06-WLAN RRM命令
本章节下载: 06-WLAN RRM命令 (298.58 KB)
1.1.1 calibrate-bandwidth self-decisive
1.1.2 calibrate-channel 2.4g channel-usage-threshold
1.1.3 calibrate-channel 2.4g crc-error-threshold
1.1.4 calibrate-channel 2.4g interference-threshold
1.1.5 calibrate-channel 2.4g noise-threshold
1.1.6 calibrate-channel 2.4g receive-service-traffic threshold
1.1.7 calibrate-channel 2.4g retransmission-threshold
1.1.8 calibrate-channel 2.4g tolerance-level
1.1.9 calibrate-channel 5g channel-usage-threshold
1.1.10 calibrate-channel 5g crc-error-threshold
1.1.11 calibrate-channel 5g interference-threshold
1.1.12 calibrate-channel 5g noise-threshold
1.1.13 calibrate-channel 5g receive-service-traffic threshold
1.1.14 calibrate-channel 5g retransmission-threshold
1.1.15 calibrate-channel 5g tolerance-level
1.1.16 calibrate-channel self-decisive
1.1.17 calibrate-power 2.4g adjacency-factor
1.1.18 calibrate-power 2.4g min
1.1.19 calibrate-power 2.4g threshold
1.1.20 calibrate-power 5g adjacency-factor
1.1.22 calibrate-power 5g threshold
1.1.23 calibrate-power self-decisive
1.1.24 display wlan rrm baseline
1.1.25 display wlan rrm baseline apply-history
1.1.26 display wlan rrm-history ap
1.1.27 display wlan rrm-status ap
1.1.28 wlan calibrate-channel pronto ap all
1.1.29 wlan calibrate-power pronto ap all
1.1.30 wlan rrm baseline apply
1.1.31 wlan rrm baseline remove
1.1.33 wlan rrm calibration-bandwidth interval
1.1.34 wlan rrm calibration-channel ap
1.1.35 wlan rrm calibration-channel interval
1.1.36 wlan rrm calibration-power interval
calibrate-bandwidth self-decisive enable命令用来开启自动频宽调整。
undo calibrate-bandwidth self-decisive命令用来恢复缺省情况。
自动频宽调整处于关闭状态。
全局配置视图
当某射频的邻居Radio数量过多时,需要降低频宽,以减少干扰;当某射频的邻居Radio数量较少时,需要增大频宽,以提高数据传输速率。增大频宽或减小频宽是通过将相邻的信道绑定或拆分完成的。
开启自动频宽调整后,设备在每一个自动频宽调整周期到达时,都会开始频宽调整流程。
本命令仅对5GHz频段射频生效。
# 开启设备的5GHz频段射频的自动频宽调整功能。
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] calibrate-bandwidth self-decisive enable
calibrate-channel 2.4g channel-usage-threshold命令用来配置2.4GHz频段信道使用率门限值。
undo calibrate-channel 2.4g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g channel-usage-threshold percent percent
undo calibrate-channel 2.4g channel-usage-threshold percent
2.4GHz频段信道使用率门限值为60。
全局配置视图
percent percent:信道使用率门限值,以百分比表示,取值范围为1~100。
在满足以下所有条件时,设备将进行信道质量计算:
· 射频口在当前信道收发的报文占报文处理能力的百分比达到门限值;
· 干扰在信道使用率中的占比达到门限值;
· 射频接收流量中业务流量未达到设定的阈值。
# 配置2.4GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-usage-threshold percent 40
· calibrate-channel 2.4g interference-threshold
· calibrate-channel 2.4g receive-service-traffic threshold
calibrate-channel 2.4g crc-error-threshold命令用来配置2.4GHz频段信道的CRC错误门限值。
undo calibrate-channel 2.4g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g crc-error-threshold percent
2.4GHz频段信道的CRC错误门限值为0。
全局配置视图
