06-端口安全命令
本章节下载: 06-端口安全命令 (519.36 KB)
1.1.2 display port-security mac-address block
1.1.3 display port-security mac-address security
1.1.4 port-security access-user log enable
1.1.5 port-security authentication open
1.1.6 port-security authentication open global
1.1.7 port-security authorization ignore
1.1.8 port-security authorization-fail offline
1.1.10 port-security free-vlan
1.1.11 port-security intrusion-mode
1.1.12 port-security mac-address aging-type inactivity
1.1.13 port-security mac-address dynamic
1.1.14 port-security mac-address security
1.1.15 port-security mac-limit
1.1.16 port-security mac-move bypass-vlan-check
1.1.17 port-security mac-move permit
1.1.18 port-security max-mac-count
1.1.19 port-security nas-id-profile
1.1.22 port-security port-mode
1.1.23 port-security strict-intrusion-protection enable
1.1.24 port-security timer autolearn aging
1.1.25 port-security timer autolearn aging second
1.1.26 port-security timer blockmac
1.1.27 port-security timer disableport
1.1.28 port-security user-mac control enable
1.1.29 snmp-agent trap enable port-security
display port-security命令用来显示端口安全的配置信息、运行情况和统计信息。
display port-security [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定端口的端口安全相关信息。interface-type interface-number表示端口类型和端口编号。若不指定本参数,则显示所有端口的端口安全信息。
# 显示所有端口的端口安全相关状态。
<Sysname> display port-security
Global port security parameters:
Port security : Enabled
AutoLearn aging time : 0 min
Disableport timeout : 20 s
Blockmac timeout : 180 s
MAC move : Denied
Authorization fail : Online
NAS-ID profile : Not configured
Dot1x-failure trap : Disabled
Dot1x-logon trap : Disabled
Dot1x-logoff trap : Enabled
Intrusion trap : Disabled
Address-learned trap : Enabled
Mac-auth-failure trap : Disabled
Mac-auth-logon trap : Enabled
Mac-auth-logoff trap : Disabled
Open authentication : Disabled
Traffic-statistics : Disabled
OUI value list :
Index : 1 Value : 123401
GigabitEthernet1/0/1 is link-up
Port mode : userLogin
NeedToKnow mode : Disabled
AutoLearn aging time : Not configured
Intrusion protection mode : NoAction
Strict intrusion protection : Disabled
Security MAC address attribute
Learning mode : Sticky
Aging type : Periodical
Max secure MAC addresses : 32
Current secure MAC addresses : 0
Authorization : Permitted
Free VLANs : Not configured
MAC-move VLAN check bypass : Disabled
表1-1 display port-security命令显示信息描述表
Port security |
端口安全的开启状态 |
AutoLearn aging time |
Sticky MAC地址的老化时间,单位为分钟或秒 |
Disableport timeout |
收到非法报文的端口暂时被关闭的时间,单位为秒 |
Blockmac timeout |
收到非法报文的端口将非法报文的源MAC地址加入阻塞MAC地址列表的时间,单位为秒 |
MAC move |
MAC迁移功能的开启状态 · Both port move and VLAN move are permitted:同时开启了允许端口迁移和允许VLAN迁移功能 · Denied:未开启MAC迁移功能 · Only port move is permitted:仅开启允许端口迁移功能 · Only VLAN move is permitted:仅开启允许VLAN迁移功能 |
Authorization fail |
授权失败后用户的状态,包括下线(Offline)和保持在线(Online)两种类型 |
NAS-ID profile |
全局引用的NAS-ID Profile |
Dot1x-failure trap |
802.1X用户认证失败的告警功能开启状态 |
Dot1x-logon trap |
802.1X用户认证成功的告警功能开启状态 |
Dot1x-logoff trap |
802.1X用户认证下线的告警功能开启状态 |
Intrusion trap |
发现非法报文的告警功能开启状态 |
Address-learned trap |
端口学习到新MAC地址的告警功能开启状态 |
Mac-auth-failure trap |
MAC地址认证用户认证失败的告警功能开启状态 |
Mac-auth-logon trap |
MAC地址认证用户认证成功的告警功能开启状态 |
Mac-auth-logoff trap |
MAC地址认证用户认证下线的告警功能开启状态 |
Open authentication |
端口安全全局开放认证模式功能开启状态 · Enabled:打开 · Disabled:关闭 |
Traffic-statistics |
端口安全接入用户的流量统计功能开启状态 · Enabled:开启 · Disabled:关闭 |
OUI value list |
允许通过认证的用户的24位OUI值 |
Index |
OUI的索引 |
Value |
OUI值 |
Port mode |
端口安全模式,包括以下几种: · noRestriction · autoLearn · macAddressWithRadius · macAddressElseUserLoginSecure · macAddressElseUserLoginSecureExt · secure · userLogin · userLoginSecure · userLoginSecureExt · macAddressOrUserLoginSecure · macAddressOrUserLoginSecureExt · userLoginWithOUI 关于各模式的具体涵义,请参考端口安全配置手册 |
