁止报文分片功能。
[Sysname-nqa-admin-test-udp-tracert] no-fragment enable
nqa命令用来创建NQA测试组,并进入NQA测试组视图。如果指定的NQA测试组视图已经存在,则直接进入NQA测试组视图。
undo nqa命令用来删除指定的NQA测试组。
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
不存在NQA测试组。
context-admin
all:所有NQA测试组、模板和操作组。
# 创建一个管理员名为admin,测试操作标签为test的NQA测试组,并进入NQA测试组视图。
nqa agent enable命令用来开启NQA客户端功能。
undo nqa agent enable命令用来关闭NQA客户端功能,并停止所有正在进行的测试。
nqa agent enable
NQA客户端功能处于开启状态。
context-admin
# 开启NQA客户端功能。
[Sysname] nqa agent enable
· nqa server enable
nqa agent udp-jitter high-performance enable命令用来全局开启UDP-jitter测试的高性能模式。
undo nqa agent udp-jitter high-performance enable命令用来全局关闭UDP-jitter测试的高性能模式。
UDP-jitter测试的高性能探测模式处于全局关闭状态。
用户可在系统视图和UDP-jitter测试类型视图下开启UDP-jitter测试的高性能模式。
· 系统视图下可以开启所有UDP-jitter测试的高性能模式,UDP-jitter测试类型视图下只能开启该视图下UDP-jitter测试的高性能模式。
· 从系统视图和UDP-jitter测试类型视图任意一个都能开启UDP-jitter测试的高性能模式,但若要关闭UDP-jitter测试的高性能模式,则必须将两个视图下的UDP-jitter测试的高性能模式都关闭。
开启全局高性能模式后,命令route-option bypass-route、data-size、reaction checked-element { jitter-ds | jitter-sd } threshold-type accumulate、reaction checked-element rtt threshold-type accumulate将不再生效。
# 全局开启UDP-jitter的高性能模式。
[Sysname] nqa agent udp-jitter high-performance enable
· high-performance enable
nqa schedule命令用来配置测试组的启动时间和持续时间。
undo nqa schedule命令用来停止指定测试组的测试。
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
undo nqa schedule admin-name operation-tag
未配置NQA调度功能。
context-admin
start-time:指定测试组的启动时间和日期。
hh:mm:ss:测试组的启动时间,小时:分钟:秒。
yyyy/mm/dd:测试组的启动日期,年:月:日,缺省值为系统的当前日期,年的取值范围为2000~2035。
mm/dd/yyyy:测试组的启动日期,月:日:年,缺省值为系统的当前日期,年的取值范围为2000~2035。
now:测试组立即开始测试。
lifetime:指定测试的持续时间。
lifetime:测试的持续时间,取值范围为1~2147483647,单位为秒。
forever:测试组将一直进行测试。
recurring:指定测试组每天都被调度运行。每天启动测试的时间由start-time参数指定。若不指定该参数,则测试组只在当天的指定时间内调度运行一次。
测试组被调度后不允许进入测试类型视图。若需要重新进入测试类型视图,请使用undo nqa schedule命令停止指定测试组的测试。
系统时间在启动时间~启动时间+持续时间范围内时,测试组进行测试。执行nqa schedule命令时,如果系统时间尚未到达启动时间,则到达启动时间后,启动测试;如果系统时间在启动时间~启动时间+持续时间之间,则立即启动测试;如果系统时间已经超过启动时间+持续时间,则不会启动测试。通过display clock命令可以显示系统的当前时间。
配置lifetime时间请保证一次测试能够完成,否则无法完成正常的联动操作。
# 启动管理员名称为admin,标签为test的测试组进行测试,测试组的启动时间为2008年8月8日以后(包含当天)的每天的08:08:08,测试持续时间为1000秒。
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000 recurring
· destination ip
· display clock(基础配置命令参考/设备管理)
· nqa entry
· type
nqa template命令用来创建指定类型NQA模板,并进入NQA模板视图。如果指定的NQA模板视图已经存在,则直接进入NQA模板视图。
undo nqa template命令用来删除指定类型的NQA模板。
nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | radius-account | rtsp | sip | smtp | snmp | snmpdca | ssl | tcp | tcphalfopen | udp | wap } name
undo nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | radius-account | rtsp | sip | smtp | snmp | snmpdca | ssl | tcp | tcphalfopen | udp | wap } name
不存在NQA模板。
context-admin
arp:配置ARP模板类型。
dns:配置DNS模板类型。
ftp:配置FTP模板类型。
http:配置HTTP模板类型。
https:配置HTTPS模板类型。
icmp:配置ICMP模板类型。
imap:配置IMAP模板类型。
pop3:配置POP3模板类型。
radius:配置RADIUS认证探测模板类型。
radius-account:配置RADIUS-ACCOUNT计费探测模板类型。
rtsp:配置RTSP模板类型。
sip:配置SIP模版类型。
smtp:配置SMTP模板类型。
snmp:配置SNMP模板类型。
snmpdca:配置SNMP DCA模板类型。
ssl:配置SSL模板类型。
tcp:配置TCP模板类型。
tcphalfopen:配置TCP Half Open模板类型。
udp:配置UDP模板类型。
wap:配置WAP模板类型。
# 创建一个类型为ICMP、名称为icmptplt的模板,并进入NQA模板视图。
nqa twamp-light client命令用来创建TWAMP-light Client,并进入TWAMP-light-client视图。如果TWAMP-light Client已经存在,则直接进入TWAMP-light-client视图。
undo nqa twamp-light client命令用来删除TWAMP-light Client。
不存在TWAMP-light Client。
context-admin
双向主动测量协议TWAMP满足对复杂、多样化组网场景性能测量的需求。当使用NQA TWAMP-light统计业务时,需要执行nqa twamp-light client命令进入client视图,在TWAMP-light-client视图下可以创建TWAMP-light Client测试会话(Test session),然后基于这些会话启动相关统计业务。
执行undo nqa twamp-light client命令时,系统会删除TWAMP-light Client及其所有的会话和统计信息。
# 创建TWAMP-light Client,并进入TWAMP-light-client视图。
[Sysname] nqa twamp-light client
[Sysname-nqa-twamp-light-client]
nqa twamp-light sender命令用来创建TWAMP-light Sender,并进入TWAMP-light-sender视图。如果TWAMP-light Sender已经存在,则直接进入TWAMP-light-sender视图。
undo nqa twamp-light sender命令用来删除TWAMP-light Sender。
不存在TWAMP-light Sender。
context-admin
在TWAMP-light-sender视图下可以控制TWAMP-light测试的启动和停止。
# 创建TWAMP-light Sender,并进入TWAMP-light Sender。
[Sysname] nqa twamp-light sender
[Sysname-nqa-twamp-light-sender]
oid命令用来配置SNMP-DCA测试的SNMP Agent上MIB节点的阈值和权重。
undo oid命令用来恢复缺省情况。
oid oid threshold threshold-value weight weight-value
undo oid oid
未配置SNMP-DCA测试的SNMP Agent上MIB节点的阈值和权重。
SNMP-DCA类型的NQA模板视图
context-admin
oid:SNMP-DCA测试的SNMP Agent上MIB节点的OID,为1~255个字符的字符串,其中OID指代的MIB节点的返回值必须为MIB节点的资源使用率。
threshold threshold-value:阈值,表示MIB节点的资源使用率可达到的上限,取值范围为0~100。取值为0时表示该MIB节点不作为判断SNMP Agent是否繁忙的参考。
weight weight-value:权重,表示MIB节点在用于计算SNMP Agent状态时应占有的比重。取值范围为0~100,取值为0时表示该MIB节点的权重不参与SNMP Agent状态的计算。
当agent-type配置为User-defined时,必须进行本配置,用户最多可以配置8条自定义的OID命令。
NQA客户端对Net-SNMP或Windows类型的SNMP Agent进行SNMP-DCA测试时,会自动获取SNMP Agent当前MIB节点的资源使用率。
# 在SNMP-DCA类型的NQA模板视图下配置测试的SNMP Agent上MIB节点的阈值和权重。
[Sysname-nqatplt-snmpdca-test] oid 1.3.6.1.4.1.2021.11.11.0 threshold 90 weight 90
· agent-type
operation命令用来配置FTP测试的操作方式。
undo operation命令用来恢复缺省情况。
operation { get | put }
undo operation
FTP测试的操作方式为get操作。
FTP测试类型视图
FTP类型的模板视图
context-admin
get:从FTP服务器获取文件。
put:向FTP服务器传送文件。
进行put操作时,若配置了filename,发送数据前判断filename指定的文件是否存在,如果存在则上传该文件,如果不存在则探测失败。
进行get操作时,如果FTP服务器上没有以url中所配置的文件名为名称的文件,则测试不会成功。进行get操作时,设备上不会保存从服务器获取的文件。
进行get、put操作时,请选用较小的文件进行测试,如果文件较大,可能会因为超时而导致测试失败,或由于占用较多的网络带宽而影响其他业务。
# 在FTP测试类型下配置FTP测试的操作方式为put操作。
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test-ftp] operation put
# 在FTP类型的NQA模板视图下配置测试的操作方式为put操作。
[Sysname-nqatplt-ftp-ftptplt] operation put
· password
· username
operation命令用来配置HTTP测试的操作方式。
operation { get | post | raw }
undo operation
HTTP测试的操作方式为get操作。
HTTP测试类型视图
HTTP类型的NQA模板视图
context-admin
get:从HTTP服务器获取数据。
post:向HTTP服务器提交数据。
raw:向HTTP服务器发送RAW请求报文。
HTTP测试中以HTTP请求报文作为探测报文。
测试的操作方式为get或post时,请求报文内容从url中获取。
测试的操作方式为raw时,请求报文为raw-request子视图中配置的内容。在配置HTTP操作方式中的raw操作可以通过在raw-request子视图中配置get、post或其他服务器支持的请求类型的HTTP报文,以此直接作为探测报文。请确保raw-request子视图中所配置报文内容的正确性。
# 在HTTP测试类型下配置HTTP测试的操作方式为raw操作。
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] operation raw
# 在HTTP类型的NQA模板视图下配置测试的操作方式为raw操作。
[Sysname-nqatplt-http-httptplt] operation raw
· password
· raw-request
· username
operation命令用来配置HTTPS测试的操作方式。
undo operation
HTTPS测试的操作方式为get操作。
HTTPS类型的NQA模板视图
context-admin
get:从HTTPS服务器获取数据。
post:向HTTPS服务器提交数据。
raw:向HTTPS服务器发送RAW请求报文。
HTTPS测试中以HTTPS请求报文作为探测报文。
测试的操作方式为raw时,请求报文为raw-request子视图中配置的内容。在配置HTTPS操作方式中的raw操作可以通过在raw-request子视图中配置get、post或其他服务器支持的请求类型的HTTPS报文,以此直接作为探测报文。请确保raw-request子视图中所配置报文内容的正确性。