percent:CRC错误门限值,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不考虑CRC错误门限值。
CRC错误门限值是触发自动信道调整的条件之一。当设备检测到2.4GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
# 配置2.4GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g crc-error-threshold 10
calibrate-channel 2.4g interference-threshold命令用来配置2.4GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 2.4g interference-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g interference-threshold percent percent
undo calibrate-channel 2.4g interference-threshold percent
2.4GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
percent percent:干扰在信道使用率中的占比门限值,以百分比表示,取值范围为0~100。
增大门限值将降低自动信道调整的概率,减小门限值将提高自动信道调整的概率。
# 配置2.4GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g interference-threshold percent 50
· calibrate-channel 2.4g channel-usage-threshold
calibrate-channel 2.4g noise-threshold命令用来配置2.4GHz频段信道噪声门限值。
undo calibrate-channel 2.4g noise-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g noise-threshold value
2.4GHz频段信道噪声门限值为0。
全局配置视图
value:噪声门限值,取值范围为0~127,代表功率范围为0~-127dBm,即噪声门限值越大,表示的噪声越小。取值为0时表示自动信道调整不考虑噪声因素。
噪声门限值是触发自动信道调整的条件之一。当设备检测到2.4GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置2.4GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g noise-threshold 50
calibrate-channel 2.4g receive-service-traffic threshold命令用来配置2.4GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 2.4g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 2.4g receive-service-traffic threshold value
2.4GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
threshold value:业务流量阈值,取值范围为0~1000,单位为Mbps。
设备对2.4GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置2.4GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g receive-service-traffic threshold 30
calibrate-channel 2.4g retransmission-threshold命令用来配置2.4GHz频段信道重传门限值。
undo calibrate-channel 2.4g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 2.4g retransmission-threshold value
2.4GHz频段信道重传门限值为0。
全局配置视图
value:重传门限值,取值范围为0~100,单位为百分比。取值为0时表示自动信道调整不考虑重传因素。
重传是触发自动信道调整的条件之一。当设备检测到2.4GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置2.4GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g retransmission-threshold 50
calibrate-channel 2.4g tolerance-level命令用来配置2.4GHz频段信道的容限系数。
undo calibrate-channel 2.4g tolerance-level命令用来恢复缺省情况。
calibrate-channel 2.4g tolerance-level percent
2.4GHz频段信道的容限系数为1。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示2.4GHz频段信道在进行自动信道调整时不考虑容限系数。
容限系数为信道调整前后,两信道的信道质量差值。
设备开始计算信道质量后,只有在备选信道质量优于当前信道且达到或超过容限系数时,备选信道才会被应用。
# 配置2.4GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 2.4g tolerance-level 10
calibrate-channel 5g channel-usage-threshold命令用来配置5GHz频段信道使用率门限值。
undo calibrate-channel 5g channel-usage-threshold命令用来恢复缺省情况。
calibrate-channel 5g channel-usage-threshold percent percent
