| Title | Size | Downloads |
| H3C S3100-52P Ethernet Switch Operatioin Manual-Release 1702-6W100-LLDP Operation.pdf | 182.08 KB |
| 39-LLDP Operation | 182.08 KB |
Table of Contents
Performing Basic LLDP Configuration
Setting the LLDP Re-Initialization Delay
Configuring the TLVs to Be Advertised
Configuring the Management Address
Setting an Encapsulation Format for LLDPDUs
Displaying and Maintaining LLDP
Basic LLDP Configuration Example
CDP-Compatible LLDP Configuration Example
When configuring LLDP, go to these sections for information you are interested in:
l Overview
l LLDP Configuration Task List
l Performing Basic LLDP Configuration
l Configuring CDP Compatibility
l Displaying and Maintaining LLDP
H3C S3100-52P Ethernet Switch supports LLDP in Release 1702.
Overview
Background
In a heterogeneous network, it is important that different types of network devices from different vendors can discover one other and exchange configuration for interoperability and management sake. This calls for a standard configuration exchange platform.
To address the needs, the IETF drafted the Link Layer Discovery Protocol (LLDP) in IEEE 802.1AB. The protocol operates on the data link layer to exchange device information between directly connected devices. With LLDP, a device sends local device information (including its major functions, management IP address, device ID, and port ID) as TLV (type, length, and value) triplets in LLDPDUs to the directly connected devices, and at the same time, stores the device information received in LLDPDUs sent from the LLDP neighbors in a standard management information base (MIB). It allows a network management system to fast detect Layer-2 network topology change and identify what the change is.
For more information about MIBs, refer to SNMP-RMON Operation in this manual.
Basic Concepts
LLDP frames
LLDP sends device information in LLDP data units (LLDPDUs). LLDPDUs are encapsulated in Ethernet II or SNAP frames.
1) Ethernet II-encapsulated LLDP frame format
Figure 1-1 Ethernet II-encapsulated LLDP frame format
The fields in the frame are described in Table 1-1:
Table 1-1 Description of the fields in an Ethernet II-encapsulated LLDP frame
Destination MAC address |
The MAC address to which the LLDPDU is advertised. It is fixed to 0x0180-C200-000E, a multicast MAC address. |
Source MAC address |
The MAC address of the sending port. If the port does not have a MAC address, the MAC address of the sending bridge is used. |
Type |
The Ethernet type for the upper layer protocol. It is 0x88CC for LLDP. |
Data |
LLDP data unit (LLDPDU). |
FCS |
Frame check sequence, a 32-bit CRC value used to determine the validity of the received Ethernet frame. |
2) SNAP-encapsulated LLDP frame format
Figure 1-2 SNAP-encapsulated LLDP frame format
The fields in the frame are described in Table 1-2:
Table 1-2 Description of the fields in a SNAP-encapsulated LLDP frame
Type |
The SNAP type for the upper layer protocol. It is 0xAAAA-0300-0000-88CC for LLDP. |
Data |
LLDPDU. |
FCS |
LLDPDUs
LLDP uses LLDPDUs to exchange information. An LLDPDU comprises multiple type, length, and value (TLV) sequences, each carrying a type of device information, as shown in Figure 1-3.
An LLDPDU can carry up to 28 types of TLVs, of which the chassis ID TLV, port ID TLV, TTL TLV, and end of LLDPDU TLV (end TLV in the figure) are mandatory TLVs that must be carried and other TLVs are optional.
TLVs
TLVs are type, length, and value sequences that carry information elements, where the type field identifies the type of information, the length field indicates the length of the information field in octets, and the value field contains the information itself.
LLDPDU TLVs fall into these categories: basic management TLVs, organizationally (IEEE 802.1 and IEEE 802.3) specific TLVs, and LLDP-MED (media endpoint discovery) TLVs. Basic management TLVs are essential to device management. Organizationally specific TLVs and LLDP-MED TLVs are used for enhanced device management; they are defined by standardization or other organizations and thus are optional to LLDPDUs.
1) Basic management TLVs
Table 1-1 lists the basic management TLV types currently in use. Some of them are mandatory to LLDPDUs, that is, must be included in every LLDPDU.