# 在HTTPS类型的NQA模板视图下配置测试的操作方式为raw操作。
[Sysname] nqa template https httptplt
[Sysname-nqatplt-https-httptplt] operation raw
· password
· raw-request
· username
out interface命令用来指定探测报文的出接口。
undo out interface命令用来恢复缺省情况。
out interface interface-type interface-number
undo out interface
未指定探测报文的出接口。
ICMP-echo测试类型视图
DHCP测试类型视图
UDP-tracert测试类型视图
UDP-jitter测试类型视图
context-admin
interface-type interface-number:探测报文出接口的接口类型和接口编号。
该命令指定的接口必须处于UP状态,否则NQA探测过程将会失败。
对于ICMP-echo测试类型和DNS/ICMP/TCP Half Open类型的NQA模板,如果配置next-hop命令,此配置不生效。
password命令用来配置测试服务器的用户登录密码。
undo password命令用来恢复缺省情况。
undo password
未配置测试服务器的用户登录密码。
FTP/HTTP测试类型视图
FTP/HTTP/HTTPS/IMAP/POP3/RADIUS认证探测类型的NQA模板视图
context-admin
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。对于FTP/HTTP/HTTPS,明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串;对于RADIUS,明文密码为1~64个字符的字符串,密文密码为1~117个字符的字符串;对于IMAP/POP3,明文密码为1~40个字符的字符串,密文密码为1~85个字符的字符串。
# 在FTP测试类型下配置FTP服务器的用户登录密码为ftpuser。
[Sysname-nqa-admin-test-ftp] password simple ftpuser
# 在FTP类型的NQA模板视图下配置FTP服务器的用户登录密码为ftpuser。
[Sysname-nqatplt-ftp-ftptplt] password simple ftpuser
· operation
· username
port-detect enable命令用来开启端口检测功能。
undo port-detect enable命令用来关闭端口检测功能。
port-detect enable
端口检测功能处于关闭状态。
TCP Half Open/UDP类型的NQA模板视图
context-admin
开启TCP Half Open模板的端口检测功能是用于测试对端TCP服务的端口是否可用。NQA客户端将主动向对端发出TCP SYN报文,如果在探测超时时间(probe timeout命令配置)内,收到目的端回应的SYN+ACK报文,则认为测试成功,反之则认为测试失败。
开启UDP模板的端口检测功能用于测试对端UDP服务的端口是否可用。如果在探测超时时间(probe timeout命令配置)内,没有收到任何标识目的端不可达的ICMP差错报文,则认为测试成功,反之则认为测试失败。需要在目的端开启ICMP目的不可达报文发送功能,如果目的端是H3C设备,需要在设备上执行ip unreachables enable命令。另外,需要配置data-fill string raw或hex-data-fill hex raw命令,填充字符串可以是在参数允许范围内的任意值。
要使本功能生效,必须通过destination port命令配置目的端口号。
# 在TCP Half Open类型的NQA模板视图下开启TCP Half Open的端口检测功能。
[Sysname] nqa template tcphalfopen tplt
[Sysname-nqatplt-tcphalfopen-tplt] port-detect enable
· data-fill
· destination port
· hex-data-fill
· ip unreachables enable(三层技术-IP业务命令参考/IP性能优化)
priority 8021p命令用来配置探测报文的802.1p优先级。
undo priority 8021p命令用来恢复缺省情况。
priority 8021p value
undo priority 8021p
探测报文的802.1p优先级为0。
TWAMP-light测试的Client-session视图
context-admin
value:探测报文的802.1p优先级,取值范围为0~7。
为了测试在二层网络环境下,对于业务流量拥塞的情况下设备根据报文不同的优先级给予不同的优先转发策略时,路径上对于该类流量的服务质量。此时使用本命令指定测试流量的优先级。
有关802.1p优先级的详细介绍,请参见“ACL和QoS配置指导”中的“QoS”。
# 配置TWAMP-light测试探测报文的802.1p优先级为1。
[Sysname-nqa-twamp-light-client] test-session 1
[Sysname-nqa-twamp-light-client-session1] priority 8021p 1
probe count命令用来配置一次NQA测试中探测的次数。
undo probe count命令用来恢复缺省情况。
probe count times
undo probe count
对于UDP-tracert测试类型,对于一个TTL值的节点发送的探测报文次数为3次;其他类型的NQA测试一次NQA测试中的探测次数为1次。
UDP-tracert测试类型视图
ICMP-jitter/UDP-jitter测试类型视图
context-admin
times:对于UDP-tracert测试类型,表示对于一个TTL值的节点发送的探测报文次数,取值范围为1~10;对于其他测试类型,表示一次NQA测试中进行探测的次数,取值范围为1~15。
不同测试类型中,探测的含义不同:
· 对于TCP和DLSw测试,一次探测操作是指建立一次连接。
· 对于ICMP-jitter和UDP-jitter测试,一次探测操作是指连续发送多个探测报文,发送探测报文的个数由probe packet-number命令指定。
· 对于FTP、HTTP、DHCP和DNS测试,一次探测操作是指完成一次相应的功能,例如上传或下载一个文件,获取一个Web页面,为接口申请一个IP地址,将一个域名解析为IP地址。
· 对于ICMP-echo、ARP和UDP-echo测试,一次探测操作是指发送一个探测报文。
· 对于SNMP测试,一次探测操作是指发送三个SNMP协议报文,分别对应SNMP v1、SNMP v2c和SNMP v3三个版本。
· 对于Path-jitter测试,一次探测操作分为两个步骤:首先通过tracert探路获取到达目的地址的路径(最大为64跳);再根据tracert结果,分别向路径上的每一跳发送多个ICMP-echo探测报文,发送探测报文的个数由用户来设定。
· 对于UDP-tracert测试,一次探测操作是指一个特定TTL值的节点发送一个探测报文的操作。
对于UDP-tracert测试,同一个TTL的节点,设备会发送数量为probe count命令配置的探测报文,系统在进行第一次探测之后,等待回应;对于其他类型的测试,如果配置的次数大于1,那么系统在进行第一次探测之后,等待回应。如果到达probe timeout命令指定的探测超时时间时,仍然没有收到回应,则发起第二次探测。如此反复,直到完成指定次数的探测。
Voice和Path-jitter测试不支持该命令,一次测试中只能进行一次探测。
# 在ICMP-echo测试类型下配置一次ICMP-echo测试中探测的次数为10次。
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] probe count 10
probe packet-interval命令用来配置发送探测报文的时间间隔。
undo probe packet-interval命令用来恢复缺省情况。
probe packet-interval interval
发送探测报文的时间间隔为20毫秒。
context-admin
interval:测试中发送探测报文的时间间隔,取值范围为10~60000,单位为毫秒。
# 在UDP-jitter测试类型下配置测试中发送探测报文的时间间隔为100毫秒。
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number命令用来配置一次探测中发送探测报文的个数。
undo probe packet-number命令用恢复缺省情况。
probe packet-number number
一次ICMP-jitter、UDP-jitter或Path-jitter探测中发送10个探测报文;一次Voice探测中发送1000个探测报文。
context-admin
number:一次探测中发送探测报文的个数,对于ICMP-jitter、UDP-jitter和Path-jitter测试,取值范围为10~1000;对于Voice测试,取值范围为10~60000。
# 在UDP-jitter测试类型下配置一次探测中发送100个探测报文。
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout命令用来配置一次探测中等待响应报文的超时时间。
undo probe packet-timeout命令用来恢复缺省情况。
probe packet-timeout timeout
ICMP-jitter、UDP-jitter和Path-jitter测试中等待响应报文的超时时间为3000毫秒;Voice测试中等待响应报文的超时时间为5000毫秒。
ICMP-jitter/Path-jitter/UDP-jitter/Voice测试类型视图
context-admin
timeout:一次探测中等待响应报文的超时时间,取值范围为10~3600000,单位为毫秒。
# 在UDP-jitter测试类型下配置一次探测中等待响应报文的超时时间为100毫秒。
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout命令用来配置探测的超时时间。
undo probe timeout命令用来恢复缺省情况。
probe timeout timeout
undo probe timeout
探测的超时时间为3000毫秒。
ICMP-echo/TCP/UDP-echo测试类型视图
ARP/DHCP/DLSw/DNS/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
context-admin
timeout:一次探测的超时时间,单位为毫秒。在FTP、HTTP探测中,取值范围为10~86400000;在DHCP、DLSw、DNS、ICMP-echo、SNMP、TCP、UDP-echo和UDP-tracert探测中,取值范围为10~3600000。对于NQA模板类型来说,FTP、HTTP和HTTPS模板的范围为10~86400000,其他模板范围为10~3600000。
如果NQA探测没有在probe timeout命令指定的时间内完成,则认为本次探测超时。
frequency命令中配置的interval参数的值需要大于probe timeout命令中的timeout参数的值。否则,probe timeout命令将没有机会生效。
# 在ICMP-echo测试类型下配置探测的超时时间为10000毫秒。
[Sysname-nqa-admin-test-icmp-echo] probe timeout 10000
# 在HTTP类型的NQA模板视图下配置探测的超时时间为10000毫秒。
[Sysname-nqatplt-http-httptplt] probe timeout 10000
· frequency
proxy-url命令用来配置HTTP/HTTPS代理服务器的网址。
undo proxy-url命令用来恢复缺省情况。
proxy-url url
undo proxy-url
未配置HTTP/HTTPS代理服务器的网址。
HTTP/HTTPS类型的NQA模板视图
context-admin
url:HTTP/HTTPS代理服务器的网址,为1~255个字符的字符串,区分大小写。url的主机名部分,由“.”分隔的字符串组成(如 aabbcc.com),每个字符串的长度不超过63个字符,区分大小写;字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
· HTTP测试类型时,url格式为http://host或http://host:port。
· HTTPS测试类型时,url格式为https://host或https://host:port。
在必须通过代理服务器才能访问HTTP/HTTPS服务器的组网环境下,必须配置本命令。配置本命令后,设备发送的探测报文以及HTTP/HTTPS服务器返回的响应报文,都会经过代理服务器中转。
# 在HTTP类型的NQA模板视图下配置HTTP代理服务器的网址为http://www.company.com。
[Sysname-nqatplt-http-httptplt] proxy-url http://www.company.com
raw-request命令用来进入raw-request子视图,并在该子视图下配置HTTP/HTTPS测试请求报文内容。
undo raw-request命令用来恢复缺省情况。
raw-request
undo raw-request
未配置HTTP/HTTPS测试请求报文的内容。
HTTP测试类型视图
context-admin
每次使用raw-request命令进入raw-request子视图时,之前在该子视图下配置的HTTP测试请求报文内容会被清除。