undo calibrate-channel 5g channel-usage-threshold percent
5GHz频段信道使用率门限值为60。
全局配置视图
# 配置5GHz频段信道使用率门限值为40。
[Sysname-wlan-global-configuration] calibrate-channel 5g channel-usage-threshold percent 40
· calibrate-channel 5g interference-threshold
· calibrate-channel 5g receive-service-traffic threshold
calibrate-channel 5g crc-error-threshold命令用来配置5GHz频段信道的CRC错误门限值。
undo calibrate-channel 5g crc-error-threshold命令用来恢复缺省情况。
calibrate-channel 5g crc-error-threshold percent
5GHz频段信道的CRC错误门限值为0。
全局配置视图
CRC错误门限值是触发自动信道调整的条件之一。当设备检测到5GHz频段信道中CRC错误的帧占所有802.11帧的百分比达到或超过设定值时,将触发自动信道调整。
# 配置5GHz频段信道的CRC错误门限值为10,即CRC错误率达到或超过10%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g crc-error-threshold 10
calibrate-channel 5g interference-threshold命令用来配置5GHz频段干扰在信道使用率中的占比门限值。
undo calibrate-channel 5g interference-threshold命令用来恢复缺省情况。
calibrate-channel 5g interference-threshold percent percent
undo calibrate-channel 5g interference-threshold percent
5GHz频段干扰在信道使用率中的占比门限值为70。
全局配置视图
# 配置5GHz频段干扰在信道使用率的占比门限值为50%。
[Sysname-wlan-global-configuration] calibrate-channel 5g interference-threshold percent 50
· calibrate-channel 5g channel-usage-threshold
calibrate-channel 5g noise-threshold命令用来配置5GHz频段信道噪声门限值。
undo calibrate-channel 5g noise-threshold命令用来恢复缺省情况。
calibrate-channel 5g noise-threshold value
5GHz频段信道噪声门限值为0。
全局配置视图
value:噪声门限值,取值范围为0~127,代表功率范围为0~-127dBm,即噪声门限值越大,表示噪声越小。取值为0时表示自动信道调整不考虑噪声因素。
噪声门限值是触发自动信道调整的条件之一。当设备检测到5GHz频段信道中的噪声达到或超过设定的门限值时,将触发自动信道调整。
# 配置5GHz频段信道噪声门限值为50,即噪声达到或超过-50dBm时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g noise-threshold 50
calibrate-channel 5g receive-service-traffic threshold命令用来配置5GHz频段射频接收流量中业务流量阈值。
undo calibrate-channel 5g receive-service-traffic threshold命令用来恢复缺省情况。
calibrate-channel 5g receive-service-traffic threshold value
5GHz频段射频接收流量中业务流量阈值为10Mbps。
全局配置视图
设备对5GHz频段射频接收的流量进行判断。若接收流量中的业务流量达到设定的阈值,则表示终端与射频间的流量为正常的业务流量;若未达到设定的阈值,则表示射频接收了大量的干扰流量,需要对当前的工作信道进行调整。
# 配置5GHz频段射频接收流量中业务流量阈值为30Mbps。
[Sysname-wlan-global-configuration] calibrate-channel 5g receive-service-traffic threshold 30
calibrate-channel 5g retransmission-threshold命令用来配置5GHz频段信道重传门限值。
undo calibrate-channel 5g retransmission-threshold命令用来恢复缺省情况。
calibrate-channel 5g retransmission-threshold value
5GHz频段信道重传门限值为0。
全局配置视图
重传是触发自动信道调整的条件之一。当设备检测到5GHz频段信道的重传率达到或超过设定的门限值时,将触发自动信道调整。
# 配置5GHz频段信道重传门限值为50,即重传率达到或超过50%时触发自动信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g retransmission-threshold 50
calibrate-channel 5g tolerance-level命令用来配置5GHz频段信道的容限系数。
undo calibrate-channel 5g tolerance-level命令用来恢复缺省情况。
calibrate-channel 5g tolerance-level percent
5GHz频段信道的容限系数为0。
全局配置视图
percent:容限系数,取值范围为0~100,单位为百分比。取值为0时表示5GHz频段信道在进行自动信道调整时不考虑容限系数。
# 配置5GHz频段信道的容限系数为10,即两信道的信道质量差值达到或超过10时进行信道调整。
[Sysname-wlan-global-configuration] calibrate-channel 5g tolerance-level 10