NeedToKnow mode |
Need To Know模式,包括以下几种: · NeedToKnowOnly:表示仅允许目的MAC地址为已知MAC地址的单播报文通过 · NeedToKnowWithBroadcast:允许目的MAC地址为已知MAC地址的单播报文或广播地址的报文通过 · NeedToKnowWithMulticast:允许目的MAC地址为已知MAC地址的单播报文,广播地址或组播地址的报文通过 · NeedToKnowAuto:表示仅当有用户上线后,才允许广播地址报文、组播地址报文和目的MAC地址为已知MAC地址的单播报文通过 · Disabled:表示不进行NTK处理 |
接口视图下配置的安全MAC老化时间,单位为秒。如果未在接口视图下配置安全MAC老化时间,则显示为“Not configured” |
Intrusion protection mode |
入侵检测特性模式,包括以下几种: · BlockMacAddress:表示将非法报文的源MAC地址加入阻塞MAC地址列表中 · DisablePort:表示将收到非法报文的端口永久关闭 · DisablePortTemporarily:表示将收到非法报文的端口暂时关闭一段时间 · NoAction:表示不进行入侵检测处理 |
Strict intrusion protection |
端口上严格入侵检测的开启状态 · Enabled:开启 · Disabled:关闭 |
Security MAC address attribute |
安全MAC地址的相关属性 |
Security MAC address learning mode |
安全MAC地址的学习方式: · Dynamic:动态类型 · Sticky:Sticky类型 |
Security MAC address aging type |
安全MAC地址的老化方式: · Periodical:按照配置的老化时间间隔进行老化 · Inactivity:无流量命中时老化 |
Max secure MAC addresses |
端口安全允许的最大安全MAC地址数目或上线用户数 |
Current secure MAC addresses |
端口下保存的安全MAC地址数目 |
Authorization |
服务器的授权信息是否被忽略 · Permitted:表示当前端口应用RADIUS服务器或本地设备下发的授权信息 · Ignored:表示当前端口不应用RADIUS服务器或本地设备下发的授权信息 |
NAS-ID profile |
端口下引用的 NAS-ID Profile |
Free VLANs |
端口上配置的无需认证的VLAN,如果没有配置,则显示Not configured |
端口安全端口开放认证模式功能开启状态 · Enabled:打开 · Disabled:关闭 |
MAC-move VLAN check bypass |
端口上MAC迁移时不检查VLAN功能的开启状态 · Enabled:开启 · Disabled:关闭 |
display port-security mac-address block命令用来显示阻塞MAC地址信息。
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
interface interface-type interface-number:显示指定端口的阻塞MAC地址信息。interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示指定VLAN的阻塞MAC地址信息。其中,vlan-id表示VLAN编号,取值范围为1~4094。
count:显示阻塞MAC地址的个数。
如果不指定任何参数,则显示所有阻塞MAC地址的信息。
# 显示所有阻塞MAC地址。
<Sysname> display port-security mac-address block
MAC ADDR Port VLAN ID
000f-3d80-0d2d GE1/0/1 30
--- On slot 1, 1 MAC address(es) found ---
--- 1 mac address(es) found ---
# 显示所有阻塞MAC地址计数。
<Sysname> display port-security mac-address block count
表1-2 display port-security mac-address block命令显示信息描述表
MAC ADDR |
阻塞MAC地址 |
Port |
阻塞MAC地址所在端口 |
VLAN ID |
端口所属VLAN |
number mac address(es) found |
当前阻塞MAC地址数目为number个 |
· port-security intrusion-mode
display port-security mac-address security命令用来显示安全MAC地址信息。
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
interface interface-type interface-number:显示指定端口的安全MAC地址信息。其中,interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示指定VLAN的安全MAC地址信息。其中,vlan-id表示VLAN编号,取值范围为1~4094。
count:统计符合条件的安全MAC地址个数。
当端口工作于autoLearn模式或开启端口安全接入用户安全MAC控制功能时,端口上通过自动学习、静态配置、认证成功用户以及Voice VLAN用户的安全MAC地址可通过该命令查看。
如果不指定任何参数,则显示所有安全MAC地址的信息。
# 显示所有安全MAC地址。
<Sysname> display port-security mac-address security
MAC addr VLAN ID State Port index Type Aging time
0002-0002-0002 1 Secure GE1/0/1 MAC-Auth Not aged
--- Number of secure MAC addresses: 1 ---
# 显示所有安全MAC地址计数。
<Sysname> display port-security mac-address security count
表1-3 display port-security mac-address security命令显示信息描述表
MAC addr |
安全MAC地址 |
VLAN ID |
端口所属VLAN |
State |
添加的MAC地址类型 · Secure:表示该项是安全MAC地址 |
Port index |
安全MAC地址所在端口 |
Type |
安全MAC类型: · Autolearn:动态学习 · Manual:手动配置 · MAC-Auth:MAC地址认证用户 · 802.1X:802.1X认证用户 · Web-Auth:Web认证用户 · Voice VLAN:Voice VLAN用户 |
Aging time |
安全MAC地址的剩余存活时间 · 对于静态MAC地址,显示为Not aged · 对于Sticky MAC地址,显示为具体的剩余存活时间,当存活时间小于60秒,显示单位为秒;当存活时间大于等于60秒时,显示单位为分钟。缺省情况下为不进行老化,显示为Not aged |
Number of secure MAC addresses |
当前保存的安全MAC地址数 |
· port-security mac-address security
port-security access-user log enable命令用来开启端口安全接入用户日志信息功能。
undo port-security access-user log enable命令用来关闭端口安全接入用户日志信息功能。
port-security access-user log enable [ failed-authorization | mac-learning | violation | vlan-mac-limit ] *
undo port-security access-user log enable [ failed-authorization | mac-learning | violation | vlan-mac-limit ] *