HTTP/HTTPS测试的操作方式为raw时,必须配置该命令。raw-request子视图下支持配置TEXT命令。TEXT命令为HTTP/HTTPS测试报文的内容,即HTTP/HTTPS的请求报文。要求报文内容中不能包含alias命令配置的别名,请用户自行确保报文的正确性,否则探测将失败。有关alias命令的详细介绍请参见“基础配置命令参考”中的“CLI”。
# 进入raw-request子视图,并在该子视图下配置HTTP测试GET操作的请求报文的内容。
[Sysname-nqa-admin-test-http] raw-request
[Sysname-nqa-admin-test-http-raw-request] GET /sdn/ui/app/index HTTP/1.0\r\nHost: 172.0.0.2\r\n\r\n
# 在HTTP类型的NQA模板视图下,进入raw-request子视图,并在该子视图下配置HTTP测试POST操作的请求报文的内容。
[Sysname-nqatplt-http-httptplt] raw-request
[Sysname-nqatplt-http-httptplt-raw-request] POST /sdn/ui/app/index HTTP/1.0\r\nHost:
172.0.0.2\r\nAuthorization: Basic cm9vdDoxMjM0NTY=\r\n\r\n
reaction checked-element { jitter-ds | jitter-sd }命令用来创建监测单向抖动时间的阈值告警组。
undo reaction命令用来删除指定的阈值告警组。
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
不存在监测单向抖动时间的阈值告警组。
ICMP-jitter/UDP-jitter/Voice测试类型视图
context-admin
item-number:阈值告警组编号,取值范围为1~10。
jitter-ds:监测从目的到源的单向抖动时间。
jitter-sd:监测从源到目的的单向抖动时间。
threshold-type:指定阈值类型。
accumulate accumulate-occurrences:每次测试中,累计的单向抖动时间超出阈值的报文个数。对于ICMP-jitter与UDP-jitter测试,取值为1~14999;对于Voice测试,取值范围为1~59999。
average:每次测试中,单向抖动时间的平均值。
threshold-value:指定阈值范围。
upper-threshold:阈值上限,取值范围为0~3600000,单位为毫秒。
lower-threshold:阈值下限,取值范围为0~3600000,且必须小于等于阈值上限,单位为毫秒。
action-type:触发的动作类型,缺省动作类型为none。
none:只在显示信息中记录监测结果,不向网管发送Trap消息。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。
阈值告警组创建后,不能再通过reaction命令修改该阈值告警组的内容。若要修改阈值告警组的内容,则需要先通过undo reaction命令用来删除阈值告警组,再利用新的参数创建阈值告警组。
监测的对象是探测成功的报文,探测失败的报文不参与计数。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测UDP-jitter探测报文的从目的到源的单向抖动时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均单向抖动时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# 在UDP-jitter测试类型下创建编号为2的阈值告警组,监测UDP-jitter探测报文的从目的到源的单向抖动时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的单向抖动时间超出阈值的报文个数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction checked-element { owd-ds | owd-sd }命令用来创建监测单向时延的阈值告警组。
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
不存在监测单向时延的阈值告警组。
context-admin
owd-ds:监测每个探测报文的从目的到源的单向时延。
owd-sd:监测每个探测报文的从源到目的的单向时延。
lower-threshold:阈值下限,取值范围为0~3600000,单位为毫秒,且必须小于等于阈值上限。
监测单向时延的阈值告警组不支持触发动作,但可以通过相关显示命令display nqa reaction counters和display nqa statistics显示当前的监测结果。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测每个UDP-jitter探测报文的从目的到源的单向时延,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。收到探测报文的应答报文后,计算该探测报文从目的到源的单向时延,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
reaction checked-element icpif命令用来创建监测Voice测试ICPIF值的阈值告警组。
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测Voice测试ICPIF值的阈值告警组。
Voice测试类型视图
context-admin
upper-threshold:阈值上限,取值范围为1~100。
lower-threshold:阈值下限,取值范围为1~100,且必须小于等于阈值上限。
# 在Voice测试类型下创建编号为1的阈值告警组,监测每次Voice测试的ICPIF值,阈值上限为50,下限为5。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的ICPIF值,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
reaction checked-element mos命令用来创建监测Voice测试MOS值的阈值告警组。
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测Voice测试MOS值的阈值告警组。
Voice测试类型视图
context-admin
item-number:阈值告警组的编号,取值范围为1~10。
upper-threshold:阈值上限,取值范围为1~500。
lower-threshold:阈值下限,取值范围为1~500,且必须小于等于阈值上限。
实际的阈值下限(或阈值上限)为输入的阈值下限/100(或阈值上限/100),即如果输入的阈值下限和阈值上限分别为100、200,则MOS值在1~2之间时,未超出阈值。
# 在Voice测试类型下创建编号为1的阈值告警组,监测每次Voice测试的MOS值,阈值上限为200,下限为100。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的MOS值,若超出阈值范围,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
reaction checked-element packet-loss命令用来创建监测每次测试中丢包数的阈值告警组。
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
不存在监测每次测试中丢包数的阈值告警组。
context-admin
accumulate accumulate-occurrences:每次测试中,累计的丢包数。对于ICMP-jitter与UDP-jitter测试,取值范围为1~15000;对于Voice测试,取值范围为1~60000。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测每次UDP-jitter测试的丢包数。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的丢包数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction checked-element probe-duration命令用来创建监测探测持续时间的阈值告警组。
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测探测持续时间的阈值告警组。
context-admin
accumulate accumulate-occurrences:每次测试中,累计的探测持续时间超出阈值的探测次数。accumulate-occurrences取值范围为1~15。
average:每次测试中,探测持续时间的平均值。
consecutive consecutive-occurrences:测试组启动后,连续的探测持续时间超出阈值的探测次数。consecutive-occurrences取值范围为1~16。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。DNS测试不支持发送Trap,DNS测试类型视图下无此参数。
监测的对象是成功的探测,失败的探测不参与计数。
# 在ICMP-echo测试类型下创建编号为1的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均探测持续时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# 在ICMP-echo测试类型下创建编号为2的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的持续时间超出阈值的探测次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# 在ICMP-echo测试类型下创建编号为3的阈值告警组,监测ICMP-echo探测的持续时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次探测结束后,检查测试组启动以来连续的持续时间超出阈值的探测次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction checked-element probe-fail命令用来创建监测探测失败次数的阈值告警组。
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
不存在监测探测失败次数的阈值告警组。
context-admin
accumulate accumulate-occurrences:一次测试中,累计的探测失败次数。accumulate-occurrences取值范围为1~15。
consecutive consecutive-occurrences:NQA测试组启动以来,连续的探测失败次数。consecutive-occurrences取值范围为1~16。
trap-only:条件满足时,在显示信息中记录监测结果的同时,向网管发送Trap消息。DNS测试不支持发送trap,DNS测试类型视图下无此参数。
# 在ICMP-echo测试类型下创建编号为1的阈值告警组,监测ICMP-echo探测的失败次数。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的探测失败次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# 在ICMP-echo测试类型下创建编号为2的阈值告警组,监测ICMP-echo探测的失败次数。NQA测试组启动前,初始的阈值状态为invalid。每次探测结束后,检查测试组启动以来连续的探测失败次数,若达到或超过10次,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction checked-element probe-fail命令用来建立联动项,对当前所在测试组中的探测进行监测,当连续探测失败次数达到阈值时,就触发其他模块联动。
undo reaction命令用来删除指定的联动项。
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
不存在联动项。
context-admin
item-number:联动项序号,取值范围为1~10。
threshold-type:指定门限类型。
consecutive consecutive-occurrences:NQA测试组启动以来连续的探测失败次数,取值范围为1~16。
action-type:触发的动作类型。
trigger-only:条件满足时,触发其它模块联动。
联动项创建后,不能再通过reaction命令修改该联动项的内容。若要修改联动项的内容,则需要先通过undo reaction命令用来删除联动项,再利用新的参数创建联动项。
# 在TCP测试类型下建立序号为1的联动项,连续探测失败3次,触发其他模块联动。
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
· track(网络管理和监控命令参考/Track)
reaction checked-element rtt命令用来创建监测报文往返时延的阈值告警组。
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测报文往返时延的阈值告警组。
context-admin
accumulate accumulate-occurrences:每次测试中,累计的RTT超出阈值的报文个数。对于ICMP-jitter与UDP-jitter测试,取值范围为1~15000;对于Voice测试,取值范围为1~60000。
average:每次测试中,报文往返时间的平均值。