calibrate-channel self-decisive enable命令用来开启自动信道调整。
undo calibrate-channel self-decisive enable命令用来恢复缺省情况。
calibrate-channel self-decisive enable { 2.4g | 5g | all }
undo calibrate-channel self-decisive enable { 2.4g | 5g | all }
自动信道调整处于关闭状态。
全局配置视图
2.4g:开启或关闭设备的2.4GHz频段射频的自动信道调整功能。
5g:开启或关闭设备的5GHz频段射频的自动信道调整功能。
all:开启或关闭设备的2.4GHz和5GHz频段射频的自动信道调整功能。
开启自动信道调整后,设备将按照自动信道调整模式来执行信道的检测、评估和调整。
# 开启设备的2.4GHz和5GHz频段射频的自动信道调整功能。
[Sysname-wlan-global-configuration] calibrate-channel self-decisive enable all
calibrate-power 2.4g adjacency-factor命令用来配置2.4GHz频段邻居因子。
undo calibrate-power 2.4g adjacency-factor命令用来恢复缺省情况。
calibrate-power 2.4g adjacency-factor neighbor
2.4GHz频段邻居因子为1。
全局配置视图
neighbor:邻居因子,取值范围为1~16。
邻居因子既作为功率比较门限,也用于在功率比较时选择一个功率值来和功率调整门限进行比较。
· 功率比较门限:当检测到Radio信息的其它Radio的数目达到功率比较门限,AP才会进行功率比较,判断出是否调整Radio的功率。否则,将Radio的发射功率调整为最大发射功率。以邻居因子等于3为例,则当检测到Radio信息的其它Radio的数目达到3个时,AP才会进行功率比较。
· 选择用于功率比较的功率值:功率比较时,AP会将其它Radio检测到的该Radio功率值进行从大到小排序后,挑选出排名与邻居因子相同的功率值,即,如果邻居因子为3,则选择排名第3位的功率值来和功率调整门限进行比较。
# 配置2.4GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 2.4g adjacency-factor 7
calibrate-power 2.4g min命令用来配置2.4GHz频段射频的最小发射功率。
undo calibrate-power 2.4g min命令用来恢复缺省情况。
calibrate-power 2.4g min tx-power
2.4GHz频段射频的最小发射功率为6dBm。
全局配置视图
tx-power:射频的最小发射功率,取值范围为1~20,单位为dBm。
完成自动功率调整后,射频的发射功率不会小于本命令设置的值。
# 配置2.4GHz频段射频的最小发射功率为15dBm。
[Sysname-wlan-global-configuration] calibrate-power 2.4g min 15
calibrate-power 2.4g threshold命令用来配置2.4GHz频段功率调整门限值。
undo calibrate-power 2.4g threshold命令用来恢复缺省情况。
calibrate-power 2.4g threshold value
功率调整门限值为65。
全局配置视图
threshold value:功率调整门限值,取值范围为1~196,代表功率范围为-1dBm~-196dBm。功率门限值越大,表示功率越小。
需要合理设置门限值,既保证AP上的Radio有较大的覆盖范围,不会出现弱信号,满足正常的使用需求,同时也要减少AP间相互干扰。
# 配置2.4GHz频段功率调整门限值为-70dBm。
[Sysname-wlan-global-configuration] calibrate-power 2.4g threshold 70
calibrate-power 5g adjacency-factor命令用来配置5GHz频段邻居因子。
undo calibrate-power 5g adjacency-factor命令用来恢复缺省情况。
calibrate-power 5g adjacency-factor neighbor
5GHz频段邻居因子为1。
全局配置视图
# 配置5GHz频段邻居因子为7。
[Sysname-wlan-global-configuration] calibrate-power 5g adjacency-factor 7
calibrate-power 5g min命令用来配置5GHz频段射频的最小发射功率。
undo calibrate-power 5g min命令用来恢复缺省情况。
calibrate-power 5g min tx-power
5GHz频段射频的最小发射功率为11dBm。
全局配置视图
# 配置5GHz频段射频的最小发射功率为15dBm。
[Sysname-wlan-global-configuration] calibrate-power 5g min 15
calibrate-power 5g threshold命令用来配置5GHz频段功率调整门限值。
undo calibrate-power 5g threshold命令用来恢复缺省情况。
calibrate-power 5g threshold value
功率调整门限值为65。
全局配置视图
# 配置5GHz频段功率调整门限值为-75dBm。
[Sysname-wlan-global-configuration] calibrate-power 5g threshold 75
calibrate-power self-decisive enable命令用来开启自动功率调整。
undo calibrate-power self-decisive enable命令用来恢复缺省情况。
calibrate-power self-decisive enable { 2.4g | 5g | all }
undo calibrate-power self-decisive enable { 2.4g | 5g | all }
