04-STUN命令
本章节下载: 04-STUN命令 (197.79 KB)
1.1.1 display stun client info
1.1.2 display stun server packet-statistics
1.1.3 reset stun client statistics
display stun client info命令用来查看STUN客户端收发报文的统计信息和NAT信息。
# 查看STUN客户端收发报文的统计信息和NAT信息。
<Sysname> display stun client info
Totally 1 STUN clients
Local IP/port : 1.1.1.24/6666
Local VPN : -
NAT IP/port : 66.1.1.1/6666
NAT type : Full Cone NAT
STUN refresh times : 5657
STUN request timeouts : 2
Basic requests sent : 11324
Behavior requests sent : 5517
Filter requests sent : 5518
Received response to basic requests : 11315
Received response to behavior requests : 5517
Received response to filter requests : 5517
Transaction ID errors in received responses : 0
表1-1 display stun client info命令信息描述
项目 |
Local IP/port |
STUN客户端发起探测的IP地址和端口 |
Local VPN |
STUN客户端隧道接口所属的VPN实例的名称 |
NAT IP/port |
转换后的公网地址和端口 |
NAT type |
NAT转换类型: · Full Cone NAT:完全锥型NAT · Restricted Cone NAT:限制锥型NAT · Port Restricted Cone NAT:端口限制锥型NAT · Symmetric NAT:对称NAT · NO NAT:不存在NAT · -:未知类型 |
STUN refresh times |
STUN客户端刷新探测结果的次数 |
STUN request timeouts |
STUN客户端探测超时次数 |
Basic requests sent |
发送BASIC探测报文统计计数。BASIC探测用于探测地址转换后的IP地址和端口号 |
Behavior requests sent |
发送Behavior探测报文统计计数。Behavior探测用于探测NAT映射类型 |
Filter requests sent |
发送Filter探测报文统计计数。Filter探测用于探测NAT过滤方式 |
Received responses to basic requests |
接收到BASIC探测报文统计计数 |
Received responses to behavior requests |
接收到Behavior探测报文统计计数 |
Received responses to filter requests |
接收到Filter探测报文统计计数 |
Transaction ID errors in received responses |
接收到的响应报文中的事务ID错误 |
· reset stun client statistics
display stun server packet-statistics命令用来查看STUN服务器收发报文的统计信息。
# 查看STUN服务器收发报文的统计信息。
<Sysname> display stun server packet-statistics
STUN success/error requests received : 22386/0
STUN success/error responses sent : 22386/0
STUN requests dropped : 0
STUN packets recieved : 22386
STUN unknown packets received : 0
表1-2 display stun server statistics packet命令信息描述
项目 |
STUN success/error requests received |
STUN服务器接收探测请求报文成功/失败个数 |
STUN success/error responses sent |
STUN服务器发送探测响应报文成功/失败个数 |
STUN requests dropped |
STUN服务器丢弃的请求报文个数 |
STUN packets received |
STUN服务器接收到的报文个数 |
STUN unknown packets received |
STUN服务器接收到的未知报文个数 |
· reset stun server packet-statistics
reset stun client statistics命令用来清除STUN客户端的报文统计信息。
执行本命令将清除已记录的所有STUN客户端的报文统计信息,请谨慎操作。
# 清除STUN客户端的报文统计信息。
<Sysname> reset stun client statistics
· display stun client info
reset stun server packet-statistics命令用来清除STUN服务器的报文统计信息。
执行本命令将清除已记录的所有STUN服务器的报文统计信息,请谨慎操作。
# 清除STUN服务器的报文统计信息。
<Sysname> reset stun server packet-statistics
· display stun server statistics
stun client命令用来开启接口的STUN客户端功能,并设置STUN客户端连接的STUN服务器的IP和端口号。
undo stun client命令用来关闭STUN客户端功能。
stun client destination-ip ip-address [ destination-port port-number ]