# 在UDP-jitter测试类型下创建编号为1的阈值告警组,监测UDP-jitter探测报文的往返时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试的平均报文往返时间,若超出阈值,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# 在UDP-jitter测试类型下创建编号为2的阈值告警组,监测每个UDP-jitter探测报文的往返时间,阈值上限为50毫秒,下限为5毫秒。NQA测试组启动前,初始的阈值状态为invalid。每次测试结束后,检查本次测试中累计的RTT超出阈值的报文个数,若达到或超过100个,阈值状态置为over-threshold;反之,置为below-threshold。当阈值状态改变时,向网管发送Trap消息。
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction checked-element two-way-delay命令用来创建监测双向时延的阈值告警组。
reaction item-number checked-element two-way-delay threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测双向时延的阈值告警组。
context-admin
upper-threshold:上限阈值,取值范围是2~1000000,单位为微秒。
lower-threshold:下限阈值,取值范围是1~999999,且必须小于等于上限阈值,单位为微秒。
阈值告警组创建后,不能再通过reaction命令修改该阈值告警组的内容。若要修改阈值告警组的内容,则需要先通过undo reaction命令用来删除阈值告警组,再重新配置。
在监控时间内的测试结果均大于上限阈值或者从大于下限阈值恢复到小于下限阈值时,将触发告警。监控时间由start命令的monitor-time参数配置。
# 创建编号为1的阈值告警组,监测探测报文的从目的到源和从源到目的的双向时延,阈值上限为50毫秒,下限为5毫秒。
[Sysname-nqa-twamp-light-client-session1] reaction 1 checked-element two-way-delay threshold-value 50 5 action-type trap-only
· start (TWAMP-light-sender view)
reaction checked-element two-way-jitter命令用来创建监测双向抖动的阈值告警组。
reaction item-number checked-element two-way-jitter threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测双向抖动的阈值告警组。
context-admin
upper-threshold:上限阈值,取值范围2~1000000,单位为微秒。
lower-threshold:下限阈值,取值范围为1~999999,且必须小于等于上限阈值,单位为微秒。
# 创建编号为1的阈值告警组,监测探测报文的从目的到源和从源到目的的双向抖动时间,阈值上限为20毫秒,下限为3毫秒。
[Sysname-nqa-twamp-light-client-session1] reaction 1 checked-element two-way-jitter threshold-value 20 3 action-type trap-only
reaction checked-element two-way-loss命令用来创建监测双向丢包率的阈值告警组。
reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
不存在监测双向丢包率的阈值告警组。
context-admin
upper-threshold:上限阈值,表示每1000000个包中设备可接受的丢包数,取值范围是2~1000000,单位为1/1000000。
lower-threshold:上限阈值,表示每1000000个包中设备可接受的丢包数,取值范围是1~999999,且必须小于等于上限阈值,单位为1/1000000。
# 创建编号为1的阈值告警组,监测探测报文的从目的到源和从源到目的的双向丢包率。阈值上限为1000,下限为500。
[Sysname-nqa-twamp-light-client-session1] reaction 1 checked-element two-way-loss threshold-value 1000 500 action-type trap-only
reaction trap命令用来配置在指定条件下向网管服务器发送Trap消息。
undo reaction trap命令用来恢复缺省情况。
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] }
undo reaction trap { path-change | probe-failure | test-complete | test-failure }
不向网管服务器发送Trap消息。
UDP-tracert测试类型视图
context-admin
path-change:当进行UDP-tracert类型测试时,在配置了frequency命令后进行连续测试后,如果检测到当前路径相对于上一次测试路径发生变化,则设备发送一次Trap消息。
probe-failure consecutive-probe-failures:每次探测结束后,计算本次NQA测试中探测连续失败的次数,如果连续失败次数大于或等于consecutive-probe-failures,则向网管服务器发送探测失败的Trap消息。一次测试中,可能发送多次Trap消息。consecutive-probe-failures为一次测试中连续探测失败的次数,取值范围为1~15。
test-complete:对于非UDP-tracert类型测试,当测试完成时发送测试完成的Trap消息。对于UDP-tracert类型测试,测试出到达目的设备的路径后,发送测试完成的Trap消息。
test-failure accumulate-probe-failures:对于非UDP-tracert类型测试,一次NQA测试结束后,计算本次NQA测试中探测失败的累计次数,如果累计失败次数大于或等于accumulate-probe-failures,则向网管服务器发送测试失败的Trap消息。accumulate-probe-failures为一次测试中累计探测失败的次数,为必须输入的参数,取值范围为1~15。对于UDP-tracert类型测试,只要未能测试出到达目的地的路径,就发送一次Trap消息。用户不能输入参数accumulate-probe-failures。
ARP测试支持reaction trap probe-failure,reaction trap test-complete和reaction trap test-failure。
ICMP-jitter、UDP-jitter 和Voice测试只支持reaction trap test-complete。
UDP-tracert测试支持reaction trap path-change,reaction trap test-complete和reaction trap test-failure(其中UDP-tracert测试不支持reaction trap test-failure的accumulate-probe-failures参数)。
# 在ICMP-echo测试类型下配置测试中连续探测失败次数大于或等于5次时,发送探测失败的Trap消息。
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
reaction trigger per-probe命令用来配置每次探测结果发送机制,即每次探测结束时都会将探测结果发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
undo reaction trigger per-probe命令用来恢复缺省情况。
连续探测成功或失败3次时,NQA客户端会把探测成功或失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
context-admin
本命令与reaction trigger probe-fail命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
本命令与reaction trigger probe-pass命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP类型的NQA模板视图下配置每次探测结果发送机制,即每次探测结束时都会将探测结果发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] reaction trigger per-probe
· reaction trigger probe-fail
· reaction trigger probe-pass
reaction trigger probe-fail命令用来配置连续探测失败的次数。
undo reaction trigger probe-fail命令用来恢复缺省情况。
reaction trigger probe-fail count
连续探测失败3次时,NQA客户端会把探测失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
任意类型的NQA模板视图
context-admin
count:连续探测失败的次数,取值范围为1~15。
当连续探测失败次数达到命令配置的数值时,NQA客户端会把探测失败的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
外部特性调用NQA模板后进行相应的NQA测试,使用此命令可以设定节点失效的连续测试失败次数。
本命令与reaction trigger per-probe命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在HTTP类型的NQA模板视图下配置确定节点失效需要连续探测失败5次。当连续探测失败的次数达到5次时,NQA客户端把探测失败的消息发送给外部特性,使外部特性能利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-http-httptplt] reaction trigger probe-fail 5
· reaction trigger per-probe
reaction trigger probe-pass命令用来配置连续探测成功次数。
undo reaction trigger probe-pass命令用来恢复缺省情况。
reaction trigger probe-pass count
连续探测成功3次时,NQA客户端会把探测成功的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
任意类型的NQA模板视图
context-admin
count:连续探测成功的次数,取值范围为1~15。
当连续探测成功次数达到命令配置的数值时,NQA客户端会把探测成功的消息发送给外部特性,使外部特性利用NQA测试的结果进行相应处理。
外部特性调用NQA模板后进行相应的NQA测试,使用此命令可以设定节点有效的连续探测成功次数。
# 在HTTP类型的NQA模板视图下配置确定节点有效需要连续探测成功5次。当连续探测成功的次数达到5次时,NQA客户端把探测成功的消息发送给外部特性,使外部特性能利用NQA测试的结果进行相应处理。
[Sysname-nqatplt-http-httptplt] reaction trigger probe-pass 5
request-method命令用来配置RTSP模板测试请求方式。
undo request-method命令用来恢复缺省情况。
request-method { describe | options }
undo request-method
RTSP模板测试请求方式为options。
RTSP类型的NQA模板视图
context-admin
describe:Describe方式,用于获取URL路径中指定对象的相关信息。
options:Options方式,用于获取RTSP服务器提供的可用方法。
配置探测请求方式为Describe方式时,必须通过url命令配置文件路径,NQA客户端通过url命令指定的配置文件路径必须对应RTSP服务器上的文件路径。
# 配置RTSP请求方式为Describe方式。
[Sysname] nqa template rtsp rtsptplt
[Sysname-nqatplt-rtsp-rtsptplt] request method describe
· url
reset nqa twamp-light statistics命令用来清除TWAMP-light测试会话的统计信息。
reset nqa twamp-light statistics { all | test-session session-id }
context-admin
all:清除所有TWAMP-light测试会话的统计信息
test-session session-id:清除指定的TWAMP-light测试会话的统计信息。session-id表示测试会话的ID,取值范围为1~256。
TWAMP-light会话统计信息清除后将无法恢复。在执行reset twamp-light statistics命令前请确认是否进行清除。
# 清除所有TWAMP-light测试会话的统计信息。
<Sysname> reset nqa twamp-light statistics all
· display nqa twamp-light client statistic
resolve-target命令用来配置要解析的域名。
undo resolve-target命令用来恢复缺省情况。
resolve-target domain-name
undo resolve-target
未配置要解析的域名。
DNS测试类型视图
DNS类型的NQA模板视图
context-admin