Table 1-3 Basic LLDP TLVs
Type |
Remarks |
Chassis ID |
Bridge MAC address of the sending device. |
Mandatory |
Port ID |
ID of the sending port. If MED TLVs are included in the LLDPDU, the port ID TLV carries the MAC address of the sending port or the bridge MAC in case the port does not have a MAC address. If no MED TLVs are included, the port ID TLV carries the port name. |
Time To Live |
Life of the transmitted information on the receiving device. |
End of LLDPDU |
Marks the end of the TLV sequence in the LLDPDU. |
Port Description |
Port description of the sending port. |
Optional |
System Name |
Assigned name of the sending device. |
System Description |
Description of the sending device. |
System Capabilities |
Identifies the primary functions of the sending device and the primary functions that have been enabled. |
Management Address |
Management address used to reach higher level entities to assist discovery by network management, and the interface number and OID (object identifier) associated with the address. |
2) IEEE 802.1 organizationally specific TLVs
Table 1-4 IEEE 802.1 organizationally specific TLVs
Type |
Port VLAN ID |
PVID of the sending port |
Port And Protocol VLAN ID |
Port and protocol VLAN IDs |
VLAN Name |
A specific VLAN name on the port |
Protocol Identity |
Protocols supported on the port |
Currently, H3C devices support receiving but not sending protocol identity TLVs.
3) IEEE 802.3 organizationally specific TLVs
Table 1-5 IEEE 802.3 organizationally specific TLVs
Type |
MAC/PHY Configuration/Status |
Contains the rate and duplex capabilities of the sending port, support for auto negotiation, enabling status of auto negotiation, and the current rate and duplex mode. |
Power Via MDI |
Contains Power supply capability of the port, including the PoE type (PSE or PD), PoE mode, support for the PSE power supply, whether PSE power supply is enabled, and whether the PoE mode is controllable. |
Link Aggregation |
Indicates the support of the port for link aggregation, the aggregation capability of the port, and the aggregation status (that is, whether the link is in an aggregation). |
Maximum Frame Size |
Indicates the supported maximum frame size. It is now the MTU of the port. |
LLDP-MED TLVs
LLDP-MED TLVs provide multiple advanced applications for voice over IP (VoIP), such as basic configuration, network policy configuration, and address and directory management. LLDP-MED TLVs satisfy the voice device vendors’ requirements for cost effectiveness, ease of deployment, and ease of management. In addition, LLDP-MED TLVs make deploying voice devices in Ethernet easier. LLDP-MED TLVs are shown in Table 1-6:
Type |
LLDP-MED Capabilities |
Allows a MED endpoint to advertise the supported LLDP-MED TLVs and its device type. |
Network Policy |
Allows a network device or MED endpoint to advertise LAN type and VLAN ID of the specific port, and the Layer 2 and Layer 3 priorities for a specific set of applications. |
Extended Power-via-MDI |
Allows a network device or MED endpoint to advertise power-related information (according to IEEE 802.3AF). |
Hardware Revision |
Allows a MED endpoint device to advertise its hardware version. |
Firmware Revision |
Allows a MED endpoint to advertise its firmware version. |
Software Revision |
Allows a MED endpoint to advertise its software version. |
Serial Number |
Allows an LLDP-MED endpoint device to advertise its serial number. |
Manufacturer Name |
Allows a MED endpoint to advertise its vendor name. |
Model Name |
Allows a MED endpoint to advertise its model name. |
Asset ID |
Allows a MED endpoint to advertise its asset ID. The typical case is that the user specifies the asset ID for the endpoint to facilitate directory management and asset tracking. |
Location Identification |
Allows a network device to advertise the appropriate location identifier information for an endpoint to use in the context of location-based applications. |
Management address
The management address of a device is used by the network management system to identify and manage the device for topology maintenance and network management. The management address is encapsulated in the management address TLV.
Operating Modes of LLDP
LLDP can operate in one of the following modes:
l TxRx mode. A port in this mode sends and receives LLDP frames.
l Tx mode. A port in this mode only sends LLDP frames.
l Rx mode. A port in this mode only receives LLDP frames.
l Disable mode. A port in this mode does not send or receive LLDP frames.
Each time the LLDP operating mode of a port changes, its LLDP protocol state machine re-initializes. To prevent LLDP from being initialized too frequently at times of frequent operating mode change, an initialization delay, which is user configurable, is introduced. With this delay mechanism, a port must wait for the specified interval before it can initialize LLDP after the LLDP operating mode changes.
How LLDP Works
Transmitting LLDP frames
An LLDP-enabled port operating in TxRx mode or Tx mode sends LLDP frames to its directly connected devices both periodically and when the local configuration changes. To prevent the network from being overwhelmed by LLDP frames at times of frequent local device information change, an interval is introduced between two successive LLDP frames.
This interval is shortened to 1 second in either of the following two cases:
l A new neighbor is discovered, that is, a new LLDP frame is received carrying device information new to the local device.
l The LLDP operating mode of the port changes from Disable/Rx to TxRx or Tx.