自动功率调整处于关闭状态。
全局配置视图
2.4g:开启或关闭设备的2.4GHz频段射频的自动功率调整功能。
5g:开启或关闭设备的5GHz频段射频的自动功率调整功能。
all:开启或关闭设备的2.4GHz和5GHz频段射频的自动功率调整功能。
开启自动功率调整后,设备在每一个自动功率调整周期到达时,都会开始功率调整流程。
若为射频配置了最大传输功率,则当前射频的自动功率调整功能将失效。
# 开启设备的2.4GHz和5GHz频段射频的自动功率调整功能。
[Sysname-wlan-global-configuration] calibrate-power self-decisive enable all
· wlan rrm calibration-power interval
display wlan rrm baseline命令用来显示射频工作参数基线的信息。
display wlan rrm baseline { all | name baseline-name } [ verbose ]
all:显示所有已保存的射频工作参数基线信息。
name baseline-name:显示已保存的射频工作参数基线信息。其中baseline-name表示基线的名称,为1~32个字符的字符串,不区分大小写。
verbose:显示射频工作参数基线的详细信息。若不指定本参数,则显示基线的概要信息。
射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息时,该用户无法查看此射频工作参数基线。
# 显示所有已保存基线的概要信息。
<Sysname> display wlan rrm baseline all
Baseline name : globalbaseline
Radio range : Global
Created at : 2015-06-22 19:55:12
表1-1 display wlan rrm baseline all命令显示信息描述表
Baseline name |
射频工作参数基线的名称 |
Radio range |
射频工作参数基线中保存的射频的范围 |
Created at |
射频工作参数基线的创建时间 |
# 显示所有已保存射频工作参数基线的详细信息。
<Sysname> display wlan rrm baseline all verbose
APName RadioID RadioType Bandwidth Channel Power RegionCode
fatap 1 dot11an 40 149 20 CN
fatap 2 dot11gn 20 13 20 CN
表1-2 display wlan rrm baseline all verbose命令显示信息描述表
Baseline name |
射频工作参数基线的名称 |
Radio range |
射频工作参数基线中保存的射频的范围 |
Created at |
射频工作参数基线的创建时间 |
APName |
AP的名称 |
RadioID |
射频号 |
RadioType |
射频类型 |
Bandwidth |
射频带宽 |
Channel |
射频工作信道 |
Power |
射频传输功率,单位为dBm |
RegionCode |
AP的区域码 |
display wlan rrm baseline apply-history命令用来显示应用射频工作参数基线的历史信息。
display wlan rrm baseline apply-history [ verbose ]
verbose:射频工作参数基线的详细历史信息。若不指定本参数,则显示射频工作参数基线的简要历史信息。
本命令用来显示最近十次应用射频工作参数基线的历史记录,如果应用不足十次,则显示全部。
# 显示应用射频工作参数基线的简要历史信息。
<Sysname> display wlan rrm baseline apply-history
Applied at : 2016-01-23 12:19:50
Applied to : global
# 显示应用射频工作参数基线的详细历史信息。
<Sysname> display wlan rrm baseline apply-history verbose
Applied to : global
Radios : 3
Success : 2
Failure : 1
Failure reason
Radio doesn't exist : 0
Radio is down : 0
Mismatching radio type : 0
Mismatching region code : 0
Ineffective service template : 0
Illegal channel : 0
Mismatching bandwidth : 1
Channel locked : 0
Channel fixed : 0
Within channel holddown time : 0
Mismatching channel gap policy: 0
Power locked : 0
Within power holddown time : 0
Power lower than min. power : 0
Power greater than max. power : 0
表1-3 display wlan rrm baseline apply-history命令显示信息描述表
Name |
射频工作参数基线的名称 |
Applied at |
射频工作参数基线的应用时间 |
Applied to |
射频工作参数基线的应用范围 |
Radio count |
射频工作参数基线中的射频总数目 |
Success |
射频工作参数基线应用成功的射频数目 |
Failure |
射频工作参数基线应用失败的射频数目 |
Failure reason |
射频工作参数基线应用失败数目 |
Radio doesn’t exist |
射频不存在 |
Radio is down |
射频状态为Down |
Mismatching radio type |
射频工作参数基线中保存的射频类型与实际射频类型不匹配 |
Mismatching region code |
射频工作参数基线中保存的AP的区域码与实际情况不匹配 |
Ineffective service template |
无线服务未生效 |