domain-name:要解析的域名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过255个字符,区分大小写。字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
# 在DNS测试类型下配置DNS测试要解析的域名为domain1。
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
# 在DNS类型的NQA模板视图下配置测试要解析的域名为domain1。
[Sysname-nqatplt-dns-dnstplt] resolve-target domain1
resolve-type命令用来配置域名解析类型。
undo resolve-type命令用来恢复缺省情况。
resolve-type { A | AAAA }
undo resolve-type
域名解析类型为A类型。
DNS类型的NQA模板视图
context-admin
A:域名解析类型为A类型请求,即将域名解析为IPv4地址。
AAAA:域名解析类型为AAAA类型请求,即将域名解析为IPv6地址。
# 在DNS类型的NQA模板视图下,配置测试的域名解析类型为A。
[Sysname-nqatplt-dns-dnstplt] resolve-type A
resource-release { data-fill | hex-data-fill }命令用来配置向服务器发送的资源释放报文。
undo resource-release命令用来恢复缺省情况。
resource-release { data-fill | hex-data-fill } string
未配置向服务器发送的资源释放报文。
TCP/UDP类型的NQA模板视图
context-admin
data-fill:表示使用文本格式的字符串来填充探测报文。
hex-data-fill:表示使用十六进制字符串来填充探测报文。
string:探测报文的填充内容。和data-fill关键字配合使用时,为1~200个字符的字符串,区分大小写;和hex-data-fill关键字配合使用时,为2~200个字符的字符串,字符串长度必须是偶数且不区分大小写。
配置本命令后,设备会给服务器发送包含指定字符串的报文,用来通知服务器本次测试结束,要求服务器关闭连接并释放相应资源。
# 在TCP类型的NQA模板视图下配置探测报文的填充字符串为abcd。
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] resource-release data-fill abcd
reth-member probe enable命令用来开启以太网冗余接口的成员接口所在链路的连通性检测功能。
undo reth-member probe enable命令用来关闭以太网冗余接口的成员接口所在链路的连通性检测功能。
以太网冗余接口的成员接口所在链路的连通性检测功能处于关闭状态。
ICMP-echo测试类型视图
context-admin
将ICMP-echo测试应用于以太网冗余接口组网环境:
· 缺省情况下,NQA探测报文的出接口只能配置为以太网冗余接口,用来探测以太网冗余接口所在链路的连通性。如果将NQA探测报文的出接口配置为以太网冗余接口的成员接口,会导致探测失败。
· 配置本命令后:
¡ 如果将NQA探测报文的出接口配置为以太网冗余接口,设备仍使用以太网冗余接口发送NQA探测报文,探测的是以太网冗余接口所在链路的连通性。
¡ 如果将NQA探测报文的出接口配置为以太网冗余接口的成员接口,不管是激活状态的还是非激活状态的成员接口,设备均也会使用配置的接口发送NQA探测报文,探测该接口所在链路的连通性。
使用该功能,配置两个ICMP-echo测试,其NQA探测报文的出接口分别配置为以太网冗余接口的两个成员接口,可帮助管理员尽快发现两个成员接口所在链路是否通畅。
# 开启以太网冗余接口的成员接口所在链路的连通性检测功能。
[Sysname-nqa-admin-test-icmp-echo] reth-member probe enable
· out interface
route-option bypass-route命令用来开启路由表旁路功能,探测直连目的地的连通情况。
undo route-option bypass-route命令用来关闭路由表旁路功能。
路由表旁路功能处于关闭状态。
UDP-tracert测试类型视图
ICMP-jitte/UDP-jitter/Voice测试类型视图
context-admin
开启该功能后,将不进行路由查找,而直接将报文发送到直连网络的目的地。
开启该功能后,设备转发探测报文可以经过的最大跳数为1,ttl命令设置的跳数不会生效。
测试目的端使用IPv6地址时,本命令配置无效。
# 在ICMP-echo测试类型下开启路由旁路功能。
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface命令用来配置探测帧的源AC口。
undo source interface命令用来恢复缺省情况。
source interface interface-type interface-number [ service-instance instance-id ]
未配置探测帧的源AC口。
context-admin
interface-type interface-number:源接口的接口类型和接口编号。
service-instance:以太网服务实例,二层以太网接口要通过以太网服务实例和源接口来获取源AC口。instance-id:以太网服务实例编号,取值范围为1~4096。
在二层VPN网络中进行的网络性能测试,执行本命令是通过将二层以太网接口和以太网服务实例相关联,生成在VPN网络中发送探测报文的源AC口。
在三层网络中进行测试时,执行本命令是将三层以太网接口作为探测报文的源接口。
执行本命令时,需要注意:
· 本命令指定的接口必须处于UP状态,否则探测将会失败。
· 本命令中指定的接口为二层接口时,必须通过service-instance instance-id参数指定以太网服务实例。
· 本命令中指定的接口为三层接口时:
¡ 在MPLS L3VPN网络中,不需要配置service-instance参数。
¡ 在MPLS L2VPN网络中,service-instance参数可选。该参数用于当指定的三层接口切换为二层接口时,不需要停止、修改、重启该测试,只需要修改MPLS L2VPN的相关配置即可,该测试即可继续运行。
# 在TWAMP-light测试的Client-session视图下,指定二层以太网接口为GigabitEthernet1/2/5/1。
[Sysname-nqa-twamp-light-client-session1] source interface gigabitethernet 1/2/5/1
· source ip
source interface命令用来配置指定接口的IP地址作为探测报文的源IP地址。
以报文发送接口的主IP地址作为探测报文中的源IP地址。
ICMP-echo测试类型视图
UDP-tracert测试类型视图
ICMP类型的NQA模板视图
context-admin
interface-type interface-number:探测报文源接口的接口类型和接口编号。
对于ICMP-echo测试类型及ICMP类型的NQA模板,本命令与source ip、source ipv6命令作用相同,多次执行这三条命令时,最后一次执行的命令生效;对于UDP-tracert测试类型,本命令与source ip命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下指定接口GigabitEthernet1/2/5/1的IP地址作为ICMP-echo探测报文的源IP地址。
[Sysname-nqa-admin-test-icmp-echo] source interface gigabitethernet 1/2/5/1
# 在ICMP类型的NQA模板视图下指定接口GigabitEthernet1/2/5/1的IP地址作为ICMP-echo探测报文的源IP地址。
[Sysname-nqatplt-icmp-icmptplt] source interface gigabitethernet 1/2/5/1
· source ip
· source ipv6
source ip命令用来配置探测报文的源IPv4地址。
undo source ip命令用来恢复缺省情况。
source ip ip-address
undo source ip
以报文发送接口的主IP地址作为探测报文中的源IPv4地址。
ARP/DHCP/DLSw/FTP/HTTP/SNMP测试类型视图
UDP-tracert测试类型视图
任意类型的NQA模板视图
context-admin
ip-address:探测报文的源IPv4地址。
source ip命令配置的源IP地址必须是设备上接口的IPv4地址,且接口为up状态,否则测试将会失败。
对于NQA模板类型来说,当源地址类型和目的地址类型不一致时,以目的地址类型为准,进行该类型的报文探测,此时源地址的配置不生效。
对于ICMP-echo/UDP-tracert测试类型及ICMP类型的NQA模板,本命令和source interface命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下配置ICMP-echo探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
# 在ICMP类型的NQA模板视图下配置探测报文中的源IPv4地址为10.1.1.1。
[Sysname-nqatplt-icmp-icmptplt] source ip 10.1.1.1
· source interface
source ipv6命令用来配置探测报文的源IPv6地址。
undo source ipv6命令用来恢复缺省情况。
source ipv6 ipv6-address
undo source ipv6
对于TWAMP-light测试,未配置测试操作中探测报文的源IPv6地址;对于其他测试类型,以报文发送接口的IPv6地址作为探测报文中的源IPv6地址。
ICMP-echo/TCP/UDP-echo/UDP-jitter测试类型视图
DNS/FTP/HTTP/HTTPS/ICMP/IMAP/POP3/RADIUS认证探测/RADIUS-ACCOUNT计费探测/RTSP/SMTP/SNMP/SNMP-DCA/SSL/TCP/TCP Half Open/UDP/WAP类型的NQA模板视图
context-admin
ipv6-address:探测报文的源IPv6地址,不支持IPv6链路本地地址。
source ipv6命令配置的源IPv6地址必须是设备上接口的IPv6地址,且接口为up状态,否则测试将会失败。
对于ICMP-echo测试类型及ICMP类型的NQA模板,本命令和source interface命令作用相同,多次执行这两条命令时,最后一次执行的命令生效。
# 在ICMP-echo测试类型下配置ICMP-echo探测报文中的源IPv6地址为1::1。
[Sysname-nqa-admin-test-icmp-echo] source ipv6 1::1
# 在ICMP类型的NQA模板视图下配置探测报文中的源IPv6地址为1::1。
[Sysname-nqatplt-icmp-icmptplt] source ipv6 1::1
· source interface
source mac命令用来配置探测帧的源MAC地址。
undo source mac命令用来恢复缺省情况。
source mac mac-address
undo source mac
对于TWAMP-light测试,未配置探测报文的源MAC地址;其他测试类型,以报文发送接口的MAC地址作为探测帧的源MAC。
context-admin
mac-address:探测帧的源MAC地址,格式为H-H-H。在配置时,可以省去MAC地址中每段开头的“0”,例如:输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
# 在TWAMP-light测试的Client-session视图下,配置探测帧的源MAC地址为1-1-1。
[Sysname-nqa-twamp-light-client-session1] source mac 1-1-1
source port命令用来配置探测报文的源端口号。
undo source port命令用来恢复缺省情况。
source port port-number
undo source port
系统自动选择设备当前空闲的端口号作为探测报文的源端口号。
UDP-echo测试类型视图
SNMP测试类型视图
UDP-tracert测试类型视图
DNS类型的NQA模板视图
context-admin
port-number:探测报文的源端口号,取值范围为1~65535。
对于TWAMP-light测试类型,必须配置本命令;对于其它测试类型,建议使用缺省值即可。
如需配置本命令,要求指定的端口号不能是当前设备中其它服务正在使用的端口号,否则会导致探测失败。
· 通过display tcp和display udp命令显示信息中的Local Addr:port字段,可查看本端正在被使用的IPv4地址及端口号。
· 通过display ipv6 tcp和display ipv6 udp命令显示信息中的LAddr->port字段,可查看本端正在被使用的IPv6地址及端口号。
# 在UDP-echo测试类型下配置探测报文的源端口号为8000。
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] source port 8000
# 在DNS类型的NQA模板视图下配置探测报文的源端口号为8000。
[Sysname-nqatplt-dns-dnstplt] source port 8000
· display ipv6 tcp(三层技术-IP业务命令参考/IPv6基础)
· display ipv6 udp(三层技术-IP业务命令参考/IPv6基础)
· display tcp(三层技术-IP业务命令参考/IP性能优化)
· display udp(三层技术-IP业务命令参考/IP性能优化)
ssl-client-policy命令用来为HTTPS/SSL类型的NQA模板绑定SSL客户端策略。