端口安全接入用户日志信息功能处于关闭状态。
failed-authorization:802.1X或MAC地址认证用户授权失败时的日志信息。
mac-learning:端口自动学习到MAC地址时的日志信息。
violation:端口安全入侵检测功能被触发时的日志信息。
vlan-mac-limit:VLAN内同时接入的MAC地址数达到最大值后有新MAC地址用户接入时的日志信息。
为了防止设备输出过多的端口安全接入用户日志信息,一般情况下建议关闭此功能。
配置本命令时,如果未指定任何参数,将同时开启或关闭本命令所有参数对应日志功能。
配置vlan-mac-limit参数后,只有当VLAN内的MAC地址数从未达到上限变为达到上限,且有新用户试图接入时才会触发日志。如果MAC地址数已达到上限,只有第1个新用户试图接入时才输出日志,后续用户试图接入时不会再次输出日志。
# 开启端口安全入侵检测功能被触发时的日志信息。
[Sysname] port-security access-user log enable violation
· info-center source portsec logfile deny(网络管理和监控/信息中心)
port-security authentication open命令用来开启端口上端口安全的开放认证模式。
undo port-security authentication open命令用来关闭端口上端口安全的开放认证模式。
端口上的端口安全开放认证模式处于关闭状态。
二层以太网接口视图
开启端口上的端口安全开放认证模式后,端口上的802.1X、MAC地址认证用户即使身份信息不正确(包含不存在的用户名或者错误的密码两种情况)也可以正常接入并访问网络。在这种模式下接入的用户被称为open用户,此类用户不支持授权和计费,但可通过display dot1x connection open、display mac-authentication connection open命令查看相关信息。
端口上开启端口安全的开放认证模式后,身份信息正确的用户可正常上线,此类不属于open用户。
开放认证模式优先级低于802.1X的Auth-Fail VLAN和MAC地址认证的Guest VLAN,即如果端口上配置了802.1X的Auth-Fail VLAN或MAC地址认证的Guest VLAN,密码错误的接入用户会加入认证失败VLAN,开放认证模式不生效。
有关802.1X、MAC地址认证的详细介绍,请参见“安全配置指导”中的“802.1X”和“MAC地址认证”。
# 开启端口GigabitEthernet1/0/1上的端口安全的开放认证模式。
[Sysname-GigabitEthernet1/0/1] port-security authentication open
· display dot1x connection
· display mac-authentication connection
· port-security authentication open global
port-security authentication open global命令用来开启全局端口安全的开放认证模式。
undo port-security authentication open global命令用来关闭全局端口安全的开放认证模式。
端口安全的开放认证模式处于关闭状态。
开启全局端口安全开放认证模式之后,802.1X、MAC地址认证用户即使身份信息不正确(包含不存在的用户名或者错误的密码两种情况)也可以正常接入并访问网络。在这种模式下接入的用户被称为open用户,此类用户不支持授权和计费,但可通过display dot1x connection open、display mac-authentication connection open命令查看相关信息。
全局开启端口安全的开放认证模式后,身份信息正确的用户可正常上线,此类不属于open用户。
有关802.1X、MAC地址认证的详细介绍,请参见“安全”中的“802.1X”和“MAC地址认证”。
# 开启全局端口安全的开放认证模式。
[Sysname] port-security authentication open global
port-security authorization ignore命令用来配置端口不应用RADIUS服务器或设备本地下发的授权信息。
undo port-security authorization ignore命令用来恢复缺省情况。
端口应用RADIUS服务器或设备本地下发的授权信息。
二层以太网接口视图
当用户通过RADIUS认证或本地认证后,RADIUS服务器或设备会根据用户账号配置的相关属性进行授权,比如动态下发VLAN等。若不希望接受这类动态下发的属性,则可通过配置本命令来忽略。
# 配置端口GigabitEthernet1/0/1不应用RADIUS服务器或设备本地下发的授权信息。
[Sysname-GigabitEthernet1/0/1] port-security authorization ignore
· display port-security
port-security authorization-fail offline命令用来开启授权失败用户下线功能。
undo port-security authorization-fail offline命令用来关闭授权失败用户下线功能。
port-security authorization-fail offline [ quiet-period ]
授权失败用户下线功能处于关闭状态,即授权失败后用户保持在线。
quiet-period:表示开启用户授权失败下线静默功能。802.1X认证或MAC地址认证用户下线后,设备将其加入对应认证类型的静默队列,并根据对应认证类型的静默定时器的值来确定用户认证失败以后,设备停止对其提供认证服务的时间间隔。在静默期间,设备不对来自认证失败用户的报文进行认证处理,直接丢弃;静默期后,设备再次收到该用户的报文,则对其进行认证处理。若不指定此参数,用户授权下线后,设备再次收到该用户的报文就对其进行认证处理。
如果配置为授权失败用户下线,当下发的授权ACL、User Profile不存在或者ACL、User Profile下发失败时,将强制用户下线。
如果配置为授权失败用户保持在线,当下发的授权ACL、User Profile不存在或者ACL、User Profile下发失败时,用户保持在线,授权ACL、User Porfile不生效,设备打印日志信息。
若开启本功能时指定了quiet-period参数则需要先完成如下配置:
· 对于802.1X用户,通过dot1x quiet-period命令开启802.1X认证静默定时器功能,并通过dot1x timer quiet-period命令设置静默定时器的值。
· 对于MAC地址认证用户,通过mac-authentication timer quiet命令配置MAC地址认证静默定时器的值。
# 开启授权失败用户下线功能。
[Sysname] port-security authorization-fail offline
· dot1x quiet-period(安全命令参考/802.1X)
· dot1x timer quiet-period(安全命令参考/802.1X)
· mac-authentication timer(安全命令参考/MAC地址认证)
port-security enable命令用来使能端口安全。
undo port-security enable命令用来关闭端口安全。
端口安全功能处于关闭状态。
如果已全局开启了802.1X或MAC地址认证,则无法使能端口安全。
执行使能或关闭端口安全的命令后,端口上的相关配置将会恢复为如下情况:
· 802.1X端口接入控制方式恢复为macbased;
· 802.1X端口的授权状态恢复为auto。
端口上有用户在线的情况下,若关闭端口安全,则在线用户将会下线。
# 使能端口安全。
[Sysname] port-security enable
· dot1x(安全命令参考/802.1X)
· dot1x port-control(安全命令参考/802.1X)
· dot1x port-method(安全命令参考/802.1X)
· mac-authentication(安全命令参考/MAC地址认证)
port-security free-vlan命令用来配置端口安全的Free VLAN。