Illegal channel |
射频工作参数基线中保存的射频工作信道不合法 |
Mismatching bandwidth |
射频工作参数基线中保存的射频带宽与实际射频带宽不匹配 |
Channel locked |
工作信道被锁定 |
Channel fixed |
射频工作信道已手动配置为固定值 |
Within channel holddown time |
当前工作信道处于信道保持调整期 |
Mismatching channel gap policy |
射频工作参数基线中保存的射频工作信道与信道间隔策略选取的信道不匹配 |
Power locked |
射频功率被锁定 |
Within power holddown time |
当前射频功率处于功率保持调整期 |
Power lower than min. power |
射频工作参数基线中保存的射频功率小于配置的最小传输功率 |
Power greater than max. power |
射频工作参数基线中保存的射频功率大于配置的最大传输功率 |
· wlan rrm baseline apply name
display wlan rrm-history ap命令用来显示RRM调整历史信息。
display wlan rrm-history ap { all | name ap-name }
all:当前AP。
name ap-name:AP名称,当前只能为fatap。
该命令显示所有或指定AP上最近10次改变的信道或功率的详细信息。显示输出包括改变时间、触发原因、功率、干扰等参数。
# 显示AP的RRM历史信息。
<Sysname> display wlan rrm-history ap name fatap
AP RRM History
Flags : I - Interference, P - Packets discarded, F - Retransmission,
R - Radar select, C - Coverage, B - Channelbusy
M – Manual D – Bandwidth O - Others
AP RRM History : fatap
Radio : 1 Basic BSSID : 000f-e2ff-7700
Ch Power BW Load Util Intf Reason Date Time
(dBm) (MHz) (%) (%) (%) (yyyy-mm-dd) (hh:mm:ss)
Before 36 20 20 24 2 21 -P------- 2014-07-07 17:31:50
After 40 20 20 9 0 8 - - -
Before 40 20 20 54 1 53 IP------- 2014-07-08 12:19:50
After 36 20 20 10 0 10 - - -
Before 36 20 20 29 1 28 -------D- 2014-07-08 12:59:50
After 36 20 40 30 0 29 - - -
表1-4 display wlan rrm-history命令显示信息描述表
Radio |
AP的Radio ID |
Basic BSSID |
基本服务集标识 |
Ch |
Radio的工作信道 |
Power (dBm) |
Radio的发射功率,单位为dBm |
BW (MHz) |
Radio的运行频宽,单位为MHz |
Load (%) |
信道的负载,以百分比表示 |
Util (%) |
信道的利用率,以百分比表示 |
Intf (%) |
信道检测到的干扰,以百分比表示 |
Reason |
调整的原因,包括以下取值: · I:干扰 · P:丢包 · F:重传 · R:规避雷达信号后,选用更优信道 · C:信号覆盖 · B:信道繁忙 · M:手动信道调整 · D:频宽调整 · O:其它原因 |
Date |
调整的日期 |
Time |
调整的时间 |
display wlan rrm-status ap命令用来显示AP上射频的RRM详细信息。
display wlan rrm-status ap { all | name ap-name } [ neighbor-type { managed | unmanaged } ]
all:当前AP。
neighbor-type:根据邻居类型显示探测到的RRM详细信息。如果不指定本参数,则显示AP能探测到的所有邻居类型的RRM详细信息。
managed:显示AP能探测到的邻居Radio的RRM详细信息。
unmanaged:显示AP能探测到的非邻居Radio的RRM详细信息。
如果信道和功率调整处于关闭状态,则执行此命令时,只会显示AP上Radio的工作信道和功率级别,其它信息如干扰、邻居的数量等不会显示。
# 显示AP的信道和功率调整详细信息。
<Sysname> display wlan rrm-status ap name fatap
AP RRM Profile : fatap
Radio : 1 Basic BSSID : 70f9-6d31-2fe0
Channel : 157 Tx Power (dBm) : 18
Ch Nbrs Load Util Intf PER Retry Radar Last Detected At
36 0 0 - 0 0 - - 2020-04-10 09:35:01
40 0 0 - 0 0 - - 2020-04-10 09:35:01
44 0 0 - 0 0 - - 2020-04-10 09:35:01
48 0 0 - 0 0 - - 2020-04-10 09:35:01
52 0 0 - 0 0 - - 2020-04-10 09:35:01
56 0 0 - 0 0 - - 2020-04-10 09:35:01
60 0 0 - 0 0 - - 2020-04-10 09:35:01
64 0 0 - 0 0 - - 2020-04-10 09:35:01
100 0 0 - 0 0 - - 2020-04-10 09:35:01
104 0 0 - 0 0 - - 2020-04-10 09:35:01
108 0 0 - 0 0 - - 2020-04-10 09:35:01
112 0 0 - 0 0 - - 2020-04-10 09:35:01
116 0 0 - 0 0 - - 2020-04-10 09:35:01