undo ssl-client-policy命令用来恢复缺省情况。
ssl-client-policy policy-name
未绑定SSL客户端策略。
HTTPS/SSL类型的NQA模板视图
context-admin
policy-name:SSL客户端策略名,为1~31个字符的字符串,不区分大小写。
通过绑定SSL客户端策略与服务器建立SSL连接,确认服务器业务的可用性。
# 在SSL类型的NQA模板视图下配置SSL客户端策略为policy。
[Sysname] nqa template ssl ssltplt
[Sysname-nqatplt-ssl-ssltplt] ssl-client-policy policy
start命令用来启动TWAMP-light测试。
start test-session session-id { permanent | duration duration | packet-count count } [ tx-interval { 10 | 100 | 1000 | 30000 } ] [ time-out timeout ] [ [ statistics-interval statistics-interval ] monitor-time time ]
TWAMP-light测试处于关闭状态。
context-admin
test-session session-id:启动指定的TWAMP-light测试会话测试。session-id表示测试会话的ID,取值范围为1~256。
permanent:指定会话的TWAMP-light测试将一直进行测试。
duration duration:指定会话的TWAMP-light测试的持续时间,duration表示测试持续时间,取值范围为60~300,单位为秒。
packet-count count:指定会话的TWAMP-light测试的发送报文个数,count表示测试报文个数,取值范围100~30000。
tx-interval { 10 | 100 | 1000 | 30000 }:指定报文发送周期,每个周期时间内发送一个报文。取值为10、100、1000、30000,单位为ms,缺省值为100ms。
time-out timeout:指定统计周期内反射报文的超时时间,本参数的取值范围为1~10,单位为秒,缺省值为5。
statistics-interval interval:TWAMP-light测试的统计周期,每间隔周期时间统计一次报文收发的服务质量并上报统计结果。单位为毫秒,取值范围为1000~6000000。统计周期必须是10ms的整数倍。本参数的缺省值与报文发送周期的取值有关,详情请参见表1-14。
monitor-time time:TWAMP-light测试的报文监控时间。取值范围为1000~86400000,单位为毫秒。监控时间必须是统计周期的整数倍。
TWAMP-light测试包括按需测试和连续测试两种方式。
· 按需测试是指有限的时间内为了诊断而由人工干预发起的性能检测,可以实现在诊断期间单次的性能检测。
会话在达到指定的时间间隔或者指定的发送报文数量后会自动停止统计。
· 连续测试是指连续、不间断发生的测试动作,直到使用stop (TWAMP-light-sender view)命令手工停止测试为止。
测试启动后,系统将持续监控探测结果,一旦出现不符合阈值的结果出现便启动监控时间计时,当在监控时间段内探测结果始终不符合阈值时,则打印日志并发送告警。不符合阈值的情况如下:
· 在监控时间段内的探测结果始终大于上限阈值。
· 探测结果从大于下限阈值恢复到小于下限阈值则开始计时,在监控时间段内的探测结果始终小于下限阈值。
其中监控时间与monitor-time参数的配置有关:
· 配置monitor-time参数时,会同时将丢包、时延和抖动监控时间配置为相同值。
· 不配置monitor-time参数时,丢包、时延和抖动的监控时间使用缺省值,缺省值与报文发送周期的取值有关,详情请参见表1-14。
阈值告警的上下限阈值由NQA TWAMP-light阈值告警功能配置。
如果同时启动多个TWAMP-light测试,那么每个测试会话指定的源IP、源端口、目的IP和目的端口四个参数不能均相同,否则多个测试匹配同一条流将影响测试结果。
如果配置了data-fill命令,则报文发送周期不允许配置为10ms和100ms。
统计周期建议配置为大于等于报文发送周期,否则将出现上报的统计信息为空的情况。
统计周期和监控时间的缺省值和测试报文发送周期的取值有关,关系如表1-14所示:
报文发送周期 |
统计周期缺省值 |
双向丢包监控时间缺省值 |
双向时延和双向抖动监控时间缺省值 |
10ms |
2s |
60s |
2s |
100ms |
20s |
60s |
20s |
1s |
200s |
200s |
200s |
30s |
600s |
600s |
600s |
# 启动TWAMP-light测试,并指定发送报文数量为3000个。
[Sysname-nqa-twamp-light-sender] start test-session 1 packet-count 3000
· data-fill
· stop (TWAMP-light-sender view)
statistics hold-time命令用来配置统计组的保留时间。
undo statistics hold-time命令用来恢复缺省情况。
statistics hold-time hold-time
统计组的保留时间为120分钟。
context-admin
hold-time:统计组的保留时间,取值范围为1~1440,单位为分钟。
统计组具有老化功能。统计组保存一定时间后将被删除,以便记录新的统计组信息。
# 在ICMP-echo测试类型下配置统计组的保留时间为3分钟。
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics interval命令用来配置对测试结果进行统计的时间间隔。
undo statistics interval命令用来恢复缺省情况。
statistics interval interval
对测试结果进行统计的时间间隔为60分钟。
context-admin
interval:对测试结果进行统计的时间间隔,取值范围为1~35791394,单位为分钟。
NQA将统计时间间隔内完成的NQA测试归为一组,计算该组测试结果的统计值,这些统计值构成一个统计组。通过display nqa statistics命令可以显示该统计组的信息。
# 在ICMP-echo测试类型下配置对测试结果进行统计的时间间隔为2分钟。
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
statistics max-group命令用来配置能够保留的最大统计组个数。
undo statistics max-group命令用来恢复缺省情况。
statistics max-group number
能够保留的最大统计组个数为2。
context-admin
number:能够保留的最大统计组个数,取值范围为0~100。
当保留的统计组数目达到最大值时,如果形成新的统计组,保存时间最久的统计组将被删除。
能够保留的最大统计组个数为0时,不进行统计。
# 在ICMP-echo测试类型下配置能够保留的最大统计组个数为5。
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
stop命令用来停止TWAMP-light测试。
stop { all | test-session session-id }
context-admin
all:停止所有TWAMP-light测试会话的测试。
test-session session-id:停止TWAMP-light测试会话。session-id表示测试会话的编号,取值范围为1~256。
# 停止TWAMP-light测试会话1的测试。
[Sysname-nqa-twamp-light-sender] stop test-session 1
target-only命令用来配置Path-jitter测试中仅针对到达目的地址的完整路径进行探测,不逐跳进行探测。
undo target-only命令用来恢复缺省情况。
target-only
undo target-only
Path-jitter测试中会逐跳进行探测。
Path-jitter测试类型视图
context-admin
# 在Path-jitter测试类型下配置仅针对到达目的地址的完整路径进行探测。
[Sysname-nqa-admin-test-path-jitter] target-only
test-accuracy命令用来配置TWAMP-light Client端测试的精度。
undo test-accuracy命令用来恢复测试精度的默认值。
test-accuracy { microsecond | millisecond }
undo test-accuracy
缺省情况下,TWAMP-light Client端测试的精度为微秒级。
context-admin
microsecond:测试精度为微秒级。
millisecond:测试精度为毫秒级。
该命令用来控制TWAMP-light Client测试的精度,当一些设备因为硬件原因,支持的精度达不到微秒级时,从而导致计算结果出错时,可以使用该命令来调整测试精度。
在配置该命令前,必须停止当前正在探测的TWAMP-light会话。
# 配置TWAMP-light Client的测试精度为毫秒级。
[Sysname-nqa-twamp-light-client] test-accuracy millisecond
test-session命令用来创建TWAMP-light Client端的测试会话,并进入Client-session视图。如果TWAMP-light Client端的测试会话已经存在,则直接进入Client-session视图。
undo test-session命令用来删除TWAMP-light Client端的测试会话。
undo test-session session-id
不存在TWAMP-light Client端的测试会话。
context-admin
session-id:表示测试会话的ID。取值范围为1~256。
请创建TWAMP-light Client端的测试会话并完成会话相关参数的配置后,再通过nqa twamp-light sender命令进入TWAMP-light-sender视图启动TWAMP-light测试。
# 创建TWAMP-light Client端的测试会话1,并进入Client-session1视图。
timestamp-format命令用来配置TWAMP-light测试探测报文的时间戳格式。
undo timestamp-format命令用来恢复缺省情况。
timestamp-format { ntp | ptp }
TWAMP-light测试的时间戳格式为PTP。
context-admin
ntp:配置探测报文的时间戳格式为NTP。
ptp:配置探测报文的时间戳格式为PTP。
TWAMP-light测试的探测报文会携带时间戳,本命令用来配置测试时报文携带的时间戳封装格式。相比NTP时间戳格式,PTP时间戳格式可携带更高精度的时间,可使TWAMP-light测试结果更精确。
使用本命令时,如果设备未达到NTP或者PTP时间同步,或者TWAMP-light Sender端和Responder端使用的时间戳格式不同,设备都可以进行TWAMP-light测试,只是测试结果的精确度会有差异。
# 配置TWAMP-light测试的时间戳格式为NTP。
[Sysname-nqa-twamp-light-client-session1] timestamp-format ntp
tos命令用来配置NQA探测报文IP报文头中服务类型域的值。
undo tos命令用来恢复缺省情况。
tos value
undo tos
NQA探测报文IP报文头中服务类型域的值为0。
任意测试类型视图
DNS/FTP/HTTP/HTTPS/ICMP/IMAP/POP3/RADIUS认证探测/RADIUS-ACCOUNT计费探测/RTSP/SIP/SMTP/SNMP/SNMP-DCA/SSL/TCP/TCP Half Open/UDP/WAP类型的NQA模板视图
context-admin
value:探测报文IP报文头中服务类型域的值,取值范围为0~255。
# 在ICMP-echo测试类型下配置探测报文IP报文头中服务类型域的值为1。
[Sysname-nqa-admin-test-icmp-echo] tos 1
# 在ICMP类型的NQA模板视图下配置探测报文IP报文头中服务类型域的值为1。
[Sysname-nqatplt-icmp-icmptplt] tos 1
transport-protocol命令用来配置SIP测试使用的传输协议。
undo transport-protocol命令用来恢复缺省情况。
transport-protocol { tcp | udp }
SIP测试使用的传输协议为UDP。
SIP类型的NQA模板视图
context-admin
tcp:使用TCP连接发起SIP探测。
udp:使用UDP连接发起SIP探测。
修改NQA模板下SIP使用的传输协议后,系统将会停止使用该模板的已有SIP探测,并发起一个新的探测请求。
# 配置SIP测试使用的传输协议为TCP。
[Sysname] nqa template sip siptplt
[Sysname-nqatplt-sip-siptplt] transport-protocol tcp
ttl命令用来配置探测报文在网络中可以经过的最大跳数。
undo ttl命令用来恢复缺省情况。
ttl value
undo ttl
UDP-tracert类型探测报文在网络中可以经过的最大跳数是30跳。其它测试类型下探测报文在网络中可以经过的最大跳数为20跳。
UDP-tracert测试类型视图
context-admin
value:对于UDP-tracert测试类型,表示允许探测报文填充的最大跳数值;对于其它测试类型,表示探测报文在网络中可以经过的最大跳数。取值范围为1~255。
配置route-option bypass-route命令后,探测报文在网络中可以经过的最大跳数为1,ttl命令不会生效。