This is the fast sending mechanism of LLDP. With this mechanism, a specific number of LLDP frames are sent successively at the 1-second interval to help LLDP neighbors discover the local device as soon as possible. Then, the normal LLDP frame transmit interval resumes.
Receiving LLDP frames
An LLDP-enabled port operating in TxRx mode or Rx mode checks the TLVs carried in every LLDP frame it receives for validity violation. If valid, the information is saved and an aging timer is set for it based on the time to live (TTL) TLV carried in the LLDPDU. If the TTL TLV is zero, the information is aged out immediately.
Protocols and Standards
The protocols and standards related to LLDP include:
l IEEE 802.1AB-2005, Station and Media Access Control Connectivity Discovery
l ANSI/TIA-1057, Link Layer Discovery Protocol for Media Endpoint Devices
Complete these tasks to configure LLDP:
Task |
Remarks |
Required |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Enabling LLDP
To make LLDP take effect on certain ports, you need to enable LLDP both globally and on these ports.
Follow these steps to enable LLDP:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable LLDP globally |
lldp enable |
Required By default, LLDP is disabled globally. |
Enter Ethernet interface view |
Required |
Enable LLDP |
lldp enable |
Optional By default, LLDP is enabled on a port. |
Setting LLDP Operating Mode
LLDP can operate in one of the following modes.
Follow these steps to set LLDP operating mode:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Set the LLDP operating mode |
lldp admin-status { disable | rx | tx | txrx } |
Optional TxRx by default. |
When LLDP operating mode changes on a port, the port initializes the protocol state machines after a certain delay. By adjusting the LLDP re-initialization delay, you can avoid frequent initializations caused by frequent LLDP operating mode changes on a port.
Follow these steps to set the LLDP re-initialization delay for ports:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Set the LLDP re-initialization delay |
lldp timer reinit-delay delay |
Optional 2 seconds by default |
Enabling LLDP Polling
With LLDP polling enabled, a device checks for local configuration changes periodically. Upon detecting a configuration change, the device sends LLDP frames to inform the neighboring devices of the change.
Follow these steps to enable LLDP polling:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Enable LLDP polling and set the polling interval |
lldp check-change-interval interval |
Required Disabled by default |
Follow these steps to configure the LLDPDU TLVs to be advertised out the specified port or ports:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Configure the TLVs to be advertised |
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1–10> | elin-address tel-number } | network-policy | power-over-ethernet } } |
Optional By default, all types of LLDP TLVs except location identification TLV are advertisable. |
The management address of a device is used by the network management system to identify and manage the device for topology maintenance and network management. The management address is encapsulated in the management address TLV. LLDP encodes management addresses in numeric format in management address TLVs.
Make sure that a neighbor also encodes its management address in numeric format to guarantee normal communication with the neighbor.
Follow these steps to configure a management address to be advertised on a port:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Enable LLDP to advertise management address TLVs and configure the advertised management IP address |
lldp management-address-tlv [ ip-address ] |
Optional By default, the management address is sent through LLDPDUs, and the management address is the main IP address of the lowest-ID VLAN carried on the interface. If the VLAN is not assigned a main IP address, 127.0.0.1 is used. |
Setting Other LLDP Parameters
The TTL TLV carried in an LLDPDU determines how long the device information carried in the LLDPDU can be saved on a recipient device.
You can configure the TTL of locally sent LLDP frames to determine how long information about the local device can be saved on a neighbor device by setting the TTL multiplier. The TTL is expressed as follows:
TTL = Min (65535, (TTL multiplier × LLDPDU transmit interval))
As the expression shows, the TTL can be up to 65535 seconds. TTLs greater than it will be rounded down to 65535 seconds.
Follow these steps to change the TTL multiplier:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Set the TTL multiplier |
lldp hold-multiplier value |
Optional 4 by default. |
Set the LLDPDU transmit interval |
lldp timer tx-interval interval |
Optional 30 seconds by default |
Set LLDPDU transmit delay |
lldp timer tx-delay delay |
Set the number of LLDP frames sent each time fast LLDPDU transmission is triggered. |
lldp fast-count count |
Optional 3 by default |
Both the LLDPDU transmit interval and delay must be less than the TTL to ensure that the LLDP neighbors can receive LLDP frames to update information about the device you are configuring before it is aged out.
LLDPDUs can be encapsulated in Ethernet II or SNAP frames.
l With Ethernet II encapsulation configured, an LLDP port sends LLDPDUs in Ethernet II frames and processes an incoming LLDP frame only when it is Ethernet II encapsulated.
l With SNAP encapsulation configured, an LLDP port sends LLDPDUs in SNAP frames and processes an incoming LLDP frame only when it is SNAP encapsulated.