undo port-security free-vlan命令用来恢复缺省配置。
仅R1122及以上版本支持本命令。
port-security free-vlan vlan-id-list
undo port-security free-vlan [ vlan-id-list ]
未配置端口安全的Free VLAN,即开启802.1X认证、MAC地址认证或配置了端口安全相关认证模式的端口接收的任意VLAN内的用户报文都需要进行相应的认证。
二层以太网接口视图
vlan-id-list:指定无需进行802.1X或MAC地址认证的VLAN列表。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
开启802.1X认证、MAC地址认证或端口安全功能并配置了端口安全模式为userLogin、userLoginSecure、userLoginWithOUI、userLoginSecureExt、macAddressWithRadius、macAddressOrUserLoginSecure、macAddressElseUserLoginSecure、macAddressOrUserLoginSecureExt或macAddressElseUserLoginSecureExt时,若需要对指定VLAN的流量不进行认证,直接转发,可配置端口安全的Free VLAN。
可以通过多次执行本命令,配置端口安全的多个Free VLAN。
执行undo port-security free-vlan时,如果不指定VLAN,则表示删除所有Free VLAN。
# 在端口GigabitEthernet1/0/1配置Free VLAN为VLAN 2和VLAN 3,即设备接收到这两个VLAN内的报文不触发802.1X或MAC地址认证。
[Sysname-GigabitEthernet1/0/1] port-security free-vlan 2 3
port-security intrusion-mode命令用来配置入侵检测特性,对接收到非法报文的端口采取相应的安全策略。
undo port-security intrusion-mode命令用来恢复缺省情况。
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
对接收到非法报文的端口不进行入侵检测处理。
二层以太网接口视图
blockmac:表示将非法报文的源MAC地址加入阻塞MAC地址列表中,源MAC地址为阻塞MAC地址的报文将被丢弃,实现在端口上过滤非法流量的作用。此MAC地址在被阻塞一段时间后恢复正常。阻塞时长可通过port-security timer blockmac命令配置。阻塞MAC地址列表可以通过display port-security mac-address block命令查看。
disableport:表示将收到非法报文的端口永久关闭。
disableport-temporarily:表示将收到非法报文的端口暂时关闭一段时间。关闭时长可通过port-security timer disableport命令配置。
可以通过执行undo shutdown命令重新开启被入侵检测特性临时或永久断开的端口。
当端口上开启了严格入侵检测功能时,不能将入侵检测特性模式修改为blockmac。如需在已开启严格入侵检测功能的端口上修改入侵检测特性模式为blockmac,请先执行undo port-security strict-intrusion-protection enable命令关闭严格入侵检测功能。
# 配置端口GigabitEthernet1/0/1的入侵检测特性检测到非法报文后,将非法报文的源MAC地址置为阻塞MAC。
[Sysname-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
· display port-security mac-address block
· port-security strict-intrusion-protection enable
· port-security timer blockmac
· port-security timer disableport
port-security mac-address aging-type inactivity命令用来配置安全MAC地址的老化方式为无流量老化。
undo port-security mac-address aging-type inactivity命令用来恢复缺省情况。
安全MAC地址按照配置的老化时间进行老化,即在安全MAC地址的老化时间到达后立即老化,不论该安全MAC地址是否还有流量产生。
二层以太网接口视图
无流量老化方式下,设备会定期检测端口上的安全MAC地址是否有流量产生,若某安全MAC地址在一定的老化检测周期内没有任何流量产生,则将会被老化,否则该安全MAC地址不会被老化,并在下一个老化检测周期内重复该检测过程。下一个周期内若还有流量产生则继续保持该安全MAC地址的学习状态,该方式可有效避免非法用户通过仿冒合法用户MAC地址乘机在合法用户的安全MAC地址老化时间到达之后占用端口资源。
在二层以太网接口上,老化检测机制由port-security timer autolearn aging命令配置的安全MAC地址老化时间决定:
· 如果配置的老化时间大于等于60秒,则老化检测周期为30秒。若某安全MAC地址在N个连续的老化检测周期内无流量产生,则将会被老化。N为老化时间以半分钟向上取整。例如,安全MAC地址老化时间为80秒,则N为3。
· 如果配置的老化时间小于60秒,则老化检测周期就等于老化时间。若某安全MAC地址在老化检测周期内无流量产生,则将会被老化。
此命令仅对于Sticky MAC地址以及动态类型的安全MAC地址有效。
# 配置端口GigabitEthernet1/0/1的安全MAC地址的老化方式为无流量老化。
[Sysname-GigabitEthernet1/0/1] port-security mac-address aging-type inactivity
port-security mac-address dynamic命令用来将Sticky MAC地址设置为动态类型的安全MAC地址。
undo port-security mac-address dynamic命令用来恢复缺省情况。
端口学习到的是Sticky类型的安全MAC,它能够被保存在配置文件中,设备重启后也不会丢失。
二层以太网接口视图
动态类型的安全MAC地址不会被保存在配置文件中,可通过执行display port-security mac-address security命令查看到,设备重启之后会丢失。在不希望设备上保存重启之前端口上已有的Sticky MAC地址的情况下,可将其设置为动态类型的安全MAC地址。
本命令成功执行后,指定端口上的Sticky MAC地址会立即被转换为动态类型的安全MAC地址,且将不能手工添加Sticky MAC地址。之后,若成功执行对应的undo命令,该端口上的动态类型的安全MAC地址会立即转换为Sticky MAC地址,且用户可以手工添加Sticky MAC地址。
# 将端口GigabitEthernet1/0/1上的Sticky MAC地址设置为动态类型的安全MAC地址。
[Sysname-GigabitEthernet1/0/1] port-security mac-address dynamic
· display port-security mac-address security
port-security mac-address security命令用来添加安全MAC地址。
undo port-security mac-address security命令用来删除指定的安全MAC地址。
在二层以太网接口视图下:
port-security mac-address security [ sticky ] mac-address vlan vlan-id
undo port-security mac-address security [ sticky ] mac-address vlan vlan-id
在系统视图下:
port-security mac-address security [ sticky ] mac-address interface interface-type interface-number vlan vlan-id