配置UDP-tracert类型测试时,如果使用init-ttl命令配置的初始跳数值大于此值,测试将无法启动。
# 在ICMP-echo测试类型下配置探测报文在网络中可以经过的最大跳数为16跳。
[Sysname-nqa-admin-test-icmp-echo] ttl 16
# 在ICMP类型的NQA模板视图下配置探测报文在网络中可以经过的最大跳数为16跳。
[Sysname-nqatplt-icmp-icmptplt] ttl 16
type命令用来配置当前测试组的测试类型,并进入测试组测试类型视图。
type { arp | dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | path-jitter | snmp | tcp | udp-echo | udp-jitter | udp-tracert | voice }
未配置当前测试组的测试类型。
NQA测试组视图
context-admin
arp:测试类型为ARP。
dhcp:测试类型为DHCP。
dlsw:测试类型为DLSw。
dns:测试类型为DNS。
ftp:测试类型为FTP。
http:测试类型为HTTP。
icmp-echo:测试类型为ICMP-echo。
icmp-jitter:测试类型为ICMP-jitter。
path-jitter:测试类型为Path-jitter。
snmp:测试类型为SNMP。
tcp:测试类型为TCP。
udp-echo:测试类型为UDP-echo。
udp-jitter:测试类型为UDP-jitter。
udp-tracert:测试类型为UDP-tracert。
voice:测试类型为Voice。
一个NQA测试组对应一个NQA测试类型。当进入NQA测试组视图后,需要指定测试类型并配置测试类型相应的属性。当NQA测试组指定了一个测试类型后,测试组将与测试类型绑定,若需要重新指定测试类型,请在系统视图下删除测试组之后重新创建测试组并指定测试类型。
# 配置测试组的测试类型为FTP测试,并进入测试组测试类型视图。
url命令用来配置测试访问的网址。
undo url命令用来恢复缺省情况。
url url
undo url
未配置测试访问的网址。
FTP/HTTP测试类型视图
ICMP-echo测试类型视图
UDP-jitter测试类型视图
FTP/HTTP/HTTPS/RTSP/WAP类型的NQA模板视图
context-admin
url:测试操作访问的目标资源地址,为1~255个字符的字符串,区分大小写。url中的主机名部分,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,区分大小写;字符串中可以包含字母、数字、“-”及“_”,不能出现连续“.”。
不同测试类型,url参数的格式不同:
· HTTP测试类型的url格式为http://host/resource或http://host:port/resource,缺省端口号为80。
· HTTPS测试类型的url格式为https://host/resource或https://host:port/resource,缺省端口号为443。
· FTP测试类型的url格式为ftp://host/filename或ftp://host:port/filename,缺省端口号为21。
· ICMP-echo测试类型的URL地址格式可以是任意协议类型加上主机名和端口号,例如http://host:port。其中,主机名必须指定,协议类型和端口号可以不指定。
· UDP-jitter测试类型的URL地址格式可以是任意协议类型加上主机名和端口号,例如http://host:port。其中,主机名和端口号必须指定,协议类型可以不指定。
· RTSP测试类型的url格式为rtsp://host/resource或rtsp://host:port/resource,缺省端口为554。
· WAP测试类型的url格式为http://host/filename、http://host:port/filename、https://host/resource或https://host:port/resource。
url中指定的主机名必须为目的设备的域名,如果指定端口号,则要求端口号必须是目的设备提供服务的端口号。
filename取值范围的详细介绍,请参见“基础配置指导”中的“文件系统管理”。
WAP测试单独配置URL无效,需要配置expect data匹配期望测试成功的应答内容来判断探测是否成功。
对于ICMP-echo测试类型,配置destination ip命令后,不能再配置本命令,反之,配置了本命令后不能再配置destination ip命令。
对于UDP-jitter测试类型,配置了destination ip或destination port命令后,不能再配置本命令,反之,配置了本命令后不能再配置destination ip和destination port命令。
# 在HTTP测试类型下配置HTTP测试访问的网址为http://www.company.com/index.html。
[Sysname-nqa-admin-test-http] url http://www.company.com/index.html
# 在HTTP类型的NQA模板视图下配置测试访问的网址为http://www.company.com/index.html。
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] url http://www.company.com/index.html
username命令用来配置登录用户名。
undo username命令用来恢复缺省情况。
username username
undo username
未配置登录用户名。
FTP/HTTP测试类型视图
FTP/HTTP/HTTPS/IMAP/POP3/RADIUS认证探测/RADIUS-ACCOUNT计费探测类型的NQA模板视图
context-admin
username:测试使用的登录用户名,区分大小写。FTP、HTTP或HTTPS登录用户名,为1~32个字符的字符串;POP3或IMAP登录用户名,为1~40个字符的字符串,形如user1@test.com;RADIUS或RADIUS-ACCOUNT用户名,为1~253个字符的字符串。
# 在FTP测试类型下配置FTP登录用户名为administrator。
[Sysname-nqa-admin-test-ftp] username administrator
# 在FTP类型的NQA模板视图下配置FTP登录用户名为administrator。
[Sysname-nqatplt-ftp-ftptplt] username administrator
· operation
· password
version命令用来配置HTTP/HTTPS测试所使用的版本。
undo version命令用来恢复缺省情况。
version { v1.0 | v1.1 }
undo version
HTTP/HTTPS测试所使用的版本为1.0。
HTTP测试类型视图
context-admin
v1.0:测试使用的版本为1.0。
v1.1:测试使用的版本为1.1。
# 在HTTP测试类型下配置HTTP测试使用的版本为1.1。
[Sysname-nqa-admin-test-http] version v1.1
version命令用来配置SNMP-DCA测试所使用的SNMP版本。
version { v1 | v2c }
undo version
SNMP-DCA测试所使用的SNMP版本为SNMPv1。
SNMP-DCA类型的NQA模板视图
context-admin
v1:SNMPv1版本。
v2c:SNMPv2c版本。
只有本命令配置的版本和测试的SNMP Agent使用的SNMP版本相同时,SNMP-DCA才能正常工作。
# 在SNMP-DCA类型的NQA模板视图下配置SNMP-DCA测试所使用的SNMP版本为SNMPv2c。
[Sysname] nqa template snmpdca test
[Sysname-nqatplt-snmpdca-test] version v2c
vlan命令用来配置探测帧所属的VLAN。
undo vlan命令用来恢复缺省情况。
vlan { vlan-id | s-vid vlan-id c-vid vlan-id }
undo vlan
未配置探测帧所属的VLAN。
context-admin
vlan-id:探测报文所属的VLAN,取值范围为1~4094。
s-vid:匹配外层VLAN标签(Service VLAN ID)。
c-vid:匹配内层VLAN标签(Customer VLAN ID)。
配置该命令后探测帧将在指定的VLAN内发送。
当需要使用封装内外层VLAN标签的报文进行测试时,用户可根据需求来配置探测报文的内外层VLAN。
# 在TWAMP-light测试的Client-session视图下,配置探测帧的所属的VLAN为VLAN 3。
[Sysname-nqa-twamp-light-client-session1] vlan 3
vpn-instance命令用来指定测试操作所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
未指定测试操作所属的VPN,表示在公网中进行NQA测试。
UDP-tracert测试类型视图
任意类型的NQA模板视图
context-admin
vpn-instance-name:表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
配置本命令后,NQA将在指定的VPN中进行测试。
# 在ICMP-echo测试类型下指定测试操作所属的VPN实例为vpn1。
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
# 在FTP类型的NQA模板视图下指定测试操作所属的VPN实例为vpn1。
[Sysname-nqatplt-ftp-ftptplt] vpn-instance vpn1
只有在测试类型为UDP-jitter、TCP、UDP-echo和Voice时,才需要配置NQA服务器。
display nqa server命令用来显示NQA服务器的状态信息。
display nqa server
context-admin
context-operator
# 显示NQA服务器的状态信息。
<Sysname> display nqa server
NQA server status: Enabled
TCP connect:
IP address: 2.2.2.2
Port: 2000
ToS:200
VPN instance: -
UDP echo:
IP address: 3.3.3.3
Port: 3000
ToS: 255
VPN instance: -
High performance mode: Enabled
表1-15 display nqa server命令输出信息描述
描述命令 |
NQA server status |
NQA服务器状态,包括的取值如下: · Disabled:未启用NQA服务器功能; · Enabled:启用了NQA服务器功能; |
TCP connect |
NQA TCP测试中服务器的状态信息 |
UDP echo |
NQA UDP测试中服务器的状态信息 |
IP address |
NQA服务器TCP/UDP监听服务的IP地址 |
Port |
NQA服务器TCP/UDP监听服务的端口号 |
ToS |
NQA服务器TCP/UDP监听服务的回应报文携带的ToS值 |
VPN instance |
NQA服务器监听的IP地址所属的VPN实例名称。如果NQA服务器监听的是公网IP地址,则显示为- |
High performance mode |
NQA服务器的高性能模式,包括的取值如下: · Disabled:未开启NQA服务器高性能模式 · Enabled:开启了NQA服务器高性能模式 |
display nqa twamp-light responder命令用来显示TWAMP-light Responder端的会话信息。
display nqa twamp-light responder [ test-session session-id ]
context-admin
context-operator
test-session session-id:显示指定会话的信息。session-id表示会话ID,取值范围为1~256。未指定本参数时,表示显示所有会话的信息。
# 显示所有TWAMP-light Responder端的会话信息。
<Sysname> display nqa twamp-light responder
Session ID : 1
Status : Active
Interface : -
Service instance : -
Destination IP : 1.1.1.1
Destination IPv6 : -
Source IP : 2.2.2.2
Source IPv6 : -
Destination port : 2001
Source port : 2010
VPN instance : -
Destination MAC : 1-1-2
Source MAC : 1-1-1
VLAN ID : -
Service VLAN ID : -
Customer VLAN ID : -
Timestamp format : PTP
Description : -
Session ID : 2
Status : Active
Interface : -
Source IP : 3.3.3.3
Source IPv6 : -
Source port : 2020
VPN instance : -
Source MAC : 1-1-1
VLAN ID : -
Service VLAN ID : -
Timestamp format : NTP
Description : -
表1-16 display nqa twamp-light responder命令显示信息描述表
Session ID |
会话ID |
Status |
测试会话的工作状态,取值为: · Active:激活状态,表示测试会话的NQA服务器的TWAMP-light Responder的反射功能已被激活 · Inactive:未激活状态,表示测试会话的NQA服务器的TWAMP-light Responder的反射功能未被激活 |