By default, LLDPDUs are encapsulated in Ethernet II frames. If the neighbor devices encapsulate LLDPDUs in SNAP frames, configure the encapsulation format for LLDPDUs as SNAP to guarantee normal communication with the neighbors.
Follow these steps to set the encapsulation format for LLDPDUs to SNAP:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Set the encapsulation format for LLDPDUs to SNAP |
lldp encapsulation snap |
Required Ethernet II encapsulation format applies by default. To restore the default, use the undo lldp encapsulation command. |
LLDP-CDP (CDP is short for the Cisco Discovery Protocol) packets use only SNAP encapsulation.
On an S3100-52P switch, only one voice VLAN exists at any given point in time. For detailed information about voice VLAN, refer to Voice VLAN Operation in this manual.
You need to enable CDP compatibility for your device to work with Cisco IP phones.
As your LLDP-enabled device cannot recognize CDP packets, it does not respond to the requests of Cisco IP phones for the voice VLAN ID configured on the device. This can cause a requesting Cisco IP phone to send voice traffic without any tag to your device, disabling your device from differentiating voice traffic from other types of traffic.
Configuration Prerequisites
Before configuring CDP compatibility, make sure that:
l LLDP is enabled globally.
l LLDP is enabled on the port connected to an IP phone and is configured to operate in TxRx mode on the port.
CDP-compatible LLDP operates in one of the follows two modes:
l TxRx, where CDP packets can be transmitted and received.
l Disable, where CDP packets can neither be transmitted nor be received.
To make CDP-compatible LLDP take effect on certain ports, first enable CDP-compatible LLDP globally and configure CDP-compatible LLDP to operate in TxRx mode.
Follow these steps to enable LLDP to be compatible with CDP:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable CDP compatibility globally |
lldp compliance cdp |
Required Disabled by default. |
Required |
Configure CDP-compatible LLDP to operate in TxRx mode |
lldp compliance admin-status cdp txrx |
Required By default, CDP-compatible LLDP operates in disable mode. |
As the maximum TTL allowed by CDP is 255 seconds, ensure that the product of the TTL multiplier and the LLDPDU transmit interval is less than 255 seconds for CDP-compatible LLDP to work properly with Cisco IP phones. You can use related commands to configure the TTL multiplier and the LLDPDU transmit interval. For details, see Setting Other LLDP Parameters.
Configuring LLDP Trapping
LLDP trapping is used to notify the network management system (NMS) of events such as new neighboring devices detected and link malfunctions.
To prevent excessive LLDP traps from being sent when topology is unstable, you can set a minimum trap sending interval for LLDP.
Follow these steps to configure LLDP trapping:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Enable LLDP trap sending |
lldp notification remote-change enable |
Quit to system view |
quit |
Set the interval to send LLDP traps |
lldp timer notification-interval interval |
Optional 5 seconds by default |
Use the command… |
Remarks |
Display the global LLDP information or the information contained in the LLDP TLVs to be sent through a port |
display lldp local-information [ global | interface interface-type interface-number ] |
Available in any view |
Display the information contained in the LLDP TLVs sent from neighboring devices |
display lldp neighbor-information [ interface interface-type interface-number ] [ brief ] |
Display LLDP statistics |
display lldp statistics [ global | interface interface-type interface-number ] |
Display LLDP status of a port |
display lldp status [ interface interface-type interface-number ] |
Display types of advertisable optional LLDP TLVs |
display lldp tlv-config [ interface interface-type interface-number ] |
LLDP Configuration Examples
Network requirements
As shown in Figure 1-4, the NMS and Switch A are located in the same Ethernet. An MED device and Switch B are connected to Ethernet 1/0/1 and Ethernet 1/0/2 of Switch A.
Enable LLDP on the ports of Switch A and Switch B to monitor the link between Switch A and Switch B and the link between Switch A and the MED device on the NMS.
Figure 1-4 Network diagram for basic LLDP configuration
Configuration procedure
1) Configure Switch A.
# Enable LLDP globally.
[SwitchA] lldp enable
# Enable LLDP on Ethernet 1/0/1 and Ethernet 1/0/2 (you can skip this step because LLDP is enabled on ports by default), and set the LLDP operating mode to Rx.
[SwitchA] interface ethernet 1/0/1
[SwitchA-Ethernet1/0/1] lldp enable
[SwitchA-Ethernet1/0/1] lldp admin-status rx
[SwitchA-Ethernet1/0/1] quit
[SwitchA] interface ethernet 1/0/2
[SwitchA-Ethernet1/0/2] lldp enable
[SwitchA-Ethernet1/0/2] lldp admin-status rx
[SwitchA-Ethernet1/0/2] quit
2) Configure Switch B.