132 0 0 - 0 0 - - 2020-04-10 09:35:01
136 0 0 - 0 0 - - 2020-04-10 09:35:01
140 0 0 - 0 0 - - 2020-04-10 09:35:01
149 1 0 - 0 0 - - 2020-04-10 09:35:01
153 4 0 - 0 0 - - 2020-04-10 09:35:01
157 0 0 0 0 0 0 - 2020-04-10 09:35:01
161 2 0 - 0 0 - - 2020-04-10 09:35:01
165 0 0 - 0 0 - - 2020-04-10 09:35:01
Nbr-MACAddress Ch Intf SignalStrength Type Last Detected At
(%) (dBm)
000f-e212-ff01 161 0 -60 Unmanaged 2020-04-10 09:39:03
5866-ba74-e461 153 0 -72 Unmanaged 2020-04-10 09:39:03
70f9-6d30-9020 153 0 -40 Managed 2020-04-10 09:39:03
70f9-6d31-3080 149 0 -54 Managed 2020-04-10 09:39:03
70f9-6d31-34e0 161 0 -59 Managed 2020-04-10 09:39:03
7425-8a86-bbe0 153 0 -48 Unmanaged 2020-04-10 09:39:03
7425-8a86-c720 153 0 -63 Unmanaged 2020-04-10 09:39:03
Radio : 2 Basic BSSID : 70f9-6d31-2ff0
Channel : 1 Tx Power (dBm) : 19
1 6 4 0 4 0 0 - 2020-04-10 09:33:06
6 4 2 - 2 0 - - 2020-04-10 09:33:06
11 6 2 - 2 0 - - 2020-04-10 09:33:06
(%) (dBm)
000f-e212-ff11 1 49 -77 Unmanaged 2020-04-10 09:31:05
0023-89e1-ed00 11 0 -87 Unmanaged 2020-04-10 09:31:05
006a-55f6-ae10 1 57 -88 Unmanaged 2020-04-10 09:31:05
5866-ba64-aa31 1 10 -60 Unmanaged 2020-04-10 09:31:05
5866-ba74-e471 6 0 -76 Unmanaged 2020-04-10 09:31:05
5866-baa9-a610 11 0 -62 Unmanaged 2020-04-10 09:31:05
70f9-6d30-9030 6 0 -63 Managed 2020-04-10 09:31:05
70f9-6d31-3090 1 51 -86 Managed 2020-04-10 09:31:05
70f9-6d31-34f0 6 0 -85 Managed 2020-04-10 09:33:09
7425-8a86-bbf0 6 0 -73 Unmanaged 2020-04-10 09:33:09
7425-8a86-c731 11 0 -93 Unmanaged 2020-04-10 09:33:09
80f6-2ec0-3330 11 0 -76 Unmanaged 2020-04-10 09:33:09
80f6-2ec0-3331 11 0 -73 Unmanaged 2020-04-10 09:33:09
80f6-2edd-d2d0 1 40 -60 Unmanaged 2020-04-10 09:33:09
80f6-2edd-d2d1 1 44 -68 Unmanaged 2020-04-10 09:33:09
80f6-2ede-0b30 11 0 -74 Unmanaged 2020-04-10 09:33:09
表1-5 display wlan rrm-status命令显示信息描述表
Radio |
AP的Radio ID |
Basic BSSID |
基本服务集标识 |
Channel |
Radio当前的工作信道 |
Tx Power |
Radio的发射功率 |
Ch |
Radio支持的工作信道 |
Nbrs |
信道中的邻居Radio数量 |
Load |
信道的负载,以百分比表示。信道的负载指的是在该信道上,AP发送报文/接收客户端的报文和干扰,这里的干扰指该AP接收到其它AP和客户端发送的错误报文 |
Util |
信道利用率,以百分比显表示。信道利用率指的是在该信道上,AP发送报文/接收客户端的报文 |
Intf |
信道检测到的干扰,以百分比表示 |
PER |
信道检测到的误码率,以百分比表示 |
Retry |
信道检测到的重传率,以百分比表示 |
Radar |
雷达检测状态: · -表示没有检测到雷达 · Detected表示检测到雷达 |
Nbr-MACAddress |
邻居AP的Radio接口的MAC地址 |
SignalStrength |
检测到邻居Radio的信号强度,以dBm为单位 |
Type |
AP类型: · Unmanaged:该AP上的Radio能探到的非邻居Radio · Managed:该AP上的Radio能探测到的邻居Radio |
Last Detected At |
最近一次检测到信道和邻居有效数据的时间 |
wlan calibrate-channel pronto ap all命令用来手动触发所有射频进行自动信道调整。
执行wlan calibrate-channel pronto ap all命令可能会占用较多系统资源,请谨慎使用。
执行本命令后的10分钟内,所有射频将周期性的在工作信道提供无线服务和非工作信道扫描。射频在非工作信道扫描期间可能造成在线终端的报文丢失,建议在网络维护期内执行本命令。
# 手动触发所有射频进行自动信道调整。
[Sysname] wlan calibrate-channel pronto ap all
This operation will change the working channel of all radios and might cause packet loss. Continue? [Y/N]