undo stun client destination-ip
接口的STUN客户端功能处于关闭状态。
Tunnel接口视图
destination-ip ip-address:STUN服务器的IP地址。
destination-port port-number:STUN服务器的端口号,取值范围为1024~65535,缺省值为3478。
通过本命令指定的STUN服务器的IP地址不能为STUN服务器的替代IP地址,否则STUN客户端无法与STUN服务器建立连接。
不能通过重复执行本命令来修改STUN客户端连接的STUN服务器的IP和端口号。如需修改,请先通过undo stun client destination-ip命令关闭STUN客户端功能,再执行stun client destination-ip命令。
为了STUN探测功能能够正常工作,需要保证STUN客户端到服务器的IP地址和替代IP地址路由可达。
# 在SDWAN隧道接口Tunnel1下开启接口的STUN客户端功能,并设置STUN客户端连接的STUN服务器的IP地址为122.255.128.143,端口号为1025。
[Sysname] interface tunnel 1 mode sdwan udp
[Sysname-Tunnel1] stun client destination-ip 122.225.128.143 destination-port 1025
stun server命令用来开启STUN服务器功能,并指定STUN服务器的IP地址和UDP端口号。
undo stun server命令用来关闭STUN服务器功能。
stun server ip ip-address [ port port-number ] [ alternative-ip ip-address [ alternative-port port-number ] ] [ vpn-instance vpn-instance-name ][ global-ip global-ip-address [ global-port port-number ] [ global-alternative-ip ip-address [ global-alternative-port port-number ] ] ]
undo stun server ip ip-address [ port port-number ] [ vpn-instance vpn-instance-name ]
STUN服务器功能处于关闭状态。
alternative-ip ip-address:STUN服务器的替代IP地址。STUN服务器部署在公网的场景中,如果未指定本参数,则无法确定NAT类型。
alternative-port port-number:STUN服务器的替代端口号,取值范围为1024~65535,缺省值为3479。
vpn-instance vpn-instance-name:STUN服务器的IP地址所属的VPN实例。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示STUN服务器的IP地址不属于任何一个VPN实例。
global-ip ip-address:经过NAT转换后的STUN服务器的公网IP地址。
global-port port-number:经过NAT转换后的STUN服务器的公网端口号,取值范围为1024~65535,缺省为STUN服务器的真实端口号。
global-alternative-ip ip-address:经过NAT转换后的STUN服务器的替代公网IP地址。STUN服务器部署在私网的场景中,如果未指定本参数,则无法确定NAT类型。
global-alternative-port port-number:经过NAT转换后STUN服务器的替代公网端口号,取值范围为1024~65535,缺省为STUN服务器的替代端口号。
STUN服务器通常部署在公网上,是一个发送STUN捆绑响应和接受STUN捆绑请求的设备。STUN服务器和STUN客户端通过交互STUN捆绑请求报文和STUN捆绑响应报文,能够探测NAT转换后的IP地址和端口号,以及NAT类型。
如果STUN服务器部署在私网,并通过配置了公私网映射关系唯一确定的地址转换的NAT设备与公网互通,则STUN服务器发送STUN捆绑响应报文载荷中的STUN服务器地址为私网地址,STUN客户端进一步发送捆绑请求时,使用STUN捆绑响应报文载荷中的地址作为报文的目的地址,靠近STUN客户端的NAT设备收到该捆绑请求报文后,无法进行地址转换,也无法进行路由转发,从而导致STUN探测失败。
为了解决上述问题,配置stun server命令时,还需要同时指定global-ip和alternative-global-ip参数,使得STUN服务器发送的捆绑响应报文载荷中的IP地址为经过NAT转换后的公网IP地址。通过global-ip和alternative-global-ip参数指定的转换后的公网IP地址,需要和NAT设备上地址转换后的IP地址匹配。
多出口组网环境中,可以多次配置本命令,部署多个STUN服务器。
配置SUTN服务器时,需要注意:
· 为了STUN探测功能能够正常工作,需要保证STUN客户端到服务器的IP地址和替代IP地址路由可达。
· STUN服务器的IP地址是区分不同STUN服务器的唯一判断条件。公网或同一VPN内,配置限制如下:
¡ 同一STUN服务器的IP地址、替代IP地址、公网IP地址、替代公网IP地址不能重叠。
¡ 同一SUTN服务器的端口号、替代端口号不能重叠;公网端口号、替代公网端口号不能重叠。
¡ 不同STUN服务器的IP地址、替代IP地址、公网IP地址、替代公网IP地址不能重叠。
不同VPN的STUN服务器无上述配置限制。
· 不能通过重复执行本命令来修改STUN服务器配置。如需修改,请先通过undo stun server ip命令关闭STUN服务器功能,再执行stun server ip命令。
# 配置STUN服务器的IP地址为10.1.1.1,替代IP地址为20.1.1.1,端口号为4396,替代端口号为4397。
[Sysname] stun server ip 10.1.1.1 port 4396 alternative-ip 20.1.1.1 alternative-port 4397