[SwitchB] lldp enable
# Enable LLDP on Ethernet1/0/1 (you can skip this step because LLDP is enabled on ports by default), and set the LLDP operating mode to Tx.
[SwitchB] interface ethernet 1/0/1
[SwitchB-Ethernet1/0/1] lldp enable
[SwitchB-Ethernet1/0/1] lldp admin-status tx
[SwitchB-Ethernet1/0/1] quit
3) Verify the configuration.
# Display the global LLDP status and port LLDP status on Switch A.
[SwitchA] display lldp status
Global status of LLDP : Enable
The current number of LLDP neighbors : 2
The current number of CDP neighbors : 0
LLDP neighbor information last changed time: 0 days,0 hours,4 minutes,40 seconds
Transmit interval : 30s
Hold multiplier : 4
Reinit delay : 2s
Transmit delay : 2s
Trap interval : 5s
Fast start times : 3
Port 1 [Ethernet1/0/1]:
Port status of LLDP : Enable
Admin status : Rx_Only
Trap flag : No
Roll time : 0s
Number of neighbors : 1
Number of MED neighbors : 1
Number of CDP neighbors : 0
Number of sent optional TLV : 0
Number of received unknown TLV : 0
Port 2 [Ethernet1/0/2]:
Trap flag : No
Roll time : 0s
Number of MED neighbors : 0
Number of received unknown TLV : 3
As the sample output shows, Ethernet 1/0/1 of Switch A connects a MED device, and Ethernet 1/0/2 of Switch A connects a non-MED device. Both ports operate in Rx mode, that is, they only receive LLDP frames.
# Tear down the link between Switch A and Switch B and then display the global LLDP status and port LLDP status on Switch A.
The current number of LLDP neighbors : 1
LLDP neighbor information last changed time: 0 days,0 hours,5 minutes,20 seconds
Hold multiplier : 4
Reinit delay : 2s
Transmit delay : 2s
Trap interval : 5s
Trap flag : No
Roll time : 0s
Trap flag : No
Roll time : 0s
Number of neighbors : 0
As shown in the sample output, Ethernet 1/0/2 of Switch A does not connect any neighboring devices.
As shown in Figure 1-5:
l Ethernet 1/0/1 and Ethernet 1/0/2 of Switch A are each connected to a Cisco IP phone.
l Configure voice VLAN 2 on Switch A. Enable CDP compatibility of LLDP on Switch A to allow the Cisco IP phones to automatically configure the voice VLAN, thus confining their voice traffic within the voice VLAN to be isolated from other types of traffic.
Figure 1-5 Network diagram for CDP-compatible LLDP configuration
1) Configure a voice VLAN on Switch A
# Create VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] quit
# Set the link type of Ethernet 1/0/1 and Ethernet 1/0/2 to trunk and enable voice VLAN on them.
[SwitchA-Ethernet1/0/1] port link-type trunk
[SwitchA-Ethernet1/0/1] voice vlan 2 enable
[SwitchA-Ethernet1/0/2] port link-type trunk
[SwitchA-Ethernet1/0/2] voice vlan 2 enable
2) Configure CDP-compatible LLDP on Switch A.
# Enable LLDP globally and enable LLDP to be compatible with CDP globally.
[SwitchA] lldp compliance cdp
# Enable LLDP (you can skip this step because LLDP is enabled on ports by default), configure LLDP to operate in TxRx mode, and configure CDP-compatible LLDP to operate in TxRx mode on Ethernet 1/0/1 and Ethernet 1/0/2.
[SwitchA-Ethernet1/0/1] lldp admin-status txrx
[SwitchA-Ethernet1/0/1] lldp compliance admin-status cdp txrx
[SwitchA-Ethernet1/0/2] lldp admin-status txrx
[SwitchA-Ethernet1/0/2] lldp compliance admin-status cdp txrx
# Display the neighbor information on Switch A.
[SwitchA] display lldp neighbor-information
CDP neighbor-information of port 1[Ethernet1/0/1]:
CDP neighbor index : 1
Chassis ID : SEP00141CBCDBFE
Port ID : Port 1
Sofrware version : P0030301MFG2
Platform : Cisco IP Phone 7960
Duplex : Full
CDP neighbor-information of port 2[Ethernet1/0/2]:
CDP neighbor index : 2
Chassis ID : SEP00141CBCDBFF
Port ID : Port 1
Duplex : Full
As the sample output shows, Switch A has discovered the IP phones connected to Ethernet 1/0/1 and Ethernet 1/0/2, and has obtained their LLDP device information.