反射端口 |
Service instance |
关联的以太网服务实例 |
Destination IP |
待反射报文的目的IP地址 |
Destination IPv6 |
待反射报文的目的IPv6地址 |
Source IP |
待反射报文的源IP地址 |
Source IPv6 |
待反射报文的源IPv6地址 |
Destination port |
待反射报文的目的端口号 |
Source port |
待反射报文的源端口号 |
VPN instance |
MPLS L3VPN实例名称 |
Destination MAC |
待反射报文的目的MAC地址 |
Source MAC |
待反射报文的源MAC地址 |
VLAN ID |
待反射报文的VLAN ID |
Service VLAN ID |
待反射报文的外层VLAN ID |
Customer VLAN ID |
待反射报文的内层VLAN ID |
Timestamp format |
时间戳格式,取值为: · AUTO:表示由TWAMP-light Responder自动决定使用的时间戳格式。如果用户未通过test-session命令指定时间戳格式,则使用AUTO格式 · NTP:NTP格式 · PTP:PTP格式 |
测试会话的描述信息 |
· nqa reflector
· test-session (TWAMP-light-responder view)
nqa server enable命令用来开启NQA服务器功能。
undo nqa server enable命令用来关闭NQA服务器功能。
nqa server enable
NQA服务器功能处于关闭状态。
context-admin
# 开启NQA服务器功能。
[Sysname] nqa server enable
nqa server tcp-connect命令用来在NQA服务器上创建TCP监听服务。
undo nqa server tcp-connect命令用来删除指定的TCP监听服务。
nqa server tcp-connect { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server tcp-connect { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ]
不存在TCP监听服务
context-admin
ipv4-address:NQA服务器TCP监听服务监听的IPv4地址。
ipv6-address:NQA服务器TCP监听服务监听的IPv6地址。
port-number:NQA服务器TCP监听服务监听的端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示TCP监听的是公网IP地址。
tos tos:NQA服务器应答报文中的ToS域的值。取值范围为0~255,缺省值为0。
仅TCP和DLSw测试类型下必须配置本命令,且对于DLSw测试类型,port-number值必须为2065。否则,测试失败。
所配置的IP地址、端口号及VPN实例必须与NQA客户端的配置一致,且不能与已有的监听服务冲突。
所配置的IP地址必须是作为服务器的设备上的接口的IP地址,否则配置无效。
建议不要配置1~1023之间的端口(知名端口),否则可能导致NQA测试失败或该知名端口对应的服务不可用。
# 创建IP地址为169.254.10.2,端口号为9000的TCP监听服务。
[Sysname] nqa server tcp-connect 169.254.10.2 9000
· destination ip
· destination port
· vpn-instance
nqa server udp-echo命令用来在NQA服务器上创建UDP监听服务。
undo nqa server udp-echo命令用来删除指定的UDP监听服务。
nqa server udp-echo { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ] [ high-performance-mode ] [ tos tos ]
undo nqa server udp-echo { ipv4-address | ipv6 ipv6-address } port-number [ vpn-instance vpn-instance-name ]
不存在UDP监听服务
context-admin
ipv4-address:NQA服务器UDP监听服务监听的IPv4地址。
ipv6-address:NQA服务器UDP监听服务监听的IPv6地址。
port-number:NQA服务器UDP监听服务监听的端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:NQA服务器监听的IP地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则表示UDP监听的是公网IP地址。
high-performance-mode:开启NQA服务器端对于UDP-jitter测试的高性能模式。不指定本参数则NQA服务器对于UDP-jitter测试的高性能模式处于关闭状态。
只有在测试类型为UDP-jitter、UDP-echo或Voice时,才需在NQA服务器上配置此命令。
通过本命令可以指定发送应答NQA探测报文(UDP报文)中携带的ToS值。
在高性能模式下,NQA服务器将大大提升UDP-jitter测试的探测报文应答效率。此时NQA服务器端不能处理大于100字节的NQA报文,若客户端发送的报文长度大于100字节,可能导致NQA测试失败。
当有多个UDP监听服务对于UDP-jitter测试需要开启高性能模式时,可以通过nqa server udp-echo high-performance enable命令开启NQA服务器的所有UDP监听服务对于UDP-jitter测试的高性能模式。
# 创建IP地址为169.254.10.2、端口号为9000的UDP监听服务。
[Sysname] nqa server udp-echo 169.254.10.2 9000
· destination ip
· destination ipv6
· destination port
· vpn-instance
· nqa server udp-echo high-performance enable
nqa server udp-echo high-performance enable命令用来全局开启NQA服务器UDP监听服务对于UDP-jitter测试的高性能模式。
undo nqa server udp-echo high-performance enable命令用来全局关闭NQA服务器UDP监听服务对于UDP-jitter测试的高性能模式。
NQA服务器UDP监听服务的高性能模式处于全局关闭状态。
用户可单独开启或全局开启UDP监听服务对于UDP-jitter测试的高性能模式。
· 全局开启即开启所有UDP监听服务对于UDP-jitter测试的高性能模式,单独开启则只能开启某个UDP监听服务对于UDP-jitter测试的高性能模式。
· 从全局开启和单独开启都能开启UDP监听服务对于UDP-jitter测试的高性能模式,但若要关闭UDP监听服务对于UDP-jitter测试的高性能模式,则必须将全局和单独的UDP监听服务对于UDP-jitter测试的高性能模式都关闭。
# 全局开启NQA服务器UDP监听服务对于UDP-jitter测试的高性能模式。
[Sysname] nqa server udp-echo high-performance enable
nqa twamp-light responder命令用来创建TWAMP-light Responder,并进入TWAMP-light-responder视图。如果TWAMP-light Responder已经存在,则直接进入TWAMP-light-responder视图。
undo nqa twamp-light responder命令用来删除TWAMP-light Responder。
不存在TWAMP-light Responder。
context-admin
在TWAMP-light-responder视图下创建与TWAMP-light Client测试会话相对应的测试会话,从而与TWAMP-light Client测试会话进行交互。
执行undo nqa twamp-light responder命令时,系统会删除Responder以及所有的会话信息。
# 创建TWAMP-light Responder,并进入TWAMP-light-responder视图。
[Sysname] nqa twamp-light responder
[Sysname-nqa-twamp-light-responder]
test-session命令用来配置TWAMP-light Responder端的测试会话。
undo test-session命令用来删除TWAMP-light Responder端的测试会话。
test-session session-id [ interface interface-type interface-number [ service-instance instance-id ] ] { { ip | ipv6 } destination address source address destination-port port-number source-port port-number [ vpn-instance vpn-instance-name ] | destination-mac mac-address source-mac mac-address } * [ vlan { vlan-id | s-vid vlan-id c-vid vlan-id } | timestamp-format { ntp | ptp } | description text ] *
未配置TWAMP-light Responder端的测试会话。
context-admin
interface interface-type interface-number:测试会话中反射报文的接口。interface-type interface-number表示接口类型和接口编号。
service-instance instance-id:测试会话关联的以太网服务实例,instance-id为以太网服务实例编号,取值范围为1~4096。
ip:待反射报文的IPv4地址。
ipv6:待反射报文的IPv6地址。
destination:待反射报文的目的地址。指定ip参数时表示IPv4地址,指定ipv6参数时表示IPv6地址。
source:待反射报文的源地址。指定ip参数时表示IPv4地址,指定ipv6参数时表示IPv6地址。
address:IP地址。
destination-port port-number:测试会话待反射报文的目的UDP端口号,port-number表示UDP端口号,取值范围为1~65535。
source-port port-number:测试会话待反射报文的源UDP端口号。port-number表示UDP端口号,取值范围为1~65535。
vpn-instance vpn-instance-name:表示在指定VPN中进行测试。vpn-instance-name表示MPLS L3VPN的VPN实例名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示在公网中进行测试。
destination-mac:测试会话待反射报文的目的MAC地址。
source-mac:测试会话待反射报文的源MAC地址。
mac-address:MAC地址。格式为H-H-H。在配置时,可以省去MAC地址中每段开头的“0”,例如:输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan:测试会话待反射报文的VLAN或内外层VLAN标签。
· vlan-id:VLAN的编号,取值范围为1~4094。
· s-vid:外层VLAN标签(Service VLAN ID)。
· c-vid:内层VLAN标签(Customer VLAN ID)。
timestamp-format:TWAMP-light Responder端的时间戳格式。缺省值为AUTO,AUTO表示由TWAMP-light Responder端自动选择使用的时间戳格式。
· ntp:NTP时间戳格式。
· ptp:PTP时间戳格式。
· ntp:NTP时间戳。
· ptp:PTP时间戳。
description text:测试会话的描述信息。text表示描述信息,为1~200个字符的字符串,区分大小写。使用本参数可为测试会话增加描述信息,方便用户查看和管理测试会话。
TWAMP-light Responder端的测试会话是与TWAMP-light Client测试会话相对应的测试会话,用于和TWAMP-light Client测试会话进行交互。
本命令指定的发送端IP地址、反射端IP地址、发送端UDP端口号、反射端UDP端口号以及VPN实例名组成的五元组信息需要和TWAMP-light Client测试会话的信息相互对应。
当创建的会话ID不存在,则创建一个新的会话;如果指定的会话ID已存在,则对会话信息进行修改。
一个会话ID只能指定一个反射接口和以太网服务实例,但多个会话ID可以指定同一个反射接口和以太网服务实例;一旦指定了反射接口和以太网服务实例则无法更改,只能通过undo test-session命令删除对应的会话后重新指定;已配置的会话相关参数除反射接口和以太网服务实例外,均可以修改或删除,但若删除掉所有配置,那么该测试会话也会一同删除。
# 创建TWAMP-light Responder端的测试会话1,并指定源IPv4地址为1.1.1.1.,目的IPv4地址为2.2.2.2,源端口为3000,目的端口为3001,VPN实例名称为vpn1。
[Sysname-nqa-twamp-light-responder] test-session 1 ip destination 2.2.2.2 source 1.1.1.1 destination-port 3001 source-port 3000 vpn-instance vpn1