undo port-security mac-address security [ [ mac-address [ interface interface-type interface-number ] ] vlan vlan-id ]
未配置安全MAC地址。
二层以太网接口视图
sticky:表示要添加一个可老化的安全MAC地址(Sticky MAC地址)。若不指定本参数,则表示添加的是一个不老化的静态安全MAC地址。
mac-address:安全MAC地址,格式为H-H-H。
interface interface-type interface-number:指定添加安全MAC地址的接口。其中,interface-type interface-number表示接口类型和接口编号。
vlan vlan-id:指定安全MAC地址所属的VLAN。其中,vlan-id表示VLAN编号,取值范围为1~4094。
Sticky MAC地址的老化时间可通过port-security timer autolearn aging命令配置。当Sticky MAC地址的老化时间到达时,Sticky MAC地址即被删除。
手工配置添加的安全MAC地址在保存配置并设备重启后,不会被删除。因此,可以将网络中一些已知的、固定要接入某端口的主机或设备的MAC地址添加为安全MAC地址,这样在端口处于autoLearn安全模式时,此类源MAC地址为安全MAC地址的主机或设备的报文将被允许通过指定端口,而且还可避免与其它通过自动方式学习到端口上的MAC地址的报文争夺资源而被拒绝接收。
成功添加安全MAC地址的前提为:端口安全处于开启状态;端口的端口安全模式为autoLearn;当前的端口允许指定的VLAN通过或已加入该VLAN,且该VLAN已存在。
已添加的安全MAC地址,除非首先将其删除,否则不能重复添加或者修改其地址类型,例如已经在某端口上添加了一条安全MAC地址port-security mac-address security 1-1-1 vlan 10,则不能再添加一条安全MAC地址port-security mac-address security sticky 1-1-1 vlan 10。
所有的静态安全MAC地址均不老化,除非被管理员通过命令行手工删除,或因为配置的改变(端口的安全模式被改变,或端口安全功能被关闭)而被系统自动删除。
# 使能端口安全,配置端口GigabitEthernet1/0/1的安全模式为autoLearn,并指定端口安全允许的最大MAC地址数为100。
[Sysname-GigabitEthernet1/0/1] port-security max-mac-count 100
[Sysname-GigabitEthernet1/0/1] port-security port-mode autolearn
# 为该端口添加一条Sticky MAC地址0001-0002-0003,该安全MAC地址属于VLAN 4。
[Sysname-GigabitEthernet1/0/1] port-security mac-address security sticky 0001-0002-0003 vlan 4
# 在系统视图下为端口GigabitEthernet1/0/1添加一条安全MAC地址0001-0001-0002,该安全MAC地址属于VLAN 10。
[Sysname] port-security mac-address security 0001-0001-0002 interface gigabitethernet 1/0/1 vlan 10
· port-security timer autolearn aging
port-security mac-limit命令用来设置端口上指定VLAN内端口安全功能允许同时接入的最大MAC地址数。
undo port-security mac-limit命令用来恢复缺省情况。
port-security mac-limit max-number per-vlan vlan-id-list
undo port-security mac-limit max-number per-vlan vlan-id-list
不限制端口上端口安全功能允许同时接入的最大MAC地址数。
二层以太网接口视图
max-number:端口上端口安全功能允许同时接入的MAC地址数的最大值,取值范围为1~2147483647。
per-vlan vlan-id-list:指定VLAN列表内每个VLAN内允许同时接入的MAC地址数的最大值。表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。
端口上端口安全功能允许接入的MAC地址包括:
· 端口上MAC地址认证成功用户的MAC地址;MAC地址认证Guest VLAN、Critical VLAN中用户的MAC地址。
· 802.1X认证成功用户的MAC地址;802.1X认证Guest VLAN、Auth-Fail VLAN、Critical VLAN中用户的MAC地址。
· Web认证成功用户的MAC地址,Web认证Auth-Fail VLAN中用户的MAC地址。
由于系统资源有限,如果当前端口上允许接入的MAC地址数过多,接入MAC地址之间会发生资源的争用,因此适当地配置该值可以使属于当前端口的用户获得可靠的性能保障。当指定VLAN内,端口允许接入的MAC地址数超过最大值后,该VLAN内新接入的MAC地址将被拒绝。
通过本命令配置端口上指定VLAN内端口安全功能允许同时接入的最大MAC地址数,不能小于当前端口上相应VLAN已存在的MAC地址数;否则,本次配置不生效。
# 配置端口GigabitEthernet1/0/1上,VLAN 1、VLAN 5和VLAN 10~VLAN 20上每个VLAN最多允许同时接入32个MAC地址认证或802.1X认证用户。
[Sysname-GigabitEthernet1/0/1] port-security mac-limit 32 per-vlan 1 5 10 to 20
· display dot1x
port-security mac-move bypass-vlan-check命令用来开启MAC迁移时不检查VLAN功能。
undo port-security mac-move bypass-vlan-check命令用来恢复缺省情况。
MAC迁移时不检查VLAN功能处于关闭状态,即当上线用户通过MAC迁移方式在本端口进行认证时,设备会检查用户所在VLAN是否包含在本端口所允许通过的VLAN中。
二层以太网接口视图
如果设备开启了MAC迁移功能,且用户上线的端口配置了MAC VLAN,则建议在MAC迁移的目的端口开启本功能。
端口开启MAC VLAN功能后,若用户上线成功并授权了VLAN,则当用户通过MAC迁移方式在其它端口上线时,用户发送的802.1X或MAC地址认证报文中会携带初始认证端口授权的VLAN信息。此时新端口会对用户认证的报文中携带的VLAN信息进行检查,如果用户所在VLAN不在新端口允许通过的VLAN范围内,则不允许用户进行MAC迁移。执行port-security mac-move bypass-vlan-check命令后,新端口不对用户认证的报文中携带的VLAN信息进行检查,不论用户所在VLAN是否在端口允许通过的VLAN范围内,都允许用户进行MAC迁移。
当在Trunk类型端口下开启MAC迁移时不检查VLAN功能,并对用户进行802.1X认证时,需要执行dot1x eapol untag命令配置端口发送802.1X协议报文不携带VLAN Tag功能。
# 在端口GigabitEthernet1/0/1下开启MAC迁移时不检查VLAN功能。
[Sysname-GigabitEthernet1/0/1] port-security mac-move bypass-vlan-check
· dot1x eapol untag(安全命令参考/802.1X)
· port-security mac-move permit
port-security mac-move permit命令用来开启允许MAC迁移功能。
undo port-security mac-move permit命令用来关闭允许MAC迁移功能。
port-security mac-move permit [ port | vlan ]
允许MAC迁移功能处于关闭状态。
port:表示允许用户进行端口迁移。
vlan:表示允许用户进行VLAN迁移。
允许MAC迁移功能是指,允许在线的802.1X用户、MAC地址认证用户或Web认证用户迁移到设备的其它端口上或迁移到同一端口下的其它VLAN(指不同于上一次发起认证时所在的VLAN)接入后可以重新认证上线。