wlan calibrate-power pronto ap all命令用来手动触发所有射频进行自动功率调整。
执行wlan calibrate-power pronto ap all命令可能会占用较多系统资源,请谨慎使用。
本功能对已经配置了最大传输功率的射频不生效。
# 手动触发所有射频进行自动功率调整。
[Sysname] wlan calibrate-power pronto ap all
wlan rrm baseline apply命令用来将射频工作参数基线应用到对应的射频。
wlan rrm baseline apply name baseline-name
name baseline-name:射频工作参数基线的名称,为1~32个字符的字符串,不区分大小写。
当射频工作参数基线处于以下任一情况时,将无法应用射频工作参数基线到对应的射频。
· 射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息。
· 射频工作参数基线为start_config_baseline.csv。
# 应用名称为bl的射频工作参数基线。
[Sysname] wlan rrm baseline apply name bl
· display wlan rrm baseline apply-history
· wlan rrm baseline save
wlan rrm baseline remove命令用来删除射频工作参数基线。
wlan rrm baseline remove name baseline-name
射频工作参数基线中保存了当前用户不具有location权限的AP的射频信息时,该用户无法删除此射频工作参数基线。
# 删除名称为bl的射频工作参数基线。
[Sysname] wlan rrm baseline remove name bl
wlan rrm baseline save命令用来将当前射频的工作参数保存为工作参数基线。
wlan rrm baseline save name baseline-name global
如果当前射频的工作信道与功率值合适,则可以使用本命令将射频的信道、功率值存储为射频工作参数基线,在需要的时候重新应用这些保存的值。
射频工作参数基线将以.csv文件的形式被保存到文件系统中。
# 将设备上所有射频的工作参数保存为射频工作参数基线,名称为global。
[Sysname] wlan rrm baseline save name global global
wlan rrm calibration-bandwidth interval命令用来配置自动频宽调整周期。
undo wlan rrm calibration-bandwidth interval命令用来恢复缺省情况。
wlan rrm calibration-bandwidth interval minutes
自动频宽调整周期为29分钟。
minutes:自动频宽调整周期,取值范围为3~1440,单位为分钟。
# 配置自动频宽调整周期为10分钟。
[Sysname] wlan rrm calibration-bandwidth interval 10
· calibrate-bandwidth self-decisive
wlan rrm calibration-channel ap命令用来手动触发指定AP的射频进行自动信道调整。
wlan rrm calibration-channel ap name ap-name [ radio radio-id ] [ force ]
name ap-name:指定进行自动信道调整的AP。ap-name表示AP的名称,当前只能为fatap。
radio radio-id:指定进行自动信道调整的AP射频,其中radio-id为射频编号,本参数的取值范围与AP型号有关,请以设备的实际情况为准。如果未指定本参数,将对指定AP的所有射频进行信道调整。
force:不进行信道质量检测、计算,直接调整信道。如果未指定本参数,射频将经过信道质量检测、计算后调整信道。
配置本命令可让指定的AP射频强制进行一次自动信道调整,或者执行一次标准的信道调整流程(先进行信道质量检测,而后进行信道质量计算,最后进行信道调整)。
同时对多个射频进行信道调整时,某一个射频的信道调整结果不影响其它射频的调整。
配置本命令并指定force参数时,调整后的信道不一定是最优信道;配置本命令但未指定force参数时,最终是否能够调整信道与信道质量分析结果有关。
无论是否指定force参数,执行本命令后,设备会花费几分钟时间进行信道扫描、收集信道数据。在此期间:
· 终端的部分报文将被丢弃。
· 不应关闭射频开关、修改信道扫描相关配置、修改WLAN RRM相关配置。
# 手动触发AP的radio 1进行强制自动信道调整。
[Sysname] wlan rrm calibration-channel ap name fatap radio 1 force
wlan rrm calibration-channel interval命令用来配置自动信道调整周期。
undo wlan rrm calibration-channel interval命令用来恢复缺省情况。
wlan rrm calibration-channel interval minutes
自动信道调整周期为293分钟。
minutes:自动信道调整周期,取值范围为3~1440,单位为分钟。
# 配置自动信道调整周期为10分钟。
[Sysname] wlan rrm calibration-channel interval 10
· calibrate-channel self-decisive
wlan rrm calibration-power interval命令用来配置自动功率调整周期。
undo wlan rrm calibration-power interval命令用来恢复缺省情况。
wlan rrm calibration-power interval minutes
自动功率调整周期为23分钟。
minutes:自动功率调整周期,取值范围为3~180,单位为分钟。
# 配置自动功率调整周期为10分钟。
[Sysname] wlan rrm calibration-power interval 10
· calibrate-power self-decisive
