H3C serves all levels of broadcasting customers in the long term and has extensive practical experience.
Extensive technical cooperation with industry partners to create greater value.
H3C provides end-to-end smart digital solutions and services.
H3C has a full range of digital infrastructures and the independent R&D capabilities of 5G, cloud computing, big data, AI, information security, edge computing and other products.
The collaboration of three clouds facilitates the in-depth media convergence
Flexibly and efficiently meets the needs of SD, HD, 4K UHD non-linear production businesses
Helps radio and television customers to rapidly build UHD IP production and broadcasting solutions
Conveniently meets the needs of rapid business growth, network performance improvement and capacity growth
Enables the business development of radio and television group customers from multiple dimensions
Accelerates the transformation and upgrading of China Broadnet in the 5G era
Helps radio and television operators create smart, operable and easy-to-evolve outlet security platforms
Network silos stall enterprise agility. H3C deploys Agentic AI-Defined LAN and Wi-Fi 8 infrastructure. Reduce MTTR and ensure seamless digital transformation.