迁移到其它端口上接入的功能对系统中的所有802.1X认证用户和MAC地址认证用户生效:
· MAC迁移功能处于关闭状态时,如果用户从某一端口上线成功,则该用户在未从当前端口下线的情况下无法在设备的其它端口上(无论该端口是否与当前端口属于同一VLAN)发起认证,也无法上线。
· MAC迁移功能处于开启状态时,如果用户从某一端口上线成功,则允许该在线用户在设备的其它端口上(无论该端口是否与当前端口属于同一VLAN)发起认证。如果该用户在后接入的端口上认证成功,则当前端口会将该用户立即进行下线处理(不论用户在当前端口上通过哪种方式进行认证),保证该用户仅在一个端口上处于上线状态。
迁移到同一端口下其它VLAN接入的功能只在用户报文携带VLAN Tag的情况下生效:
· MAC迁移功能处于关闭状态时,在用户报文携带VLAN Tag的情况下,如果用户从端口下的某个VLAN上线成功,则当该用户迁移到同一端口下的其它VLAN内发起认证时,用户认证失败。
· MAC迁移功能处于开启状态时,在用户报文携带VLAN Tag的情况下,如果用户从端口下的某个VLAN上线成功,则当该用户迁移到同一端口下的其它VLAN内发起认证时,用户认证成功,并且端口会对迁移前的在线用户立即进行下线处理,保证该用户仅在一个VLAN上处于上线状态。
如果用户进行MAC地址迁移前,服务器在线用户数已达到上限,则用户MAC地址迁移不成功。
对于迁移到同一端口下的其它VLAN内接入的用户,MAC地址认证的多VLAN模式优先级高于MAC迁移功能。当开启端口的多VLAN模式(通过mac-authentication host-mode multi-vlan命令)后,设备直接允许用户在新的VLAN通过,无需再次认证。
如果不指定任何参数,则表示同时开启端口迁移和VLAN迁移功能。
# 开启允许MAC迁移功能。
[Sysname] port-security mac-move permit
· mac-authentication host-mode(安全命令参考/MAC地址认证)
port-security max-mac-count命令用来设置端口安全允许的最大安全MAC地址数。
undo port-security max-mac-count命令用来恢复缺省情况。
port-security max-mac-count max-count [ vlan [ vlan-id-list ] ]
undo port-security max-mac-count [ vlan [ vlan-id-list ] ]
端口安全不限制本端口可保存的最大安全MAC地址数。
二层以太网接口视图
max-count:端口允许的最大安全MAC地址数,取值范围为1~2147483647。端口安全允许的最大安全MAC地址数不能小于当前端口下已保存的MAC地址数。
vlan [ vlan-id-list ]:指定端口所属VLAN。vlan-id-list是VLAN列表,表示方式为vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>,vlan-id取值范围为1~4094,&<1-10>表示前面的参数最多可以重复输入10次。vlan-id2的值必须大于或等于vlan-id1的值。若不指定vlan参数,则表示限制当前端口上允许的最大安全MAC地址数。若不指定vlan-id-list,则表示限制当前端口上每个VLAN内允许通过的最大安全MAC地址数。
对于autoLearn安全模式,端口允许的最大安全MAC地址数由本命令配置,包括端口上学习到的以及手工配置的安全MAC地址数;对于采用802.1X、MAC地址认证或者两者组合形式的认证类安全模式,端口允许的最大用户数取本命令配置的值与相应模式下允许认证用户数的最小值。例如,userLoginSecureExt模式下,端口下所允许的最大安全MAC地址数为配置的端口安全允许的最大安全MAC地址数与802.1X认证所允许的最大用户数的最小值。
当端口工作于autoLearn模式时,无法更改端口安全允许的最大安全MAC地址数。
vlan [ vlan-id-list ]参数配置仅对端口安全的autolearn模式生效。
端口允许的VLAN内最大安全MAC地址数不能小于当前VLAN内已保存的MAC地址数。
对于端口上的同一VLAN,后配置的最大安全MAC地址数覆盖前面配置的最大安全MAC地址数。
# 在端口GigabitEthernet1/0/1上配置端口安全允许的最大安全MAC地址数为100。
port-security nas-id-profile命令用来指定全局/端口引用的NAS-ID Profile。
undo port-security nas-id-profile命令用来恢复缺省情况。
port-security nas-id-profile profile-name
未指定引用的NAS-ID Profile。
二层以太网接口视图
profile-name:标识指定VLAN和NAS-ID绑定关系的Profile名称,为1~31个字符的字符串,区分大小写。
本命令引用的NAS-ID Profile由命令aaa nas-id profile配置,具体情况请参考“安全命令参考”中的“AAA”。
NAS-ID Profile可以在系统视图下或者接口视图下进行配置引用,接口上的配置优先,若接口上没有配置,则使用系统视图下的全局配置。
如果指定了NAS-ID Profile,则此Profile中定义的绑定关系优先使用;如果未指定NAS-ID Profile或指定的Profile中没有找到匹配的绑定关系,则使用设备名作为NAS-ID。
# 在端口GigabitEthernet1/0/1上指定名为aaa的NAS-ID Profile。
[Sysname-GigabitEthernet1/0/1] port-security nas-id-profile aaa
# 在系统视图下指定名为aaa的NAS-ID Profile。
[Sysname] port-security nas-id-profile aaa
· aaa nas-id profile(安全命令参考/AAA)
port-security ntk-mode命令用来配置端口Need To Know特性。
undo port-security ntk-mode命令用来恢复缺省情况。
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkauto | ntkonly }
端口未配置Need To Know特性,即所有报文都可成功发送。
二层以太网接口视图
ntk-withbroadcasts:允许广播地址报文、目的MAC地址为已知MAC地址的单播报文通过。
ntk-withmulticasts:允许广播地址报文、组播地址报文和目的MAC地址为已知MAC地址的单播报文通过。
ntkauto:仅当有用户上线后,才允许广播地址报文、组播地址报文和目的MAC地址为已知MAC地址的单播报文通过。
ntkonly:仅允许目的MAC地址为已知MAC地址的单播报文通过。
Need To Know特性通过检测从端口发出的数据帧的目的MAC地址,保证数据帧只能被发送到已知MAC地址的设备或主机上,从而防止非法设备窃听网络数据。
# 配置端口GigabitEthernet1/0/1的Need To Know特性为ntkonly,即仅允许目的MAC地址为已知MAC地址的单播报文通过。
[Sysname-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
port-security oui命令用来配置允许通过认证的用户的OUI值。
undo port-security oui命令用来删除指定索引的OUI值。
port-security oui index index-value mac-address oui-value
undo port-security oui index index-value
不存在允许通过认证的用户OUI值。
index-value:标识此OUI的索引值,取值范围为1~16。
oui-value:OUI值,输入格式为H-H-H的48位MAC地址。系统会自动取输入的前24位作为OUI值,忽略后24位。
OUI是MAC地址的前24位(二进制),是IEEE为不同设备供应商分配的一个全球唯一的标识符。当需要允许某些厂商的设备(如IP电话或打印机)无需认证即可接入网络时,则可以通过本命令来指定这些设备的OUI值。
可通过多次执行本命令,配置多个OUI值。
配置的OUI值只在端口安全模式为userLoginWithOUI时生效。在userLoginWithOUI模式下,端口上除了允许一个802.1X认证用户接入之外,还额外允许一个特殊用户接入,该用户报文的源MAC地址的OUI与设备上配置的某个OUI值相符。
# 配置一个允许通过认证的用户OUI值为000d2a,索引为4。
[Sysname] port-security oui index 4 mac-address 000d-2a10-0033
port-security port-mode命令用来配置端口安全模式。
undo port-security port-mode命令用来恢复缺省情况。
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
端口处于noRestrictions模式,此时该端口的安全功能关闭,端口处于不受端口安全限制的状态。
二层以太网接口视图
表1-4 安全模式的参数解释表
参数 |
安全模式 |
autolearn |
autoLearn |
端口可通过手工配置或自动学习MAC地址。手工配置或自动学习到的MAC地址被称为安全MAC,并被添加到安全MAC地址表中 当端口下的安全MAC地址数超过端口安全允许的最大安全MAC地址数后,端口模式会自动转变为secure模式。之后,该端口停止添加新的安全MAC,只有源MAC地址为安全MAC地址、通过命令mac-address dynamic或mac-address static手工配置的MAC地址的报文,才能通过该端口 |
macAddressWithRadius |
对接入用户采用MAC地址认证 此模式下,端口允许多个用户接入 |
macAddressElseUserLoginSecure |
端口同时处于macAddressWithRadius模式和userLoginSecure模式,但MAC地址认证优先级大于802.1X认证。允许端口下一个802.1X认证用户及多个MAC地址认证用户接入 非802.1X报文直接进行MAC地址认证。802.1X报文先进行MAC地址认证,如果MAC地址认证失败再进行802.1X认证 |
macAddressElseUserLoginSecureExt |
与macAddressElseUserLoginSecure类似,但允许端口下有多个802.1X和MAC地址认证用户 |
secure |
secure |
禁止端口学习MAC地址,只有源MAC地址为端口上的安全MAC地址、手工配置的MAC地址的报文,才能通过该端口 |
userlogin |
userLogin |
对接入用户采用基于端口的802.1X认证 此模式下,端口下的第一个802.1X用户认证成功后,其它用户无须认证就可接入 |
userlogin-secure |
userLoginSecure |
对接入用户采用基于MAC地址的802.1X认证 此模式下,端口最多只允许一个802.1X认证用户接入 |
userLoginSecureExt |
对接入用户采用基于MAC的802.1X认证,且允许端口下有多个802.1X用户 |
macAddressOrUserLoginSecure |
端口同时处于userLoginSecure模式和macAddressWithRadius模式,且允许一个802.1X认证用户及多个MAC地址认证用户接入 此模式下,802.1X认证优先级大于MAC地址认证:报文首先触发802.1X认证,默认情况下,如果802.1X认证失败再进行MAC地址认证;若开启了端口的MAC地址认证和802.1X认证并行处理功能,则端口配置了802.1X单播触发功能的情况下,当端口收到源MAC地址未知的报文,会向该MAC地址单播发送EAP-Request帧来触发802.1X认证,但不等待802.1X认证处理完成,就同时进行MAC地址认证 |
macAddressOrUserLoginSecureExt |
与macAddressOrUserLoginSecure类似,但允许端口下有多个802.1X和MAC地址认证用户 |
userlogin-withoui |
userLoginWithOUI |
与userLoginSecure模式类似,但端口上除了允许一个802.1X认证用户接入之外,还额外允许一个特殊用户接入,该用户报文的源MAC的OUI与设备上配置的OUI值相符 此模式下,报文首先进行OUI匹配,OUI匹配失败的报文再进行802.1X认证,OUI匹配成功和802.1X认证成功的报文都允许通过端口 |
端口安全模式与端口下的802.1X认证使能、端口接入控制方式、端口授权状态以及端口下的MAC地址认证使能配置互斥。
当端口安全已经使能且当前端口安全模式不是noRestrictions时,若要改变端口安全模式,必须首先执行undo port-security port-mode命令恢复端口安全模式为noRestrictions模式。
配置端口安全autoLearn模式时,首先需要通过命令port-security max-mac-count设置端口安全允许的最大安全MAC地址数。
端口上有用户在线的情况下,端口安全模式无法改变。
开启了MAC地址认证延迟功能的端口上不建议同时配置端口安全的模式为mac-else-userlogin-secure或mac-else-userlogin-secure-ext,否则MAC地址认证延迟功能不生效。MAC地址认证延迟功能的具体配置请参见“安全命令参考”中的“MAC地址认证”。
# 使能端口安全,并配置端口GigabitEthernet1/0/1的端口安全模式为secure。
[Sysname-GigabitEthernet1/0/1] port-security port-mode secure
# 将端口GigabitEthernet1/0/1的端口安全模式改变为userLogin。
[Sysname-GigabitEthernet1/0/1] undo port-security port-mode
[Sysname-GigabitEthernet1/0/1] port-security port-mode userlogin
· port-security max-mac-count
port-security strict-intrusion-protection enable命令用来开启严格入侵检测功能。
undo port-security strict-intrusion-protection enable命令用来关闭严格入侵检测功能。
严格入侵检测功能处于关闭状态。
二层以太网接口视图
严格入侵检测功能是指当用户在端口接入时,如果设备检测到其它端口的安全MAC地址表项中已经记录同一VLAN中的相同MAC地址,则认为该用户为非法用户,触发当前端口的入侵检测特性。
严格入侵检测功能仅在端口上的入侵检测特性模式为disableport或disableport-temporarily的情况下生效。
# 在端口GigabitEthernet1/0/1下开启严格入侵检测功能。
[Sysname-GigabitEthernet1/0/1] port-security strict-intrusion-protection enable
· port-security port-mode
port-security timer autolearn aging命令用来配置安全MAC地址的老化时间。
undo port-security timer autolearn aging命令用来恢复缺省情况。
port-security timer autolearn aging [ second ] time-value
安全MAC地址不会老化。
second:指定安全MAC地址老化时间单位为秒。如果未指定本参数,则表示安全MAC地址老化时间单位为分钟。
time-value:安全MAC地址的老化时间。若单位为分钟,则取值范围为0~129600,取值为0表示不会老化。若单位为秒,则取值范围10~7776000。
安全MAC地址的老化时间对所有端口学习到的安全MAC地址以及手工添加的Sticky MAC地址均有效。
当指定的安全MAC地址老化时间单位为秒时:
· 当配置的老化时间大于等于60秒时,实际生效的老化时间按30秒为步长向上取整。例如,配置的老化时间为80秒时,实际生效的老化时间为90秒。
· 当配置的老化时间小于60秒时,实际生效的老化时间与用户配置值一致。
较短的老化时间可提高端口接入的安全性和端口资源的利用率,但也会影响在线用户的在线稳定性,因此需要结合当前的网络环境和设备的性能合理设置老化时间。
当配置的安全MAC地址老化时间小于60秒,且安全MAC地址老化方式为无流量老化时,建议端口安全允许的最大安全MAC地址数不要配置过大,否则可能影响设备性能。
当在接口视图和系统视图下同时配置安全MAC老化时间时,接口视图下的配置优先级高于系统视图,实际生效的老化时间以接口视图下的配置为准。
# 配置安全MAC地址的老化时间为30分钟。
[Sysname] port-security timer autolearn aging 30
# 配置安全MAC地址的老化时间为50秒。
[Sysname] port-security timer autolearn aging second 50
port-security timer autolearn aging second命令用来配置安全MAC地址的老化时间。
undo port-security timer autolearn aging second命令用来恢复缺省情况。
仅R1132及以上版本支持本命令。
port-security timer autolearn aging second time-value
安全MAC地址不会老化。
二层以太网接口视图
二层聚合接口视图
time-value:安全MAC地址的老化时间,取值范围为10~7776000,单位为秒。
缺省情况下,所有的安全MAC地址均不老化。当安全MAC地址用户不活跃或者频繁切换位置时,为了避免这类安全MAC地址长期占用系统资源或迁移到新端口无法上线,可让安全MAC地址定期老化,提高端口接入的安全性和端口资源的利用率。
在接口视图下通过本命令配置的安全MAC地址老化时间,对该端口下自动学习到的Sticky MAC、手工添加的Sticky MAC地址和动态安全MAC地址均有效。
指定安全MAC地址的老化时间后,其实际生效值分为以下两种情况:
# 配置接口GigabitEthernet1/0/1的安全MAC地址的老化时间为50秒。
[Sysname-GigabitEthernet1/0/1] port-security timer autolearn aging second 50
port-security timer blockmac命令用来配置将非法报文的源MAC地址加入阻塞MAC地址列表的时间。
undo port-security timer blockmac命令用来恢复缺省情况。
port-security timer blockmac time-value
将非法报文的源MAC地址加入阻塞MAC地址列表的时间为180秒。
time-value:将非法报文的源MAC地址加入阻塞MAC地址列表的时间,取值范围为1~3600,单位为秒。
当通过port-security intrusion-mode命令设置入侵检测特性模式为blockmac时,将非法报文的源MAC地址加入阻塞MAC地址列表的时间由该命令配置。
# 配置将非法报文的源MAC地址加入阻塞MAC地址列表的时间为60秒。
[Sysname] port-security timer blockmac 60
port-security timer disableport命令用来配置系统暂时关闭端口的时间。
undo port-security timer disableport命令用来恢复缺省情况。
port-security timer disableport time-value
系统暂时关闭端口的时间为20秒。
time-value:端口关闭的时间,取值范围为20~300,单位为秒。
当port-security intrusion-mode设置为disableport-temporarily模式时,系统暂时关闭端口的时间由该命令配置。
# 配置端口GigabitEthernet1/0/1的入侵检测特性检测到非法报文后,将收到非法报文的端口暂时关闭30秒。
[Sysname] port-security timer disableport 30
[Sysname-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
port-secuity user-mac control enable命令用来开启端口安全接入用户安全MAC控制功能。
undo port-secuity user-mac control enable命令用来关闭端口安全接入用户安全MAC控制功能。
仅F1127及以上版本支持本命令。
端口安全接入用户安全MAC控制功能处于关闭状态。
二层以太网接口视图
缺省情况下,只有端口安全autoLearn模式下手动配置或自动学习的MAC地址属于安全MAC地址,受安全MAC相关功能控制。为了进一步提高网络接入安全,对端口的多种接入用户进行统一的安全MAC配置管理,现设备支持端口安全接入用户安全MAC控制功能。
开启本功能后,端口上认证成功的802.1X认证用户、MAC地址认证用户、Web认证用户以及Voice VLAN用户的MAC地址都将被添加到安全MAC表项中,受安全MAC相关功能控制。例如,其在线个数受端口安全允许的最大安全MAC地址数限制、支持入侵检测以及可以手动删除等。
本功能下生成的安全MAC属于Sticky MAC,可通过port-security mac-address dynamic命令转换为动态安全MAC。
与autoLearn模式下生成的Sticky MAC不同的是,认证成功用户和Voice VLAN用户在线期间,其Sticky MAC表项不会老化,只有当用户下线后,其Sticky MAC表项才会受定时老化和无流量老化机制影响。
配置本功能前,必须先在接口视图下执行port-security max-mac-count命令设置端口安全允许的最大安全MAC地址数。配置本功能后,不能修改端口安全允许的最大安全MAC地址数。
接口下配置dot1x port-method portbased或者mac-authentication host-mode multi-vlan命令时,只有第一个认证成功用户的MAC地址被添加到安全MAC表项中。
# 开启端口安全接入用户安全MAC控制功能。
[Sysname-GigabitEthernet1/0/1] port-security user-mac control enable
· display port-securtiy mac-address security
snmp-agent trap enable port-security命令用来开启端口安全告警功能。
undo snmp-agent trap enable port-security命令用来关闭指定的端口安全告警功能。
snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
undo snmp-agent trap enable port-security [ address-learned | dot1x-failure | dot1x-logoff | dot1x-logon | intrusion | mac-auth-failure | mac-auth-logoff | mac-auth-logon ] *
端口安全的所有告警功能均处于关闭状态。
address-learned:表示端口学习到新MAC地址时的告警功能。
dot1x-failure:表示802.1X用户认证失败时的告警功能。
dot1x-logon:表示802.1X用户认证成功时的告警功能。
dot1x-logoff:表示802.1X用户认证下线时的告警功能。
intrusion:表示发现非法报文时的告警功能。
mac-auth-failure:表示MAC地址认证用户认证失败时的告警功能。
mac-auth-logoff:表示MAC地址认证用户认证下线时的告警功能。
mac-auth-logon:表示MAC地址认证用户认证成功时的告警功能。
如果不指定任何参数,则表示开启或关闭所有类型的端口安全告警功能。
指定intrusion参数时,必须同时配置了入侵检测特性(通过命令port-security intrusion-mode),该告警功能才生效。
开启端口安全模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启端口学习到新MAC地址时的告警功能。
[Sysname] snmp-agent trap enable port-security address-learned
· port-security enable
